Results 1 to 5 of 5
Thread: teensyduino -> USB Type: Keyboard + serial
    Oct 2016
    5
    Currently I can select:
    - Keyboard
    - Serial + Keyboard + Mouse + Joystick
    I would like only "Serial + Keyboard".
    Is this somehow possible? Eventually bypassing teensyduino ide?
    Thanks,
    Karel.
    2,728
    Quote Originally Posted by karelv View Post
    - Keyboard
    Thanks,
    Karel.
    Yes it is possible, but since you asked, I fear it may be a little bit too demanding.
    So stick with the two add ons (Mouse + Joystick) they cost you nothing with respect to performance
    If you really wanted to try, have a look into usb_desc.(h/c) and usb_def.(h/c) in cores/teensy3
    Last edited by WMXZ; 08-23-2017 at 07:36 PM. Reason: corrected usb_def to usb_desc
    22,539
    Yes, you can create custom combinations, but you need to edit usb_desc.h. See the comments in that file for instructions.
    Oct 2016
    5
    Thanks for info.
    I will definitely try it out.
    I have tried the keyboard message default example with the 4 types active, as WMXZ suggested, but my laptop's touchpad has not 'button' function anymore.
    Probably it is due to mouse or joystick...
    And of course I will share my results here ...
    Senior Member Jp3141's Avatar
    485
    Can someone please post an example of how to do this ?
    I'm confused over the number of endpoints I need; where the unique number is for each interface (is it 'PRODUCT_ID') ? Is DEVICE_CLASS necessary ?
    Also, I'm running on MacOS Catalina and changes I make to usb_desc.h don't show up in the Tools..USB Type menu. (Edit -- it seems I also have to edit boards.txt). If I edit these files, won't they get overwritten the next time I update Teensyduino ? Can I replace usb_desc.h in my project directory ? or the new pieces of it in my .ino file ?
    I just want a USB type that has Serial + Keyboard (a simple keyboard; media keys not necessary).
    I want my application to work as a USB keyboard in an iPhone, (and also have a serial port, although that's not for the iPhone) but the iPhone seems to complain about the joystick also included in the USB device.
