cujomalainey
New member
I am trying to build a sketch I have used many times on multiple devices including the teensy 3.2 but it will not compile on the 3.5 (both through the arduino IDE and platformio.) It appears some framework defines for the board are missing.
Soucre code
Library used
Here is the output from teh arduino IDE
Soucre code
Library used
Arduino: 1.8.2 (Mac OS X), TD: 1.37, Board: "Teensy 3.5, Serial, 120 MHz, Faster, US English"
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp: In member function 'void Adafruit_NeoPixel::show()':
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1659:3: error: 'Pio' was not declared in this scope
Pio *port;
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1659:19: error: 'port' was not declared in this scope
Pio *port;
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1660:12: error: 'WoReg' does not name a type
volatile WoReg *portSet, *portClear, *timeValue, *timeReset;
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1663:29: error: 'pmc_set_writeprotect' was not declared in this scope
pmc_set_writeprotect(false);
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1664:35: error: 'TC3_IRQn' was not declared in this scope
pmc_enable_periph_clk((uint32_t)TC3_IRQn);
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1664:43: error: 'pmc_enable_periph_clk' was not declared in this scope
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1665:16: error: 'TC1' was not declared in this scope
TC_Configure(TC1, 0,
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:5: error: 'TC_CMR_WAVE' was not declared in this scope
TC_CMR_WAVE | TC_CMR_WAVSEL_UP | TC_CMR_TCCLKS_TIMER_CLOCK1);
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:19: error: 'TC_CMR_WAVSEL_UP' was not declared in this scope
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:38: error: 'TC_CMR_TCCLKS_TIMER_CLOCK1' was not declared in this scope
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1666:64: error: 'TC_Configure' was not declared in this scope
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1667:18: error: 'TC_Start' was not declared in this scope
TC_Start(TC1, 0);
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1669:15: error: 'g_APinDescription' was not declared in this scope
pinMask = g_APinDescription[pin].ulPin; // Don't 'optimize' these into
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1671:3: error: 'portSet' was not declared in this scope
portSet = &(port->PIO_SODR); // burn a few cycles after
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1672:3: error: 'portClear' was not declared in this scope
portClear = &(port->PIO_CODR); // starting timer to minimize
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1673:3: error: 'timeValue' was not declared in this scope
timeValue = &(TC1->TC_CHANNEL[0].TC_CV); // the initial 'while'.
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1674:3: error: 'timeReset' was not declared in this scope
timeReset = &(TC1->TC_CHANNEL[0].TC_CCR);
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1649:22: error: 'VARIANT_MCK' was not declared in this scope
#define SCALE VARIANT_MCK / 2UL / 1000000UL
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1651:36: note: in expansion of macro 'SCALE'
#define TIME_800_0 ((int)(0.40 * SCALE + 0.5) - (5 * INST))
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1683:14: note: in expansion of macro 'TIME_800_0'
time0 = TIME_800_0;
Multiple libraries were found for "Adafruit_NeoPixel.h"
Used: /Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel
Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Adafruit_NeoPixel
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1654:36: note: in expansion of macro 'SCALE'
#define TIME_400_0 ((int)(0.50 * SCALE + 0.5) - (5 * INST))
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1688:14: note: in expansion of macro 'TIME_400_0'
time0 = TIME_400_0;
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1698:18: error: 'TC_CCR_CLKEN' was not declared in this scope
*timeReset = TC_CCR_CLKEN | TC_CCR_SWTRG;
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1698:33: error: 'TC_CCR_SWTRG' was not declared in this scope
/Users/curtismalainey/Documents/Arduino/libraries/Adafruit_NeoPixel/Adafruit_NeoPixel.cpp:1708:17: error: 'TC_Stop' was not declared in this scope
TC_Stop(TC1, 0);
Error compiling for board Teensy 3.5.
