I'm creating a clock for my daughter that has a 60 Neopixel ring AND a SSD1306 OLED display. I am using a Teensy 3.2 and a prop shield to level shift and buffer the neopixels.
I've been noticing that I cannot seem to get the SSD1306 to work AND the strip of neopixels. I am using the adafruit driver for the SSD1306, and FastLED for the strip. Both are using SPI pins so I suspect some sort of conflict but I can't see anything amiss. I've tried swapping FastLED with the adafruit drivers to no avail.
Can anyone offer any ideas? I'm pretty sure all libraries involved are using SPI transactions which I would have thought would avoid this problem.
The only thing vaguely nonstandard about this setup is I have the neopixels voltage on a STMPS2171STR high side switch but I have confirmed this doesn't seem to affect the behavior when removed or bypassed. (The rationale for this switch is to facilitate a low-power shutdown mode.)
In the following example, the LEDs animate but the display goes dark after the splash screen comes on initially.
#include <Adafruit_NeoPixel.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define PIN_LED_ENABLE 7
#define PIN_MEM_CS 6
#define PIN_AMP_ENABLE 5
#define PIN_LED_DATA 11
#define PIN_LED_VOLTAGE_SWITCH 3
#define OLED_DC 9
#define OLED_CS 10
#define OLED_RESET 8
#define NUM_LEDS 60
Adafruit_SSD1306 display(OLED_DC, OLED_RESET, OLED_CS);
#include <FastLED.h>
// This is an array of leds. One item for each led in your strip.
CRGB leds[60];
pinMode( PIN_LED_ENABLE, OUTPUT );
digitalWrite( PIN_LED_ENABLE, LOW );
pinMode( PIN_MEM_CS, OUTPUT );
digitalWrite( PIN_MEM_CS, LOW );
pinMode( PIN_AMP_ENABLE, OUTPUT );
digitalWrite( PIN_AMP_ENABLE, LOW );
pinMode( PIN_LED_VOLTAGE_SWITCH, OUTPUT );
digitalWrite( PIN_LED_VOLTAGE_SWITCH, HIGH );
display.begin(SSD1306_SWITCHCAPVCC);
display.display();
delay(2000);
display.clearDisplay();
// Adafruit SSD1306 and FastLED don't seem to cooperate
// This is a sterling example why you'd need makernet
// Another reason is that hte prop sheild has also sorts of special pins
// that you'd have to read all of the docs to understand
// otherwise you'd get a shit ton of unexplained behavior
FastLED.addLeds<WS2811, PIN_LED_DATA, RGB>(leds, 60);
FastLED.setBrightness( 50 );
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0, 0);
display.println("Hello, world!");
display.println( millis() );
display.display();
digitalWrite( PIN_LED_ENABLE, HIGH );
// Move a single white led
for (int n = 0; n < NUM_LEDS; n++) {
leds[n] = CRGB::White;
FastLED.show();
delay(8);
// leds[n] = CRGB::Black;
FastLED.show();
delay(8);
