Results 1 to 7 of 7
Thread: Teensyduino 1.38 Beta #3
    Administrator Paul's Avatar
    Oct 2012
    338
    Here is a third beta test for Teensyduino 1.38.
    Changes since Teensyduino 1.38-beta2:
    Support for Arduino 1.8.4
    fix for disable of SD on Teensy 3.5 & 3.6 (Frank)
    SPI.transfer(readbuf, writebuf, size) (KurtE)
    Added TeensyThreads library (Fernando Trias)
    Fixed Adafruit_CC3000 on Teensy 3.x
    Audio envelope graceful handling of noteone while gain > 0
    Improved FreqMeasureMulti countToNanoseconds
    [Experimental] EventResponder
    [Experimental] MillisTimer
    [Experimental] SPI async using DMA & EventResponder (KurtE)
    4,116
    Hi Paul. Installed beta3 no problem. However, there is a conflict between the TeensyThreads Library and EventResponder which I mentioned in another thread with Kurt. All I am running is the tests.ino from the TeensyThreads library. Here is the exact error:
    C:\Users\CYBERP~1\AppData\Local\Temp\arduino_build_778242/..\arduino_cache_517125\core\core_teensy_avr_teensy35_usb_serial,speed_120,opt_o2std,keys_en-us_bbc7c6806654ab36443e271befb1ac3c.a(EventResponder.cpp.o): In function `systick_isr':
    C:\Local Programs\arduino-1.8.3-c14\hardware\teensy\avr\cores\teensy3/EventResponder.cpp:326: multiple definition of `systick_isr'
    C:\Users\CYBERP~1\AppData\Local\Temp\arduino_build_778242\libraries\TeensyThreads\TeensyThreads.cpp.o:C:\Users\CyberPalin\Documents\Arduino\libraries\TeensyThreads/TeensyThreads.cpp:196: first defined here
    c:/local programs/arduino-1.8.3-c14/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
    Multiple libraries were found for "TeensyThreads.h"
     Used: C:\Users\CyberPalin\Documents\Arduino\libraries\TeensyThreads
     Not used: C:\Local Programs\arduino-1.8.3-c14\hardware\teensy\avr\libraries\TeensyThreads
    Error compiling for board Teensy 3.5.
    Will let you know if there are any other conflicts.
    Mike
    4,116
    EDIT: here is the post: https://forum.pjrc.com/threads/44723...l=1#post150899
    EDIT2: Using Arduino 1.8.3.
    20,591
    Please give this a try. If it works, I'll send a pull request....
    Attached Files Attached Files
    5,430
    Wonder why they decided they needed a new release already? Nothing looked earth shattering in the release notes.
    Now that teens threads is in the build, maybe it is time to really try it out
    But probably topic for another thread!
    Yes both EventResponder's MillisTimer and the thread code use the systick_isr... The thread code is a lot more involved including it is written in Assembly language.
    4,116
    That fixed it. Now compiles and runs no issues.
    Ran another sketch I use for my rover that uses the following libraries and besides a few warning messages from the adafruit libraries it compiles fine:
    #include <EEPROM.h>
    #include <StopWatch.h>
    #include <elapsedMillis.h>
    #include <Streaming.h>
    #include <PWMServo.h>
    #include <vector>
    #include <string.h>
    #include <FastLED.h>
    #include <Adafruit_MotorShield.h>
    #include "utility/Adafruit_MS_PWMServoDriver.h"
    #include <Adafruit_Sensor.h>
    #include <Adafruit_TSL2561_U.h>
    #include <Adafruit_BNO055.h>
    #include <utility/imumaths.h>
    #include <VL53L0X.h>
    Will run a few more tests with my other crazy sketches and will let you know, but I don't see any issues coming up.
    Mike
    EDIT: By the way am using IDE 1.8.4 now.
    20,591
    I submitted a pull request.
    https://github.com/ftrias/TeensyThreads/pull/4
    This fixes the compile error. But TeensyThreads will prevent MillisTimer from running. That probably needs to be fixed by a special higher priority thread or some other mechanism within TeensyThreads to call MillisTimer::runFromTimer() just after each systick interrupt.
