Results 1 to 6 of 6
Thread: Neopixel Library Missing Arduino Defines for Teensy 3.5
    I am trying to build a sketch I have used many times on multiple devices including the teensy 3.2 but it will not compile on the 3.5 (both through the arduino IDE and platformio.) It appears some framework defines for the board are missing.
    Soucre code
    Library used
    Here is the output from teh arduino IDE
    Arduino: 1.8.2 (Mac OS X), TD: 1.37, Board: "Teensy 3.5, Serial, 120 MHz, Faster, US English"
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp: In member function 'void Adafruit_NeoPixel::show()':
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1659:3: error: 'Pio' was not declared in this scope
       Pio            *port;
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1659:19: error: 'port' was not declared in this scope
       Pio            *port;
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1660:12: error: 'WoReg' does not name a type
       volatile WoReg *portSet, *portClear, *timeValue, *timeReset;
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1663:29: error: 'pmc_set_writeprotect' was not declared in this scope
       pmc_set_writeprotect(false);
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1664:35: error: 'TC3_IRQn' was not declared in this scope
       pmc_enable_periph_clk((uint32_t)TC3_IRQn);
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1664:43: error: 'pmc_enable_periph_clk' was not declared in this scope
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1665:16: error: 'TC1' was not declared in this scope
       TC_Configure(TC1, 0,
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:5: error: 'TC_CMR_WAVE' was not declared in this scope
         TC_CMR_WAVE | TC_CMR_WAVSEL_UP | TC_CMR_TCCLKS_TIMER_CLOCK1);
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:19: error: 'TC_CMR_WAVSEL_UP' was not declared in this scope
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:38: error: 'TC_CMR_TCCLKS_TIMER_CLOCK1' was not declared in this scope
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:64: error: 'TC_Configure' was not declared in this scope
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1667:18: error: 'TC_Start' was not declared in this scope
       TC_Start(TC1, 0);
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1669:15: error: 'g_APinDescription' was not declared in this scope
       pinMask   = g_APinDescription[pin].ulPin; // Don't 'optimize' these into
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1671:3: error: 'portSet' was not declared in this scope
       portSet   = &(port->PIO_SODR);            // burn a few cycles after
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1672:3: error: 'portClear' was not declared in this scope
       portClear = &(port->PIO_CODR);            // starting timer to minimize
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1673:3: error: 'timeValue' was not declared in this scope
       timeValue = &(TC1->TC_CHANNEL[0].TC_CV);  // the initial 'while'.
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1674:3: error: 'timeReset' was not declared in this scope
       timeReset = &(TC1->TC_CHANNEL[0].TC_CCR);
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1649:22: error: 'VARIANT_MCK' was not declared in this scope
       #define SCALE      VARIANT_MCK / 2UL / 1000000UL
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1651:36: note: in expansion of macro 'SCALE'
       #define TIME_800_0 ((int)(0.40 * SCALE + 0.5) - (5 * INST))
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1683:14: note: in expansion of macro 'TIME_800_0'
         time0  = TIME_800_0;
    Multiple libraries were found for "Adafruit_NeoPixel.h"
     Used: /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel
     Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Adafruit_NeoPixel
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1654:36: note: in expansion of macro 'SCALE'
       #define TIME_400_0 ((int)(0.50 * SCALE + 0.5) - (5 * INST))
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1688:14: note: in expansion of macro 'TIME_400_0'
         time0  = TIME_400_0;
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1698:18: error: 'TC_CCR_CLKEN' was not declared in this scope
         *timeReset = TC_CCR_CLKEN | TC_CCR_SWTRG;
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1698:33: error: 'TC_CCR_SWTRG' was not declared in this scope
    /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1708:17: error: 'TC_Stop' was not declared in this scope
       TC_Stop(TC1, 0);
    Error compiling for board Teensy 3.5.
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    839
    I have Neopixel working fine with 3.5. Using IDE 1.8.2 and teensyduino 1.37.
    3,493
    You are using your own version of this library as shown in the error messages like:
    Try deleting this version and use the one that is installed as part of Teensyduino...
    Did a quick check of the Adafruit version up at: https://github.com/adafruit/Adafruit...t_NeoPixel.cpp
    And it looks like this one has not been updated, nor in a quick check did I see any Pull requests... Would be great if someone did one...
    #if defined(__MK20DX128__) || defined(__MK20DX256__) // Teensy 3.0 & 3.1
    17,452
    Re-run the Teensyduino installer, and in the step where optional libraries are installed, make sure you have Adafruit_Neopixel selected. The installer puts a copy for Teensy into the hardware/teensy/avr/libraries.
    My guess is you didn't install this, because the error from Arduino isn't telling you there's more than one copy of Adafruit_Neopixel.
    Ah, I was not aware it installed its own, removing the vanilla library from the library folder did the trick, thanks. Is there any way to load the modified library into platformio outside of loading it into the lib folder in the project?
    17,452
    I sent a pull request to Adafruit and it looks like they've merged it.
    Teensyduino's 1.39-beta2 will have the latest Adafruit_NeoPixel lib with Teensy 3.5 & 3.6 supported.
