// *(c) Chris O 2018/4 - License: MIT
// * U-Blox UBX-CFG-TP5 (0x06 0x31) Quick configuration editor - ILI9341 TFT + Touch interface
// * v1.1
// * Permission is hereby granted, free of charge, to any person obtaining
// * a copy of this software and associated documentation files (the
// * "Software"), to deal in the Software without restriction, including
// * without limitation the rights to use, copy, modify, merge, publish,
// * distribute, sublicense, and/or sell copies of the Software, and to
// * permit persons to whom the Software is furnished to do so, subject to
// * the following conditions:
// * 1. The above copyright notice and this permission notice shall be
// * included in all copies or substantial portions of the Software.
// * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
// * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
// * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
// * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
// * BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
// * ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
// * CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
// * SOFTWARE.
// * UBLOX GPS - Important set this to the GPS hardware serial port
#include "UBLOX.h" // Update #4 U-BLOX lib v1.0.3 https://forum.pjrc.com/threads/36103-uBlox-Library/page2
// Set this to the GPS hardware serial port you wish to use
#define GPShwSERIAL 3 // 1 = Serial1, 2 = Serial2, 3 = Serial3, 4 = Serial4 ....
// * RUN TFT Touch Calibration
// comment or uncomment me.
#define TFTCalibration // calibrate the touch screen.
uint32_t const BaudDefault = 9600; // default settings
// a uBlox object, which is on Teensy hardware
// GPS serial port
UBLOX gps(GPShwSERIAL);
// the uBlox data structure
gpsData uBloxData;
// * TFT
#include <Wire.h> // this is needed even tho we aren't using it
#include <ILI9341_t3.h>
#include <XPT2046_Touchscreen.h>
//#include <Adafruit_STMPE610.h>
// Rotations 1 or 3 = Landscape mode only ~ 1->TFT conn. pins on right side : 3->TFT conn. pins on left side
const int rotation = 3; //(1 or 3 only)
const int TouchRotation = 1; //(1 or 3 only)
// This is calibration data for the raw touch data to the screen coordinates
int TS_MINX = 367;
int TS_MINY = 226;
int TS_MAXX = 3920;
int TS_MAXY = 3809;
// https://www.pjrc.com/store/display_ili9341_touch.html
// Connections For optimized ILI9341_t3 library + XPT2046 Touch library
// ILI9341 Pin | - Teensy 3.x - | - Notes -
// VCC | VIN | Power: 3.6 to 5.5 volts
// GND | GND |
// CS | 20 | Alternate Pins: 9, 10, 15, 20, 21
// RESET | +3.3V | Optional; #define TFT_RST 255, = unused, connect to 3.3V
// D/C | 15 | Alternate Pins: 9, 10, 15, 20, 21
// SDI (MOSI)|(DOUT~MOSI) 11 | Alternate Pin: 7 [SPI.setMOSI(7); - Use befor tft.begin()]
// SCK (SCK0)| (SCK0) 13 | Alternate Pin: 14 [SPI.setSCK(14); - Use befor tft.begin()]
// LED | VIN | Use 100 ohm resistor, TFT dependent I'm not using any.
// SDO (MISO)| (DIN~MISO) 12 | Alternate Pin: 8 [SPI.setMISO(8); - Use befor tft.begin()]
// T_CLK (SCK0)| (SCK0) 13 | Alternate Pin: 14 [SPI.setSCK(14); - Use befor tft.begin()]
// T_CS | 16 | Alternate: can use any digital pin e.g. 6
// T_DIN (MOSI)|(DOUT~MOSI) 11 | Alternate Pin: 7 [SPI.setMOSI(7); - Use befor tft.begin()]
// T_DO (MISO)| (DIN~MISO) 12 | Alternate Pin: 8 [SPI.setMISO(8); - Use befor tft.begin()]
// T_IRQ | NOT IN USE | Optional: can use any digital pin
#define TOUCH_CS 16 // 8
//Adafruit_STMPE610 ts = Adafruit_STMPE610(TOUCH_CS);
XPT2046_Touchscreen ts(TOUCH_CS);
// For optimized ILI9341_t3 library
#define TFT_DC 15
#define TFT_CS 20
#define TFT_RST 255 // 255 = unused, connect to 3.3V
#define TFT_MOSI 11
#define TFT_SCLK 13
#define TFT_MISO 12
ILI9341_t3 tft = ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCLK, TFT_MISO);
#include "font_Arial.h"
int t_x; // Retrieve point x
int t_y; // Retrieve point y
int Tx = 0;
int Ty = 0;
byte touch_event_detected = 0;
#define MINPRESSURE 5 // 10
#define MAXPRESSURE 3000 // this was 1000
// Slider value editor
uint32_t xFreq = 1; // Hz, Maps the values
uint32_t xAnt = 50; // ns
float xDuty = 50.0000; // %
float xR = 29; // Slider
// The elapsedMillis feature is built into Teensyduino.
// For non-Teensy boards, it is available as a library.
elapsedMillis BLINK;
uint8_t Toggle = 1; // Toggle
uint8_t Select = 22; // 22 ant ,39 freq, 55 duty
// * Setup()
void setup(void) {
tft.begin();
tft.setRotation(rotation); // TFT Rotation 0~3
tft.setTextColor(ILI9341_WHITE);
tft.setFont(Arial_16);
byte i = 0;
while (!Serial && millis() < 5000) { // wait for Arduino Serial Monitor
if (i >= 240) {
i = 255;
tft.fillRect(250, 5, 42, 18, ILI9341_BLACK);
tft.setCursor(250, 5);
tft.print((5000.0 - (float)millis()) / 1000.0, 1);
tft.print(" sec");
// BackLight
if (i <= 254) {
i += 10;
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
Serial.println("U-Blox UBX-CFG-TP5 (0x06 0x31), TFT + Touch interface");
Serial.println("Touchscreen started");
#ifdef TFTCalibration
//int Tx = 0;
//int Ty = 0;
bool EXIT = true;
unsigned long y = 10000;
tft.setFont(Arial_9);
tft.drawRoundRect(250, 140, 70, 40, 3, ILI9341_ORANGE);
tft.setCursor(273, 155);
tft.print("EXIT");
tft.drawRoundRect(250, 200, 70, 40, 3, ILI9341_ORANGE);
tft.setCursor(273, 208);
tft.print("RUN");
tft.setCursor(255, 222);
tft.print("Calibration");
tft.setCursor(2, 2);
tft.print("Click on screen to draw Pixel");
while (millis() < y) { // wait for
tft.print((y - (float)millis()) / 1000.0, 1);
tft.print(" sec");
delay(10);
TS_Point p = ts.getPoint();
if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
// Retrieve a point
Tx = p.x;
Ty = p.y;
if (rotation == 3) { // 3
t_y = map(Ty, TS_MINY, TS_MAXY, 0, tft.height());
t_x = map(Tx, TS_MINX, TS_MAXX, 0, tft.width());
} else { // 1
t_y = map(Ty, TS_MINY, TS_MAXY, tft.height(), 0);
t_x = map(Tx, TS_MAXX, TS_MINX, 0, tft.width());
Touchrot();
tft.drawPixel(t_x, t_y, ILI9341_BLUE);
// EXIT
if (t_x > 250 && t_x < 320 && t_y > 140 && t_y < 180) {
y = 0;
EXIT = true;
delay(300);
if (t_x > 250 && t_x < 320 && t_y > 200 && t_y < 240) {
y = 0;
EXIT = false;
delay(300);
if (EXIT == false) {
TS_MINX = 450;
TS_MINY = 450;
TS_MAXX = 3700;
TS_MAXY = 3700;
TFTCali(); // Run TFT Touch Calibration
ResetScreen();
// * UBLOX GPS setup
// serial to display data
Serial.begin(9600); // Teensy Serial object always communicates at 12 Mbit/sec USB speed.
// -- AutoBauding test -- experimental baud rate 1500000
// Try communication with the GPS receiver at 9600 baud, default settings
// then set GPS UART Baud to 1500000
gps.begin(BaudDefault); // Enable Teensy serial communication @ 9600 baud, default settings.
gps.SetGPSbaud(1500000, false); // Set GPS Port Baud, Possible Baud Rate Configurations 4800~9600~19200~38400~57600~115200~230400~460800-921600
gps.end(); // Disables Teensy serial communication, to re-enable serial communication, call gps.begin(Baud, bool);.
gps.begin(19200);
gps.end();
gps.begin(38400);
gps.end();
gps.begin(57600);
gps.end();
gps.begin(115200);
gps.end();
gps.begin(230400);
gps.end();
gps.begin(460800);
gps.end();
gps.begin(921600);
gps.SetGPSbaud(1500000, true);
gps.end();
// now start communication with the GPS
// receiver at 1500000 baud,
gps.begin(1500000); // Enable Teensy serial communication @ given baud rate
// -- AutoBauding test -- baud rate 921600
// then set GPS UART Baud to 921600
gps.SetGPSbaud(921600, false);
gps.end();
gps.begin(19200);
gps.end();
gps.begin(38400);
gps.end();
gps.begin(57600);
gps.end();
gps.begin(115200);
gps.end();
gps.begin(230400);
gps.end();
gps.begin(460800);
gps.end();
gps.begin(921600);
gps.end();
gps.begin(1500000);
gps.SetGPSbaud(921600, true);
gps.end();
// receiver at 921600 baud,
gps.begin(921600); // Enable Teensy serial communication @ given baud rate
if (gps.read(&uBloxData) ) {} // reading data clears the hw serial port.
gps.SetRATE(1000, false); // Navigation/Measurement Rate Settings, e.g. 100ms => 10Hz, 200 => 5.00Hz, 1000ms => 1Hz, 10000ms => 0.1Hz
// Possible Configurations:
// 60=>16.67Hz, 64=>15.63Hz, 72=>13.89Hz, 80=>12.50Hz, 100=>10.00Hz, 125=>8.00Hz, 200=>5.00Hz, 250=>4.00Hz, 500=>2.00Hz
// 800=>1.25Hz, 1000=>1.00Hz, 2000=>0.50Hz, 4000=>0.25Hz, 10000=>0.10Hz, 20000=>0.05Hz, 50000=>0.02Hz
// NOTE: Dis_all_NMEA -strongly suggest changing RX buffer to 255 or more,*otherwise you will miss ACKs*on serial monitor
gps.Dis_all_NMEA_Child_MSGs(false); // Disable All NMEA Child Messages Command
gps.SetNAV5(3, false); // Set Dynamic platform model Navigation Engine Settings (0:portable, 2: stationary, 3:pedestrian, Etc)
// 0: portable, 2: stationary, 3: pedestrian, 4: automotive, 5: sea, 6: airborne with <1g, 7: airborne with <2g
// 8: airborne with <4g, 9: wrist worn watch (not supported in protocol v.less than 18)
// ### Periodic auto update ON,OFF Command ###
gps.Ena_NAV_PVT(false); // Enable periodic auto update NAV_PVT
//gps.Dis_NAV_PVT(false); // Disable periodic auto update NAV_PVT
//gps.Ena_NAV_ATT(true); // Enable periodic auto update NAV_ATT ~ U-blox M8 from protocol version 19
//gps.Dis_NAV_ATT(false); // Disable periodic auto update NAV_ATT ~ ---^
//gps.Ena_NAV_POSLLH(true); // Enable periodic auto update NAV_POSLLH
//gps.Dis_NAV_POSLLH(false); // Disable periodic auto update NAV_POSLLH
gps.Ena_Dis_MON_IO(true, false); // Ena/Dis periodic auto update I/O Subsystem Status, bytes(received, sent), parity errors, framing errors, overrun errors)
gps.Poll_MON_IO(false); // Polls UBX-MON-IO (0x0A 0x02) I/O Subsystem Status
gps.Poll_MON_VER(false); // Polls UBX-MON-VER (0x0A 0x04) Receiver/Software Version
// A UBlox GPS Module Primer for beginners https://forum.pjrc.com/threads/46058-A-UBlox-GPS-Module-Primer-for-beginners
gps.SetCFG_TP5(1, 50.0000, 50, true); // UBX-CFG-TP5 (0x06 0x31) - Set Time Pulse 0 Parameters.
// (1Hz,50%,ant50ns,print usb)
// SetCFG_TP5(FreqLocked- 1Hz ~ 24000000Hz, DutyLocked- 0.000000% ~ 100.000000%, antCableDelay- 0~32767ns, print usb ACK- true or false);
gps.Poll_CFG_TP5(false); // Polls CFG-TP5 (0x06 0x31) Poll Time Pulse 0 Parameters
// * Loop()
if (BLINK > 500) {
BLINK = 0; // reset since
Toggle = ! Toggle;
if (Toggle == 0) {
tft.setFont(Arial_12);
tft.setTextColor(ILI9341_YELLOW);
tft.setCursor(10, Select); //
tft.print(">");
tft.setFont(Arial_11); // Arial, Arial
if (Select == 22) {
tft.setCursor(85, 100); // 22
tft.print("Ant");
} else if (Select == 39) {
tft.setCursor(85, 115); // 22
tft.print("Freq");
} else if (Select == 55) {
tft.setCursor(85, 130); // 22
tft.print("Duty");
tft.setTextColor(ILI9341_BLACK);
tft.print(">");
tft.print("Ant");
tft.print("Freq");
tft.print("Duty");
// * UBLOX GPS read
//numSV
tft.setTextColor(ILI9341_CYAN);
tft.setCursor(265, 6);
tft.fillRect(297 , 6 , 18, 10, ILI9341_BLACK);
tft.print("#SV: ");
tft.print(uBloxData.numSV);
tft.setCursor(263, 20);
tft.print("Fix Type:");
tft.setCursor(263, 35);
tft.fillRect(263 , 35 , 55, 10, ILI9341_BLACK);
//fixType;///< [ND], GNSSfix Type: 0: no fix, 1: dead reckoning only, 2: 2D-fix, 3: 3D-fix, 4: GNSS + dead reckoning combined, 5: time only fix
switch (uBloxData.fixType) { // fixType
case 0: // 0: no-fix
tft.setTextColor(ILI9341_RED);
tft.print(" NO-fix");
case 1: // 1: dead reckoning only
tft.print("dead rec");
case 2: // 2: 2D-fix
tft.setTextColor(ILI9341_BLUE);
tft.print(" 2D-fix");
case 3: // 3: 3D-fix
tft.setTextColor(ILI9341_GREEN);
tft.print(" 3D-fix");
case 4: // 4: GNSS + dead reckoning combined
tft.print("GNSS+d");
case 5: // 5: time only fix
tft.print("Time only");
default:
// Not Supported
tft.print("Not Sup:"), tft.print(uBloxData.fixType);
//tft.setTextSize(2);
tft.fillRect(185 , 23 , 60, 11, ILI9341_BLACK);
tft.setCursor(25, 23);
tft.print("Ant Cable Delay");
tft.setCursor(163, 23);
tft.print(" ns: ");
tft.print(uBloxData.antCableDelay); // antCableDelay
tft.fillRect(185 , 40 , 75, 11, ILI9341_BLACK);
tft.setCursor(25, 40);
tft.print("Freq Locked");
tft.setCursor(161, 40);
tft.print(" Hz: ");
tft.println(uBloxData.freqPeriodL); // freqPeriodL
// CurrentfreqPeriodL = uBloxData.freqPeriodL; //TODO REMOVE?
tft.fillRect(181 , 58 , 68, 11, ILI9341_BLACK);
tft.setCursor(25, 58);
tft.print("Duty Cycle Locked");
tft.setCursor(165, 58);
tft.print(" %: ");
tft.print(uBloxData.dutycycleL, 4); // duty cycle%
//tft.setTextSize(0);
tft.setFont(Arial_8);
tft.setCursor(0, 200);
tft.print("I/O Subsystem Status");
tft.setCursor(0, 210);
tft.fillRect(47 , 210 , 70, 8, ILI9341_BLACK);
tft.print("RX Bytes: "), tft.print(uBloxData.rxBytes); ///< [B], Number of bytes ever received
tft.setCursor(0, 220);
tft.fillRect(45 , 220 , 70, 8, ILI9341_BLACK);
tft.print("TX Bytes: "), tft.print(uBloxData.txBytes); ///< [B], Number of bytes ever sent
tft.setCursor(0, 230);
tft.fillRect(66 , 230 , 70, 8, ILI9341_BLACK);
tft.print("Overrun Errs: "), tft.print(uBloxData.overrunErrs); ///< [ms], Number of 100ms timeslots with overrun errors
tft.setCursor(90, 158);
tft.fillRect(180 , 158 , 30, 8, 0x31C7);
tft.print("UBlox SW Version: "), tft.print(uBloxData.swVersion); ///< Software Version
tft.setCursor(140, 168);
tft.fillRect(165 , 168 , 50, 8, 0x31C7);
tft.print("Rev# "), tft.print(uBloxData.revVersion); ///< Rev#
tft.setCursor(121, 178);
tft.fillRect(180 , 178 , 16, 8, 0x31C7);
tft.print("HW Version: "), tft.print(uBloxData.hwVersion); ///< Hardware Version, 7 = u-blox 7
tft.setCursor(121, 188);
tft.fillRect(164 , 188 , 32, 8, 0x31C7);
tft.print("Protocol: "), tft.print(uBloxData.extension1); ///< Protocol version, e.g. 14.00
tft.drawRoundRect(180, 200, 120, 40, 6, ILI9341_CYAN); // SEND BTN
tft.setFont(Arial_20);
tft.setCursor(208, 210);
tft.print("SEND");
ScreenUpdate ();
// * TFT
// See if there's any touch data for us
TouchData();
if (touch_event_detected == 1) {
// SEND BUTTON
if (t_x > 180 && t_x < 300 && t_y > 200 && t_y < 240) {
tft.drawRoundRect(180, 200, 120, 40, 6, ILI9341_BLUE);
tft.print("SEND");
gps.SetCFG_TP5(xFreq, xDuty, xAnt, true); // UBX-CFG-TP5 (0x06 0x31) - Set Time Pulse 0 Parameters.
gps.Poll_CFG_TP5(true); // Polls CFG-TP5 (0x06 0x31) - Poll Time Pulse 0 Parameters
// Select cur. ant, freq, duty
byte temp = Select; // clear
if (t_x > 0 && t_x < 320 && t_y > 20 && t_y < 34) {
Select = 22; // y = 22
tft.drawRoundRect(20, 21, 140, 17, 3, ILI9341_ORANGE);
tft.drawRoundRect(20, 38, 140, 17, 3, ILI9341_BLACK);
tft.drawRoundRect(20, 56, 140, 17, 3, ILI9341_BLACK);
if (t_x > 0 && t_x < 320 && t_y > 40 && t_y < 50) {
Select = 39;
tft.drawRoundRect(20, 38, 140, 17, 3, ILI9341_ORANGE);
tft.drawRoundRect(20, 21, 140, 17, 3, ILI9341_BLACK);
if (t_x > 0 && t_x < 320 && t_y > 60 && t_y < 70) {
Select = 55;
tft.drawRoundRect(20, 56, 140, 17, 3, ILI9341_ORANGE);
tft.setTextColor(ILI9341_BLACK); // clear old
tft.setCursor(10, temp);
tft.print(">");
void ScreenUpdate () {
if (Select == 22) { // Ant
xR = modifiedMap(xAnt, 0, 32767, 29, 285); // 0~32767, default 50ns
// Draws the positioners
tft.fillRoundRect(29, 80, xR - 28 , 15, 1, ILI9341_BLUE);
tft.fillRoundRect(xR + 2 , 80, 285 - xR , 15, 1, ILI9341_BLACK);
tft.fillRoundRect(xR - 1, 80, 4, 15, 3, ILI9341_RED);
// Draws the positioner outside box
tft.drawRoundRect(28, 79, 285 - 25, 17, 1, ILI9341_GREEN);
tft.drawRoundRect(27, 78, 285 - 25, 19, 3, ILI9341_CYAN);
} // Ant
tft.setCursor(125, 100);
if (xAnt == uBloxData.antCableDelay) {
// print the new value in the slider bar
tft.fillRect(125, 100, 100, 12, ILI9341_BLACK); // Clear
tft.print(xAnt);
if (Select == 39) { // Freq
xR = modifiedMap(xFreq, 1, 24000000, 29, 285); // 1Hz ~ 24000000Hz
} // Freq
tft.setCursor(125, 115);
if (xFreq == uBloxData.freqPeriodL) {
tft.fillRect(125, 115, 100, 12, ILI9341_BLACK); // Clear
tft.print(xFreq);
if (Select == 55) { // Duty
xR = map(xDuty, 0 , 100, 29, 285);
} // Duty
tft.setCursor(125, 130);
if (xDuty == uBloxData.dutycycleL) {
tft.fillRect(125, 130, 100, 12, ILI9341_BLACK); // Clear
tft.print(xDuty, 4);
void ResetScreen () {
tft.fillRoundRect(5, 1, 256, 73, 3, 0x1000); // 0x52AA
tft.setCursor(6, 6);
tft.print("UBX-CFG-TP5 Current Time Pulse Configuration");
// Select = 22; // y = 22
//http://www.barth-dev.de/online/rgb565-color-picker/
//COLOR GRAY 0x52AA
//DK GRY 0x31C7
//DK BLUE 0x006F
tft.fillRoundRect(0, 75, 320, 123, 5, 0x31C7); // frame around slider and black rear axle msg. box
tft.drawRoundRect(0, 75, 320, 124, 5, ILI9341_GREEN); //
tft.fillRoundRect(20, 76, 274, 52, 5, ILI9341_BLACK); // frame around slider and - + bottons
tft.fillRoundRect(20, 125, 64, 72, 5, ILI9341_BLACK); // blue side
tft.fillRoundRect(230, 125, 64, 72, 5, ILI9341_BLACK); // red side
tft.fillRoundRect(81, 98, 152, 60, 5, ILI9341_GREEN); // red side
tft.fillRoundRect(82, 99, 150, 58, 5, ILI9341_BLACK); // red side
tft.fillRoundRect(83, 100, 35, 56, 5, 0x31C7); // red side
tft.drawRoundRect(0, 0, 320, 75, 5, ILI9341_YELLOW); //
tft.drawRoundRect(28, 97, 51, 29, 5, ILI9341_BLUE); // - botton
tft.setCursor( 50, 105);
tft.print("-");
tft.drawRoundRect(284 - 48, 97, 53, 29, 5, ILI9341_RED); // + botton
tft.setCursor(284 - 28, 105);
tft.print("+");
tft.drawRoundRect(28, 130, 51, 29, 5, ILI9341_BLUE); // - botton
tft.setCursor( 30, 137);
tft.print("-500");
tft.drawRoundRect(284 - 48, 130, 53, 29, 5, ILI9341_RED); // + botton
tft.setCursor(284 - 48, 137);
tft.print("+500");
tft.drawRoundRect(28, 165, 51, 29, 5, ILI9341_BLUE); // - botton
tft.setCursor( 30, 173);
tft.setFont(Arial_13);
tft.print("-5000");
tft.drawRoundRect(284 - 48, 165, 53, 29, 5, ILI9341_RED); // + botton
tft.setCursor(284 - 48, 173);
tft.print("+5000");
Draw_Slider(); // Draw Slider
void TouchData()
touch_event_detected = 0; // reset flag
if (ts.touched())
// Retrieve a point
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
// Wait for end of the touch event before continuing
while (ts.touched()) { //
Touchrot();
// drawPixel
// if ((t_x) && ((t_y) < tft.height())) {
// tft.drawPixel(t_x, t_y, currentcolor);
if (gps.read(&uBloxData)) {
// Area of the slider
if ( (t_y >= 80) && (t_y <= 95)) {
xR = t_x; // Stores the X value where the screen has been pressed in to variable xR
if (xR <= 29) { // Confines the area of the slider to be above 38 pixels
xR = 29;
if (xR >= 285) { /// Confines the area of the slider to be under 310 pixels
xR = 285;
xAnt = modifiedMap(xR, 29, 285, 0, 32767); // 0~32767
tft.print(xAnt);
} // Ant
xFreq = modifiedMap(xR, 29, 285, 1, 24000000);
tft.print(xFreq);
} // Freq
//xDuty = modifiedMap(xR, 29, 285, (0 - 0.125), (100 - 0.125)); // 100% 4294967295
xDuty = map(xR, 29, 285, 0 , 100); // 100% 4294967295
} // while
touch_event_detected = 1; // reset flag
Touchrot();
touch_event_detected = 1; // set flag
void Draw_Slider() { // Slider
if (Select == 22) { // antCableDelay, 0~32767, default 50ns
// If we press the [-] Button
if ((t_x >= 28) && (t_x <= 78) && (t_y >= 97) && (t_y <= 126)) {
xAnt = xAnt - 1;
// If we press the [+] Button
if ((t_x >= 284 - 48) && (t_x <= 286) && (t_y >= 97) && (t_y <= 126)) {
xAnt = xAnt + 1;
// If we press the [-]500 Button
if ((t_x >= 28) && (t_x <= 78) && (t_y >= 140) && (t_y <= 165)) {
if (xAnt < 502) {
xAnt = 1;
xAnt = xAnt - 500;
// If we press the [+]500 Button
if ((t_x >= 284 - 48) && (t_x <= 286) && (t_y >= 140) && (t_y <= 165)) {
xAnt = xAnt + 500;
// If we press the [-]5000 Button
if ((t_x >= 28) && (t_x <= 78) && (t_y >= 170) && (t_y <= 190)) {
if (xAnt < 5002) {
xAnt = 1;
xAnt = xAnt - 5000;
// If we press the [+]5000 Button
if ((t_x >= 284 - 48) && (t_x <= 286) && (t_y >= 170) && (t_y <= 190)) {
xAnt = xAnt + 5000;
if (xAnt == 0) {
xAnt = 0;
xR = modifiedMap(xAnt, 0, 32767, 29, 285); // Confines for the draw slider
} else if (xAnt >= 32767) {
xAnt = 32767;
// curr Ant
tft.print(xAnt);
if (Select == 39) { // freqPeriodLock, 24000000Hz ~ 1Hz
xFreq = xFreq - 1;
xFreq = xFreq + 1;
if (xFreq < 502) {
xFreq = 1;
xFreq = xFreq - 500;
xFreq = xFreq + 500;
if (xFreq < 5002) {
xFreq = 1;
xFreq = xFreq - 5000;
xFreq = xFreq + 5000;
if (xFreq == 0) {
xFreq = 1;
xR = modifiedMap(xFreq, 1, 24000000, 29, 285); // Confines for the draw slider
} else if (xFreq >= 24000000) {
xFreq = 24000000;
// curr Freq
tft.print(xFreq);
if (Select == 55) { // Duty, 100% 4294967295
if (xDuty < 0.0001) {
xDuty = 0;
xDuty = xDuty - 0.0001;
xDuty = xDuty + 0.0001;
if (xDuty < 0.5) {
xDuty = 0;
xDuty = xDuty - 0.0500;
xDuty = xDuty + 0.0500;
if (xDuty < 0.5001) {
xDuty = 0;
xDuty = xDuty - 0.5000;
xDuty = xDuty + 0.5000;
if (xDuty <= 0) {
xDuty = 0;
xR = modifiedMap(xDuty, 0 , 100, 29, 285); // Confines for the draw slider //(xDuty, (0 - 0.125), (100 - 0.125), 29, 285);
} else if (xDuty >= 100) {
xDuty = 100;
// curr Duty
// * Modified Map
// * ARDUINO "map" function have problems with large numbers, rolling my own "Modified Map"
double modifiedMap(double x, double in_min, double in_max, double out_min, double out_max)
double temp = (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
temp = (double) (4 * temp + .5);
return (double) temp / 4;
// * TFT Touch Calibration ()
// * based on http://cyaninfinite.com/tutorials/2-8-tft-lcd-touchscreen-shield/
void TFTCali ()
byte count = 0;
bool tft_y = false;
Serial.println("TFT Calibration");
//Splash
tft.setCursor(30, (tft.height() / 2) - 20);
tft.setFont(Arial_18);
tft.println("TFT Calibration v1.1");
tft.setCursor(30, tft.height() / 2 + 10);
tft.print("Screen size:");
tft.print(tft.width());
tft.print("x");
tft.println(tft.height());
tft.setCursor(30, (tft.height() / 2) + 30);
tft.println("Test wil begin in 2s...");
delay(2000);
//TFT Calibration
tft.setFont(Arial_14);
tft.println("TFT Calibration");
tft.setCursor(30, (tft.height() / 2));
tft.print("Click on screen to begin...");
tft_y = true;
while (count < 5) {
// Retrieve a point
Tx = 0;
Ty = 0;
if (tft_y == true) {
delay(200);
Tx = p.x;
Ty = p.y;
Touchrot();
switch (count) {
case 0:
tft.fillRect(30, (tft.height() / 2), 180, (tft.height() / 2) + 10, ILI9341_BLACK);
tft.print("Press the dots on the corners of the screen.");
//drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color);
tft.setCursor(tft.width() / 2, 10);
tft.print(count);
tft.fillCircle(0, 0, 16, ILI9341_YELLOW);
getMinMax(Tx, Ty);
count++;
case 1:
tft.fillCircle(tft.width(), 0, 16, ILI9341_YELLOW);
tft.fillRect(tft.width() / 2, 10, 10, 10, ILI9341_BLACK);
tft.print(count);
getMinMax(Tx, Ty);
count++;
case 2:
tft.fillCircle(tft.width(), tft.height(), 16, ILI9341_YELLOW);
tft.print(count);
getMinMax(Tx, Ty);
count++;
case 3:
tft.fillCircle(0, tft.height(), 16, ILI9341_YELLOW);
tft.print(count);
getMinMax(Tx, Ty);
count++;
case 4:
tft.print(count);
tft.fillRect(30, (tft.height() / 2), 300, (tft.height() / 2) + 10, ILI9341_BLACK);
tft.setCursor(30, tft.height() / 2);
tft.print("Calibration completed!");
tft.setCursor(30, (tft.height() / 2) + 20);
tft.print("TS_MINX:");
tft.print(TS_MINX);
tft.setCursor(130, (tft.height() / 2) + 20);
tft.print("TS_MINY:");
tft.print(TS_MINY);
tft.setCursor(30, (tft.height() / 2) + 40);
tft.print("TS_MAXX:");
tft.print(TS_MAXX);
tft.setCursor(130, (tft.height() / 2) + 40);
tft.print("TS_MAXY:");
tft.print(TS_MAXY);
tft.setCursor(30, (tft.height() / 2) + 75);
tft.setTextColor(ILI9341_OLIVE);
tft.print("Press Try Again or Exit...");
tft.setCursor(30, (tft.height() / 2) + 60);
tft.drawRoundRect(270, 200, 50, 40, 3, ILI9341_ORANGE);
tft.setCursor(285, 208);
tft.print("Try");
tft.setCursor(278, 222);
tft.print("Again");
tft.drawRoundRect(270, 140, 50, 40, 3, ILI9341_ORANGE);
tft.setCursor(283, 155);
tft.print("EXIT");
tft_y = false;
delay(200);
//tft.setRotation(0);
Tx = p.x;
Ty = p.y;
tft.fillRect(52, 50, 30, 10, ILI9341_BLACK);
tft.setCursor(30, 50);
tft.print("X = "); tft.print(Tx);
tft.fillRect(52, 65, 30, 10, ILI9341_BLACK);
tft.setCursor(30, 65);
tft.print("Y = "); tft.print(Ty);
tft.fillRect(97, 82, 30, 10, ILI9341_BLACK);
tft.setCursor(30, 82);
tft.print("Pressure = "); tft.println(p.z);
Touchrot();
tft.fillRect(132, 50, 25, 10, ILI9341_BLACK);
tft.setCursor(100, 50);
tft.print("t_x = "); tft.print(t_x);
tft.fillRect(132, 65, 25, 10, ILI9341_BLACK);
tft.setCursor(100, 65);
tft.print("t_y = "); tft.print(t_y);
tft.print(TS_MINX);
tft.print(TS_MINY);
tft.print(TS_MAXX);
tft.print(TS_MAXY);
// EXIT
if (t_x > 270 && t_x < 320 && t_y > 140 && t_y < 180) {
count = 5; // exit while()
delay(300);
// Try Again
if (t_x > 270 && t_x < 320 && t_y > 200 && t_y < 240) { // tft 320 x 240
tft_y = true;
count = 0; // reset
//tft.setFont(Arial_9);
TS_MINX = 450;
TS_MINY = 450;
TS_MAXX = 3600;
TS_MAXY = 3600;
delay(300);
void getMinMax(int Tx, int Ty) {
if (Tx < TS_MINX) {
TS_MINX = Tx;
if (Ty < TS_MINY) {
TS_MINY = Ty;
if (Tx > TS_MAXX) {
TS_MAXX = Tx;
if (Ty > TS_MAXY) {
TS_MAXY = Ty;
void Touchrot() {
Tx = p.x;
Ty = p.y;
if (TouchRotation == 3) { // 3
} else { // 1
//Serial.print("X = "); Serial.print(Tx);
//Serial.print(" Y = "); Serial.print(Ty);
//Serial.print(" Pressure = "); Serial.println(p.z);
