Page 3 of 8 FirstFirst 1 2 3 4 5 ... LastLast
Results 51 to 75 of 192
Thread: USB Host Mouse Driver
  1. #51
    These can't work without hard-coding for specific models, or a full HID report descriptor parser.
  2. #52
    20,821
    Can I buy this Wacom Bambo device on Amazon?
  3. #53
    20,821
    Quote Originally Posted by onliner View Post
    These can't work without ... a full HID report descriptor parser.
    A full HID report descriptor parser is *exactly* what we're doing.
    Edit: well, except so far "full" doesn't include seldom-used or not-really-necessary features: secondary level collections, physical units, physical min/max, global state push/pop, long format items, designators, strings and delimiters. And so far it's only for input. Output and maybe feature reports may be added later, but we're going to need to find more than just keyboard LEDs for testing...
  4. #54
    5,736
    I am not sure if they are still made? I see used ones up there:
    https://www.amazon.com/Wacom-CTH661-...com+bamboo+fun
    Looks like they have been probably replaced by some other versions. At least I see a few different other Bamboo versions and some other lines...
  5. #55
    5,736
    Paul,
    You might also simply look at plugging in a teensy configured as both Keyboard, Mouse and Joystick,
    I think I am seeing the same hang:
    USB Host Testing
    sizeof Device = 32
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    ISR: 408C
     Port Change
    port change: 10001803
        connect
    ISR: 1004088
     Timer0
      begin reset
    ISR: 408C
     Port Change
    port change: 10001805
      port enabled
    ISR: 1004080
     Timer0
      end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    new_Control_Transfer
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF5420    token=80000200
      Followup 1FFF5360    token=100
      Followup 1FFF53A0    token=8000
    enumeration:
      Followup 1FFF53E0    token=80280
      Followup 1FFF5420    token=80008180
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF53E0    token=80000200
      Followup 1FFF5420    token=8100
    enumeration:
      Followup 1FFF5360    token=80280
      Followup 1FFF2EC0    token=80120180
      Followup 1FFF53A0    token=80008080
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF5360    token=80000200
      Followup 1FFF2EC0    token=100
    enumeration:
      Followup 1FFF5420    token=80FC0180
      Followup 1FFF5360    token=80008080
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF5420    token=F80100
    enumeration:
      Followup 1FFF2EC0    token=80280
      Followup 1FFF53A0    token=80FC0180
      Followup 1FFF53E0    token=80008080
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF2EC0    token=80000200
      Followup 1FFF53A0    token=E40100
    enumeration:
      Followup 1FFF5420    token=80280
      Followup 1FFF5360    token=80FC0180
      Followup 1FFF2EC0    token=80008080
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF5360    token=CC0100
    enumeration:
      Followup 1FFF53A0    token=80280
      Followup 1FFF53E0    token=80FC0180
      Followup 1FFF5420    token=80008080
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF53A0    token=80000200
      Followup 1FFF53E0    token=EC0100
    enumeration:
      Followup 1FFF2EC0    token=80090180
    ISR: 4E081
     USB Async
    Async Followup
    enumeration:
    Config data length = 141
      Followup 1FFF5420    token=808D0180
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF5420    token=100
    enumeration:
    bNumInterfaces = 5
    bConfigurationValue = 1
      Followup 1FFF53E0    token=80008180
    ISR: 4E081
     USB Async
    Async Followup
      Followup 1FFF53E0    token=8100
    enumeration:
    USBHub memory usage = 1312
    USBHub claim_device this=1FFF2F00
    USBHub claim_device this=1FFF3420
    USBHub claim_device this=1FFF3940
    KeyboardController claim this=1FFF2020
    KeyboardController claim this=1FFF2220
    HIDParser claim this=1FFF3E80
    HIDParser claim this=1FFF4220
    HIDParser claim this=1FFF2420
    HIDParser claim this=1FFF27C0
    HIDParser claim this=1FFF2B60
    Descriptor 4 = INTERFACE
    ep = 83
    packet size = 8
    polling interval = 1
    new_Pipe
    allocate_interrupt_pipe_bandwidth
     best_bandwidth = 3
    , at offset = 0, shift= 0
    add_qh_to_periodic_schedule:
      interval = 1
      offset =   0
      add to slot 0
      add to slot 1
      add to slot 2
      add to slot 3
      add to slot 4
      add to slot 5
      add to slot 6
      add to slot 7
      add to slot 8
      add to slot 9
      add to slot 10
      add to slot 11
      add to slot 12
      add to slot 13
      add to slot 14
      add to slot 15
      add to slot 16
      add to slot 17
      add to slot 18
      add to slot 19
      add to slot 20
      add to slot 21
      add to slot 22
      add to slot 23
      add to slot 24
      add to slot 25
      add to slot 26
      add to slot 27
      add to slot 28
      add to slot 29
      add to slot 30
      add to slot 31
    Periodic Schedule:
     0: 1FFF2DA0
     1: 1FFF2DA0
     2: 1FFF2DA0
     3: 1FFF2DA0
     4: 1FFF2DA0
     5: 1FFF2DA0
     6: 1FFF2DA0
     7: 1FFF2DA0
     8: 1FFF2DA0
     9: 1FFF2DA0
    10: 1FFF2DA0
    11: 1FFF2DA0
    12: 1FFF2DA0
    13: 1FFF2DA0
    14: 1FFF2DA0
    15: 1FFF2DA0
    16: 1FFF2DA0
    17: 1FFF2DA0
    18: 1FFF2DA0
    19: 1FFF2DA0
    20: 1FFF2DA0
    21: 1FFF2DA0
    22: 1FFF2DA0
    23: 1FFF2DA0
    24: 1FFF2DA0
    25: 1FFF2DA0
    26: 1FFF2DA0
    27: 1FFF2DA0
    28: 1FFF2DA0
    29: 1FFF2DA0
    30: 1FFF2DA0
    31: 1FFF2DA0
    new_Data_Transfer
    Descriptor 33 = HID
    Descriptor 5 = ENDPOINT
     bInterfaceClass =    3
     bInterfaceSubClass = 0
     bInterfaceProtocol = 0
    report descriptor size = 84
    Single endpoint HID:
      endpoint = 85
       size = 8
       interval = 1
     *** before new pipe ***
    new_Pipe
     best_bandwidth = 5
    , at offset = 0, shift= 3
      interval = 1
      offset =   0
      traverse list 0
      traverse list 1
  6. #56
    20,821
    Yup, I've reproduced the problem with a Teensy LC.
    I guess we now have a pretty definitive answer to the question in the comment on line 1107.
            // TODO: does this really make an inverted tree like EHCI figure 4-18, page 93
    Working on a fix...
    FWIW, here's the code I put on the Teensy LC plugged into the Teensy 3.6 ref board.
    #include <Bounce.h>
    Bounce button2 = Bounce(15, 10);
    Bounce button3 = Bounce(16, 10);
    Bounce button4 = Bounce(17, 10);
    Bounce button5 = Bounce(18, 10);
      pinMode(15, INPUT_PULLUP);
      pinMode(16, INPUT_PULLUP);
      pinMode(17, INPUT_PULLUP);
      pinMode(18, INPUT_PULLUP);
      delay(1);
      button2.update();
      button3.update();
      button4.update();
      button5.update();
      if (button3.fallingEdge()) {
        Mouse.move(-1, 0); // move Left
      if (button2.fallingEdge()) {
        Mouse.move(1, 0);  // move Right
      if (button5.fallingEdge()) {
        Keyboard.press(KEY_B);
      if (button5.risingEdge()) {
        Keyboard.release(KEY_B);
      if (button4.fallingEdge()) {
        Keyboard.press(KEY_MEDIA_PLAY_PAUSE);
      if (button4.risingEdge()) {
        Keyboard.release(KEY_MEDIA_PLAY_PAUSE);
  7. #57
    20,821
    Yup, definitely a bug. It's sometimes creating looped lists instead of the inverted tree structure.
    I'm working on a fix, but it's not simple. This is one of the harder parts of USB host. Obviously my first attempt wasn't quite good enough...
  8. #58
    20,821
  9. #59
    5,736
    Looks like the Wacom table is now working
  10. #60
    20,821
    I'm working with the PS3 controller again. Fixed another bug, so at least Teensy isn't crashing or getting stuck. But the controller decides to play dead after 900 ms.
    Is there any more info about this mystery command?
    With PS3 - I believe I read that you also need to tell the PS3 to start sending Report 1 to get it to work...
    I think the command bytes is:
    static const uint8_t ps3_feature_F4_report[]  = {0x42, 0x0c, 0x00, 0x00};
    I tried a few different things like:
    	if ((dev->idVendor == 0x54c) && (dev->idProduct == 0x268)) {
    		println("*** Sony PS3");
    		mk_setup(setup, 0x21, 9, 0x3f4, 0, 4); // ps3 tell it to send report 1?
    		print_hexbytes((uint8_t*)&setup, 8);
    		queue_Control_Transfer(dev, &setup, (void*)ps3_feature_F4_report, this);
    But that appears to crash the USB, so probably wrong...
  11. #61
    5,736
    I will try looking again...
    Also wonder about looking also at the Usb_host_shield_2.0 code base: https://github.com/felis/USB_Host_Shield_2.0
    I do see they have PS3 modules
    Just updated to your checked in stuff. So you have a Joystick subclass I can start working with or should I pick it up from my other branch and adapt it to your HID parser?
  12. #62
    20,821
    I added the special PS3 command, and sure enough it does cause the controller to start sending HID input reports!
    https://github.com/PaulStoffregen/US...b95263cc6e3df9
    No, not yet. I'm working mostly with the verbose debug printing and watching USB packets with the Beagle protocol analyzer.
    I'll start one today, similar to the mouse. That ought to give a good starting point for hacking...
  13. #63
  14. #64
    5,736
    If I have time, if you don't beat me to it, will hack up my earlier one and test out the PS4, which worked fine earlier.
    If I am reading the code correctly, you are interpreting the HID descriptor with each packet that is received?
    So it will interesting to figure out with the Joystick, you probably want a couple of methods, like:
    Count of buttons and Count of Axes.
    Question will be on Query functions for the Axes, There appears to be some semi-standard ones and then some that are device specific...
    Again like ID of: 0x10030 is I believe X and...
    But then there was areas where they would have a use page: 0xff00 or something like that and a repeat count of 20 and then input variable... So you know there are something like 20 buttons defined... So question will be:
    Should the host code simply ask for the 15th axes and it get's it in whatever order they were defined in the report. If so probably want another query to say what is the ID for for #15. And/Or - should there be a query for X, Y,
    Side note: Wonder with Mouse if the method should be: getMouseX(), or maybe getX() or maybe just x()
    likewise getButtons, should simply be buttons()
  15. #65
    20,821
    Yes. That was part of my concern about speed. Others seem to parse the descriptor into something they can walk through more efficiently when the data arrives.
    Yeah, we should probably put some thought into a friendly & stable API before this gets into 1.40.
  16. #66
    5,736
    Hi Paul,
    I hacked up a Joystick class and saw that you had the PS3 reporting
    So I am getting output from it... Can Upload a version if you like, but my guess is you already have one.
    The PS4 controller was not working at all. Figured out report descriptor was not working fully.
    Mesg you print: report descriptor size = 483
    However you reserved 256 bytes for it. When i changed it to 512, started working
  17. #67
    20,821
    Here's a basic start on the joystick.
    https://github.com/PaulStoffregen/US...70f85f39c3a4f0
    I added to the Mouse example to print both.
    More work is still needed on scaling whatever logical min/max the device provides to a consistent 16 bit scale, so people can depend on the same range for any joystick.
  18. #68
    5,736
    Thanks,
    I synced up and the PS4 does not work as per the previous posting. Changed descriptor to 512 instead of 256 made it work.
    I tried a couple of hacks to see if you could make it work when the descriptor size > sizeof(descriptor). But did not work (yet).
    I modified line 75: if (descsize > sizeof(descriptor)) return false; // can't fit the report descriptor
    To instead set descsize = sizeof(descriptor)
    Also modified line 156 in ::control
    if (mesg == 0x22000681 && transfer->length == descsize) { // HID report descriptor
    To allow it to work if length was == descsize or sizeof(descriptor)...
    The code than called the parse code but did not show any data coming out... Probably parse did not like having it's data truncated in the middle of some levels of collection or the like.
    I also edited your version of Mouse.ino to output RX and RY as well:
      if (joystick1.available()) {
        Serial.print("Joystick: buttons = ");
        Serial.print(joystick1.getButtons(), HEX);
        Serial.print(", X = ");
        Serial.print(joystick1.getAxis(0));
        Serial.print(", Y = ");
        Serial.print(joystick1.getAxis(1));
        Serial.print(", RX = ");
        Serial.print(joystick1.getAxis(2));
        Serial.print(", RY = ");
        Serial.print(joystick1.getAxis(5));
        joystick1.joystickDataClear();
    Will play some more... Yes maybe having the code do mapping from physical min/max to logical min/max or the like makes sense.
    From posting #42, the DS4 HID descriptor beginning looks like:
    kurt@kurt-UP-CHT01:~$ sudo usbhid-dump  -i0 | grep -v : | xxd -r -p | hidrd-convert -o spec
    Usage Page (Desktop),               ; Generic desktop controls (01h)
    Usage (Gamepad),                    ; Gamepad (05h, application collection)
    Collection (Application),
        Report ID (1),
        Usage (X),                      ; X (30h, dynamic value)
        Usage (Y),                      ; Y (31h, dynamic value)
        Usage (Z),                      ; Z (32h, dynamic value)
        Usage (Rz),                     ; Rz (35h, dynamic value)
        Logical Minimum (0),
        Logical Maximum (255),
        Report Size (8),
        Report Count (4),
        Input (Variable),
        Usage (Hat Switch),             ; Hat switch (39h, dynamic value)
        Logical Maximum (7),
        Physical Minimum (0),
        Physical Maximum (315),
        Unit (Degrees),
        Report Size (4),
        Report Count (1),
        Input (Variable, Null State),
        Unit,
        Usage Page (Button),            ; Button (09h)
        Usage Minimum (01h),
        Usage Maximum (0Eh),
        Logical Maximum (1),
        Report Size (1),
        Report Count (14),
        Input (Variable),
        Usage Page (FF00h),             ; FF00h, vendor-defined
        Usage (20h),
        Report Size (6),
        Report Count (1),
        Logical Maximum (127),
        Input (Variable),
        Usage (Rx),                     ; Rx (33h, dynamic value)
        Usage (Ry),                     ; Ry (34h, dynamic value)
        Report Size (8),
        Report Count (2),
        Input (Variable),
        Usage (21h),
        Report Count (54),
        Input (Variable),
        Report ID (5),
    First thing I see is I labeled RX, RY wrong... Should be Z, Rz - Marked that section Red
    But the next interesting field is the HAT switch - On PS3 the 4 buttons above the left joystick I believe map as buttons, but on DS4 these are the HAT switch, which is 4 bit value and have a logical/physical settings...
    Then there is section for RX/RY... Not sure yet what on joystick controls these... Maybe the top touch pad? ... Will experiment.
    But looks like another nice looking day outside
  19. #69
    5,736
    Quick update:
    I pushed up a version of the code: https://github.com/KurtE/USBHost_t36...ystick-testing
    That increased HID report size to 512,
    Plus increased the Joystick Axes count to 10 for HAT 0x10039
    Updated Mouse test program to print out Z, Rz, Rx, Ry, Hat
    Wondering a few things:
    a) Should the class give some information, like the Report contains the different Desktop Axes or not... That is does my Joystick have the Rx axis?
    b) Probably should have some way to save maybe Vendor specific joystick axes values?
    c) Wondering about having something like IOCTL support? Again still learning about these controllers, but for example with the OLD PS2 controllers (on SPIish interface), There used to be command streams you could output to the device to say, for example I want pressure values for some of the controls. Example on both PS3/PS4 it feels like the L2/R2 buttons, should have the ability to say not just that the button is pressed, but how far... But how do you turn that on or off.
    d) As I see there are for example several reports that the DS4 can somehow generate at some point, again probably through the IOCTL like from c), may need/want when I receive a report from the device, which report it was... (Report ID).
  20. #70
    20,821
    Please send a pull request. I'm going to slow down on this for a few days to focus on another project.
    For now, a bigger buffer is fine. Long term, I'd like to do something similar to the (planned) addMemory for Serial & Wire. This is an object where people are likely to need several instances, so wasting space will add up.
  21. #71
    5,736
    Sounds good, I created a pull request. Will look into some of the other issues I mentioned...
  22. #72
    20,821
    Merged your pull request!
    How are you feeling about the performance of HID parsing this way, walking the report descriptor every time?
  23. #73
    10,101
    ... How are you feeling about the performance of HID parsing this way, walking the report descriptor every time?
    Are you considering making a static table of 'known' devices stored in flash table versus parsing on the fly on device arrival?
  24. #74
    Sep 2016
    3
    Awesome! There's a bunch of R2 Builders waiting patiently on the sidelines to test PS4 and PS3 Move controllers (these bad Larrys) from their trusty Teensy 3.6's.
  25. #75
    5,736
    @Paul - Speed - I am not sure, I have only used them to run test app... I may try some other tests soon...
    I probably won't get much done today, but will continue.
    With my Rabbit hole version - I only made one pass through and kept a set of details, like: bit start, bit count, type, ... for each field, that i used on each report, which probably was a bit quicker, but yours is more accurate. Like I special cased (hacked) for buttons, and for the most part combined count and size into one, so the button was one item of the number of buttons. Yours is more correct!
    I am thinking of trying a few more hacks (recovery), on your code, that maybe gets us back to 256 bytes should work in majority of cases. And maybe help do some speed ups...
    That is if we look at the linux hid dump.. for the DS4
        Report ID (1),
        Report Size (8),
        Report Count (4),
        Input (Variable),
        Unit (Degrees),
        Report Size (4),
        Report Count (1),
        Unit,
        Report Size (1),
        Report Count (14),
        Input (Variable),
        Usage (20h),
        Report Size (6),
        Report Count (1),
        Input (Variable),
        Report Size (8),
        Report Count (2),
        Input (Variable),
        Usage (21h),
        Report Count (54),
        Input (Variable),
        Report ID (5),
        Usage (22h),
        Report Count (31),
        Output (Variable),
        Report ID (4),
        Usage (23h),
        Report Count (36),
        Feature (Variable),
        Report ID (2),
        Usage (24h),
        Report Count (36),
        Feature (Variable),
        Report ID (8),
        Usage (25h),
        Report Count (3),
        Feature (Variable),
        Report ID (16),
        Usage (26h),
        Report Count (4),
        Feature (Variable),
        Report ID (17),
        Usage (27h),
        Report Count (2),
        Feature (Variable),
        Report ID (18),
        Usage Page (FF02h),             ; FF02h, vendor-defined
        Usage (21h),
        Report Count (15),
        Feature (Variable),
        Report ID (19),
        Usage (22h),
        Report Count (22),
        Feature (Variable),
        Report ID (20),
        Usage Page (FF05h),             ; FF05h, vendor-defined
        Usage (20h),
        Report Count (16),
        Feature (Variable),
        Report ID (21),
        Usage (21h),
        Report Count (44),
        Feature (Variable),
        Usage Page (FF80h),             ; FF80h, vendor-defined
        Report ID (128),
        Usage (20h),
        Report Count (6),
        Feature (Variable),
        Report ID (129),
        Usage (21h),
        Report Count (6),
        Feature (Variable),
        Report ID (130),
        Usage (22h),
        Report Count (5),
        Feature (Variable),
        Report ID (131),
        Usage (23h),
        Report Count (1),
        Feature (Variable),
        Report ID (132),
        Usage (24h),
        Report Count (4),
        Feature (Variable),
        Report ID (133),
        Usage (25h),
        Report Count (6),
        Feature (Variable),
        Report ID (134),
        Usage (26h),
        Report Count (6),
        Feature (Variable),
        Report ID (135),
        Usage (27h),
        Report Count (35),
        Feature (Variable),
        Report ID (136),
        Usage (28h),
        Report Count (34),
        Feature (Variable),
        Report ID (137),
        Usage (29h),
        Report Count (2),
        Feature (Variable),
        Report ID (144),
        Usage (30h),
        Report Count (5),
        Feature (Variable),
        Report ID (145),
        Usage (31h),
        Report Count (3),
        Feature (Variable),
        Report ID (146),
        Usage (32h),
        Report Count (3),
        Feature (Variable),
        Report ID (147),
        Usage (33h),
        Report Count (12),
        Feature (Variable),
        Report ID (160),
        Usage (40h),
        Report Count (6),
        Feature (Variable),
        Report ID (161),
        Usage (41h),
        Report Count (1),
        Feature (Variable),
        Report ID (162),
        Usage (42h),
        Report Count (1),
        Feature (Variable),
        Report ID (163),
        Usage (43h),
        Report Count (48),
        Feature (Variable),
        Report ID (164),
        Usage (44h),
        Report Count (13),
        Feature (Variable),
        Report ID (165),
        Usage (45h),
        Report Count (21),
        Feature (Variable),
        Report ID (166),
        Usage (46h),
        Report Count (21),
        Feature (Variable),
        Report ID (240),
        Usage (47h),
        Report Count (63),
        Feature (Variable),
        Report ID (241),
        Usage (48h),
        Report Count (63),
        Feature (Variable),
        Report ID (242),
        Usage (49h),
        Report Count (15),
        Feature (Variable),
        Report ID (167),
        Usage (4Ah),
        Report Count (1),
        Feature (Variable),
        Report ID (168),
        Usage (4Bh),
        Report Count (1),
        Feature (Variable),
        Report ID (169),
        Usage (4Ch),
        Report Count (8),
        Feature (Variable),
        Report ID (170),
        Usage (4Eh),
        Report Count (1),
        Feature (Variable),
        Report ID (171),
        Usage (4Fh),
        Report Count (57),
        Feature (Variable),
        Report ID (172),
        Usage (50h),
        Report Count (57),
        Feature (Variable),
        Report ID (173),
        Usage (51h),
        Report Count (11),
        Feature (Variable),
        Report ID (174),
        Usage (52h),
        Report Count (1),
        Feature (Variable),
        Report ID (175),
        Usage (53h),
        Report Count (2),
        Feature (Variable),
        Report ID (176),
        Usage (54h),
        Report Count (63),
        Feature (Variable),
        Report ID (177),
        Usage (55h),
        Report Count (2),
        Feature (Variable),
        Report ID (178),
        Usage (56h),
        Report Count (2),
        Feature (Variable),
    End Collection
    That once we work through the bytes that I marked in RED, the rest does not actually do anything for our Report (id #1). So maybe cache the last Report ID that we processed and the last byte needed for the information, and as soon as we get there, bail out and issue the hid_input_end() call. This would also be
    used in the I only read 256 bytes out of the 450+ hid descriptor... WIll assume if I got to the end of the data for the descriptor, to say we are done and do the call back...
    Current code output on DS4
    Joystick: buttons = 0, X = 125, Y = 129, Z = 129, Rz = 129, Rx = 0, Ry = 0, Hat = 8
    Joystick: buttons = 0, X = 125, Y = 129, Z = 130, Rz = 129, Rx = 0, Ry = 0, Hat = 8
    Joystick: buttons = 0, X = 125, Y = 129, Z = 129, Rz = 128, Rx = 0, Ry = 0, Hat = 8
    Appears to be working fine The buttons show all of the buttons, except the 4 associated with "Hat" which the value 8 is no buttons pressed... Not sure if we should map these from logical to physical... X,Y - Left joystick. Z, Rz - right joystick, Rx, Ry - Left and right trigger (L2, R2)
    DS3 controller: Currently looks like only left joystick and buttons is working. Need to investigate.
    Note: to self/Paul - Probably Hid controller needs to inform Joystick/Mouse code that previous device was disconnected... Actually I think the User code should be able to see the state of being connected or not. I had this in my Rabbit Hole - May merge in.
    @defragster:
    I was thinking of something like this before I went down the Rabbit hole. That is have a table by Vendor ID/Product ID - Maps to table of offset, size, type values for each of the fields, but that probably would be pretty limited and then at best maybe guessing for those other PIDs that are not in table. That is there may be 50? logitech mice over the years? ...
    Note: - I do think we probably need to have method to query more device info like PID/VID - The user code may want to detect that the are running on DS3 or DS4 and change their mapping of what button does what...
    Now back to playing with DS3
    Edit:
    Linux info for PS3 controller
    Usage (Joystik),                    ; Joystik (04h, application collection)
        Collection (Logical),
            Report ID (1),
            Report Size (8),
            Report Count (1),
            Input (Constant, Variable),
            Report Size (1),
            Report Count (19),
            Physical Maximum (1),
            Usage Maximum (13h),
            Input (Variable),
            Report Size (1),
            Report Count (13),
            Usage (Pointer),            ; Pointer (01h, physical collection)
            Collection (Physical),
                Report Size (8),
                Report Count (4),
                Physical Maximum (255),
                Input (Variable),
            End Collection,
            Report Size (8),
            Report Count (39),
            Input (Variable),
            Report Size (8),
            Report Count (48),
            Output (Variable),
            Report Size (8),
            Report Count (48),
            Feature (Variable),
        End Collection,
            Report ID (2),
            Report Size (8),
            Report Count (48),
            Feature (Variable),
        End Collection,
            Report ID (238),
            Report Size (8),
            Report Count (48),
            Feature (Variable),
        End Collection,
            Report ID (239),
            Report Size (8),
            Report Count (48),
            Feature (Variable),
        End Collection,
    End Collection
    Looks like data is correct... also looked like data is changing in reports. So will see what we are called with... Actually sort of interesting. I printed out bytes received, plus the callback with data...
    HID:  1  0  0  0  0  0 80 7c a7 ff  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  2 ee 12 ff c8  0  0 12 ae 77  0 40  2  e  2 19  1 96  0  5  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    Joystick: usage=90001, value=0
    Joystick: usage=90002, value=0
    Joystick: usage=90003, value=0
    Joystick: usage=90004, value=0
    Joystick: usage=90005, value=0
    Joystick: usage=90006, value=0
    Joystick: usage=90007, value=0
    Joystick: usage=90008, value=0
    Joystick: usage=90009, value=0
    Joystick: usage=9000A, value=0
    Joystick: usage=9000B, value=0
    Joystick: usage=9000C, value=0
    Joystick: usage=9000D, value=0
    Joystick: usage=9000E, value=0
    Joystick: usage=9000F, value=0
    Joystick: usage=90010, value=0
    Joystick: usage=90011, value=0
    Joystick: usage=90012, value=0
    Joystick: usage=90013, value=0
    Joystick: usage=10030, value=128
    Joystick: usage=10031, value=124
    Joystick: usage=10032, value=167
    Joystick: usage=10035, value=255
    Joystick: usage=10001, value=0
    Joystick: usage=10000, value=0
    Joystick: usage=10032, value=0
    Joystick: usage=10035, value=0
    Joystick: usage=10000, value=2
    Joystick: usage=10000, value=238
    Joystick: usage=10000, value=18
    Joystick: usage=10000, value=255
    Joystick: usage=10000, value=200
    Joystick: usage=10000, value=174
    Joystick: usage=10000, value=119
    Joystick: usage=10000, value=64
    Joystick: usage=10000, value=14
    Joystick: usage=10000, value=150
    Joystick: usage=10000, value=5
    Joystick: buttons = 0, X = 128, Y = 124, Z = 0, Rz = 0, Rx = 0, Ry = 0, Hat = 0
    HID:  1  0  0  0  0  0 80 7c a7 ff  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0  2 ee 12 ff c8  0  0 12 ae 77  0 40  2  d  2 19  1 95  0  5  0  0  0  0  0  0  0  0  0  0  0  0  0  0  0
    Looks like it gets the data But the data gets overwritten...
