Results 1 to 10 of 10
Thread: Teensyduino 1.38 Released
    Administrator Paul's Avatar
    Oct 2012
    294
    Teensyduino 1.38 has been released.
    These changes were made after the last beta:
    Symbol table and disassembly listing are placed in temp build folder
    Fix audio memory usage stats when more than 255 blocks allocated
    Fix USB audio transmit with null data
    Audio library support for external delay with CY15B104 (FrankB)
    I'm having trouble with the Raspberry Pi used to build for Linux ARM. Looking for Raspberry Pi feedback...
    Aug 2017
    4
    A customer (I'm a Teensy reseller) reported this error with Teensyduino 1.38 and Arduino 1.8.4 when trying to upload the Blink example to a Teensy LC https://pastebin.com/6xL8meDC
    Tried it myself and got the same error.
    843
    Blink build failure
    It looks like this commit is responsible:
    https://github.com/PaulStoffregen/co...dee782e2747e71
    Since Teensy LC has a shared interrupt for the PIT channels, it should probably be wrapped in a '#ifdef KINETISK'.
    17,596
    Opps, that's embarrassing! Looks like 1.39 might be coming later today....
    Aug 2017
    1
    Having the same issues with Teensyduino 1.38 but with Arduino 1.8.1 and 1.8.3.
    3,534
    @Paul - I have been running into some interesting types of errors, not sure if related to latest Arduino or latest Teensyduino...
    That is sometimes when I do a build (not sure if only verify or also with upload).
    The build will complete, but then fail at the end like:
    Arduino: 1.8.4 (Windows 10), TD: 1.38, Board: "Teensy 3.6, Serial, 180 MHz, Faster, US English"
    d:\arduino-1.8.4\hardware\tools\arm\bin\../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin/ar.exe: unable to rename 'C:\Users\kurte\AppData\Local\Temp\arduino_build_229766/core/core.a'; reason: File exists
    Multiple libraries were found for "USBHost_t36.h"
     Used: C:\Users\kurte\Documents\Arduino\libraries\USBHost_t36
     Not used: D:\arduino-1.8.4\hardware\teensy\avr\libraries\USBHost_t36
    Using library USBHost_t36 at version 0.1 in folder: C:\Users\kurte\Documents\Arduino\libraries\USBHost_t36
    Error compiling for board Teensy 3.6.
    And if I try to build again, it gets even stranger errors:
    Linking everything together...
    "D:\arduino-1.8.4\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O2 -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1503989929 "-TD:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/mk66fx1m0.ld" -lstdc++  -mthumb -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsingle-precision-constant -o "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766/xxx.ino.elf" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\sketch\xxx.ino.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\ehci.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\enumeration.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\hub.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\keyboard.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\memory.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\midi.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\mouse.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\print.cpp.o" "C:\Users\kurte\AppData\Local\Temp\arduino_build_229766/core\core.a" "-LC:\Users\kurte\AppData\Local\Temp\arduino_build_229766" -larm_cortexM4lf_math -lm
    C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\ehci.cpp.o: In function `usb_serial_class::write(unsigned char const*, unsigned int)':
    D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/usb_serial.h:95: undefined reference to `usb_serial_write'
    C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\ehci.cpp.o: In function `Print::print(unsigned long)':
    D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:68: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
    C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\ehci.cpp.o: In function `Print::print(unsigned long, int)':
    D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:74: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
    D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/Print.h:70: undefined reference to `Print::printNumber(unsigned long, unsigned char, unsigned char)'
    C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\print.cpp.o: In function `usb_serial_class::write(unsigned char)':
    D:\arduino-1.8.4\hardware\teensy\avr\cores\teensy3/usb_serial.h:94: undefined reference to `usb_serial_putchar'
    C:\Users\kurte\AppData\Local\Temp\arduino_build_229766\libraries\USBHost_t36\print.cpp.o: In function `USBHost::print_hexbytes(void const*, unsigned long)':
    C:\Users\kurte\Documents\Arduino\libraries\USBHost_t36/print.cpp:184: undefined reference to `Serial'
    C:\Users\kurte\Documents\Arduino\libraries\USBHost_t36/print.cpp:184: undefined reference to `Print::println()'
    Note: there were lots and lots of the same errors.... Edited down so not so big!
    I exited Arduino IDE, cleaned out the temp folder of Arduino build and cache... Tried again and it failed like first one... File existed...
    So I then reran the install for the last Beta install and then tried building code again and it worked... Will try reinstalling latest released again (tried this yesterday and it worked).
    But maybe it was also due to using the integration of TyCommander...
    Germany NRW
    4,438
    Used: C:\Users\kurte\Documents\Arduino\libraries\USBHost _t36
    Is this the right one ? ;-)
    3,534
    Yep,
    That is the version I am currently editing to handle Mice better. It is grabbing the HID descriptor data, parsing it to know where fields are and their sizes... And now starting to use that information.
    Still WIP - https://github.com/KurtE/USBHost_t36...se-Rabbit-Hole
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    127
    Hello, i found that
    the DMASPI library doesn't compile well with newer arduino/teensy loader , with T3.5/3.6 and I guessevery setting.
    the library was from
    i tried 1.81/1.82/1.83/1.84 with 1.37/1.38 teensyloader
    the empty sketch with "#include <DmaSpi.h>"
    gets error like below
    In file included from C:\Users\PoTing\Documents\Arduino\sketch_aug31a\sketch_aug31a.ino:1:0:
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:48: error: 'SPI1Class' was not declared in this scope
     class DmaSpi1 : public AbstractDmaSpi<DmaSpi1, SPI1Class, SPI1>
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:63: error: template argument 2 is invalid
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:575:63: note: invalid template non-type parameter
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::begin_setup_txChannel_impl()':
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:580:16: error: 'txChannel_' was not declared in this scope
         txChannel_()->disable();
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::begin_setup_rxChannel_impl()':
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:588:16: error: 'rxChannel_' was not declared in this scope
         rxChannel_()->disable();
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:592:35: error: 'rxIsr_' was not declared in this scope
         rxChannel_()->attachInterrupt(rxIsr_);
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h: In static member function 'static void DmaSpi1::post_cs_impl()':
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:604:16: error: 'rxChannel_' was not declared in this scope
         rxChannel_()->enable();
    G:\arduino-1.8.4\libraries\DmaSpi/DmaSpi.h:605:16: error: 'txChannel_' was not declared in this scope
         txChannel_()->enable();
    my last success of using the DMASPI library is with Arduino1.80 and Teensy 1.34
    3,534
    Yes - With the last few releases of Teensyduino, the SPI class is one class with multiple instances instead of different classes.
    I had it working a long time on my machine and forgot to push a Pull request...
    https://github.com/crteensy/DmaSpi/pull/23
    Note: What I had on my machine had a second example which is copy of first but set for SPI1... Not necessary. but...
    You can see the version with changes up at: https://github.com/kurte/DmaSpi/tree/SPI-One-Class
