BristolGarry
New member
Hi Folks - My son and I are planning on launching a High Altitude Balloon for the upcoming eclipse on the 21st. I just today received a Teensy 3.2 (we discovered that the sketch we are using is too big for an Arduino Pro Trinket), and I am now having some troubles compiling. To begin with, I am now getting a "'Serial1' does not name a type" error, which causes cascading errors. I know that there are differences between Arduino and Teensyduino, but am stumped as to where exactly I need to make changes. The code I am currently using is included below, and I am sure is full of other errors. Right now I want to fix the Serial1 error, and will gladly take any help I can get.
<code>
#include <Arduino.h>
#include <TinyGPS.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2591.h>
#include <Adafruit_MCP9808.h>
#include <stdio.h>
#define GPS_RX 8
#define GPS_TX 7
#define LED_PIN 13
#define CHIP_SELECT 10
#define DEBUG
#define SD_MISSING_ERR 2
#define FILE_CREATION_ERR 3
#define MAX_BUFFER_SIZE 320 //120 for gps, 5 for light sensor (+ comma), 4 for temp
#define HWSERIAL Serial1
TinyGPS gps;
const byte max_light_buffer_size = sizeof(uint32_t) * 4 + 1;
const byte max_temp_buffer_size = 17;
char dataBuffer [121 + max_light_buffer_size + max_temp_buffer_size];
HWSERIAL mySerial = Serial1 (GPS_RX, GPS_TX);
TinyGPS GPS (&mySerial);
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591);
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
File logfile;
void initGPS();
void initTSL2591();
void initMCP9808();
//Light sensor functions
void tsl2591UnifiedRead(boolean);
//Read light sensor using raw values rather than unified sensor
void tsl2591SimpleRead();
void tsl2591AdvancedRead();
//Specification of light sensor
void tsl2591GetSensorSpecs();
void mcp9808Read(boolean);
void error();
//define init parameters
pinMode( LED_PIN, OUTPUT );
pinMode( 10, OUTPUT );
//Serial.println(F("Starting...."));
HWSERIAL.begin(9600);
if ( !SD.begin( CHIP_SELECT ) ) {
//Serial.println( F( "Card init. failed!" ) );
error( SD_MISSING_ERR );
char filename[15]; //15 bytes
strcpy(filename, "GPSLOG00.txt");
for (uint8_t i = 0; i < 100; i++) {
filename[6] = '0' + i/10;
filename[7] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
logfile = SD.open(filename, FILE_WRITE);
if (!logfile) {
//Serial.print(F("couldn't create "));
//Serial.println(filename);
error(FILE_CREATION_ERR);
//Serial.print(F("Writing to "));
initGPS();
initTSL2591();
initMCP9808();
const unsigned short waitTime = 0;
if (GPS.newNMEAreceived()) {
char *stringptr = GPS.lastNMEA();
if (!GPS.parse(stringptr)) return;
int reading = analogRead(sensorPin);
word voltage = reading * aref_voltage;
word millivolts = (voltage/1024.0) *1000.0;
// now print out the temperature
float temperatureC = ((millivolts - 424) / 6.25L) ; //converting from 6.25 mv per degree with 424 mV offset
//to degrees ((voltage - 424mV) times 100)
strcpy(stringptr, dataBuffer);
tsl2591UnifiedRead(true);
mcp9808Read(true);
// Rad. lets log it!
//Serial.println(F("Logging"));
uint8_t stringsize = strlen(dataBuffer); //4 bytes
//if (stringsize != logfile.write((uint8_t *)stringptr, stringsize)) error(4);
//if (strstr(stringptr, "RMC") || strstr(stringptr, "GGA")) logfile.flush();
logfile.println(dataBuffer);
strcpy(dataBuffer, "");
delay(waitTime);
void error( uint8_t errno ) {
while (1) {
uint8_t i;
for ( i=0;i < errno;i++ ) {
digitalWrite( LED_PIN, HIGH );
delay( 100 );
digitalWrite( LED_PIN, LOW );
delay( 100 );
for ( i=errno; i<10; i++ ) {
delay( 200 );
void initGPS() {
GPS.begin( 9600 );
GPS.sendCommand( PMTK_SET_NMEA_OUTPUT_RMCGGA );
GPS.sendCommand( PMTK_SET_NMEA_UPDATE_5HZ );
GPS.sendCommand( PGCMD_NOANTENNA );
void initTSL2591() {
//Serial.println(F("Starting Adafruit TSL2591"));
if (tsl.begin()) {
//Serial.println(F("Found a TSL2591 sensor"));
else {
//Serial.println(F("No sensor found ... check your wiring?"));
while(1);
// You can change the gain on the fly, to adapt to brighter/dimmer light situations
//tsl.setGain(TSL2591_GAIN_LOW); // 1x gain (bright light)
tsl.setGain(TSL2591_GAIN_MED); // 25x gain
// tsl.setGain(TSL2591_GAIN_HIGH); // 428x gain
// Changing the integration time gives you a longer time over which to sense light
// longer timelines are slower, but are good in very low light situtations!
tsl.setTiming(TSL2591_INTEGRATIONTIME_100MS); // shortest integration time (bright light)
// tsl.setTiming(TSL2591_INTEGRATIONTIME_200MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_300MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_400MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_500MS);
// tsl.setTiming(TSL2591_INTEGRATIONTIME_600MS); // longest integration time (dim light)
tsl2591Gain_t gain = tsl.getGain();
switch(gain)
case TSL2591_GAIN_LOW:
//Serial.println(F("1x (Low)"));
case TSL2591_GAIN_MED:
//Serial.println(F("25x (Medium)"));
case TSL2591_GAIN_HIGH:
//Serial.println(F("428x (High)"));
case TSL2591_GAIN_MAX:
//Serial.println(F("9876x (Max)"));
void initMCP9808() {
//Serial.println(F("MCP9808 demo"));
if (!tempsensor.begin()) {
//Serial.println(F("Couldn't find MCP9808"));
while (1);
//recommended reader for tsl2591
void tsl2591UnifiedRead(boolean log) {
sensors_event_t event;
tsl.getEvent( &event );
if ((event.light == 0) |
(event.light > 4294966000.0) |
(event.light <-4294966000.0))
/* If event.light = 0 lux the sensor is probably saturated */
/* and no reliable data could be generated! */
/* if event.light is +/- 4294967040 there was a float over/underflow */
// Serial.println("Invalid data (adjust gain or timing)");
//Serial.print(event.light); Serial.println(" lux");
if (log) {
int error = sprintf(dataBuffer, "%u %c", event.light, ',');
//if (error < 0) Serial.println(F("buffer error"));
void tsl2591SimpleRead() {
// Simple data read example. Just read the infrared, fullspecrtrum diode
// or 'visible' (difference between the two) channels.
// This can take 100-600 milliseconds! Uncomment whichever of the following you want to read
uint16_t x = tsl.getLuminosity(TSL2591_VISIBLE);
//uint16_t x = tsl.getLuminosity(TSL2591_FULLSPECTRUM);
//uint16_t x = tsl.getLuminosity(TSL2591_INFRARED);
/*Serial.print(F("[ ")); Serial.print(millis()); Serial.print(F(" ms ] "));
Serial.print(F("Luminosity: "));
Serial.println(x, DEC);
void tsl2591AdvancedRead() {
uint32_t lum = tsl.getFullLuminosity();
uint16_t ir, full;
ir = lum >> 16;
full = lum & 0xFFFF;
/* Serial.print("[ "); Serial.print(millis()); Serial.print(" ms ] ");
Serial.print("IR: "); Serial.print(ir); Serial.print(" ");
Serial.print("Full: "); Serial.print(full); Serial.print(" ");
Serial.print("Visible: "); Serial.print(full - ir); Serial.print(" ");
Serial.print("Lux: "); Serial.println(tsl.calculateLux(full, ir)); */
void mcp9808Read(boolean log) {
float c = tempsensor.readTempC();
if (log) {
int error = sprintf(dataBuffer, "%.3f %c", c, "C");
// if (error < 0) Serial.println(F("buffer error"));
/*Serial.print("Temp: "); Serial.print(c); Serial.print("*C\t");
Serial.print(f); Serial.println("*F");*/
</code>
I am happy to post the error code(s) if needed.
<code>
#include <stdio.h>
#define GPS_RX 8
#define GPS_TX 7
#define LED_PIN 13
#define DEBUG
TinyGPS gps;
File logfile;
void initGPS();
void initTSL2591();
void initMCP9808();
void error();
if (!logfile) {
initGPS();
initTSL2591();
initMCP9808();
mcp9808Read(true);
delay(waitTime);
while (1) {
uint8_t i;
delay( 100 );
delay( 100 );
delay( 200 );
void initGPS() {
GPS.begin( 9600 );
if (tsl.begin()) {
else {
while(1);
switch(gain)
while (1);
if (log) {
uint16_t ir, full;
ir = lum >> 16;
if (log) {
</code>
