PIXY SPI Reader for Teensy 3.5 and 3.6
Written By: randomvibe
Date: 9/7/2017
Main Functions:
pixy_spi_read_16bit ~ Reads PIXY data via SPI connection using Teensy 3.5/3.6 SPI functions
pixy_parse_data ~ Parses SPI data stream and saves to array of PIXY struct
// Teensy 3.5/3.6 SPI Pins
#define MOSIX 11
#define SCKX 13
#define MISOX 12
SPISettings PIXYSPI(1000000, MSBFIRST, SPI_MODE0);
// Pixy Parameters
#define PIXY_SPI_CS 15 // SPI Chip Select
#define PIXY_SPI_TRY 24
#define PIXY_SYNC_BYTE_DATA 0x5b // Sync with Pixy Device
#define PIXY_START_WORD 0xaa55 // Start word in Pixy Data Block
#define PIXY_START_WORD_CC 0xaa56 // Stard word in Pixy Data Block with Color Codes
#define PIXY_MAX_BLOCKS 10 // Max No. of detectable blocks
// PIXY data block struct array
typedef struct
uint16_t obj = 0; // Object type: Normal (0xaa55), Color Code (0xaa56)
uint16_t sig = 0; // Signature Number
uint16_t x = 0; // x center of object
uint16_t y = 0; // y center of object
uint16_t wd = 0; // width of object
uint16_t ht = 0; // height of object
int16_t phi = 0; // angle of object (applies to Color-Code objects only)
} PIXY;
uint16_t pixy_spi_read_16bit(uint16_t target, SPISettings SETX, uint8_t CSX)
uint8_t a, b;
uint16_t c;
// Read First Byte
SPI.beginTransaction(SETX);
digitalWrite(CSX,LOW);
a = SPI.transfer(target);
SPI.endTransaction();
// Read Second Byte
b = SPI.transfer(0x00);
digitalWrite(CSX,HIGH);
// Build Pixy 16-bit Word
c = (uint16_t)(b | (a<<8));
return c;
uint16_t pixy_parse_data( uint16_t target, SPISettings SETX, uint8_t CSX, PIXY *pixy)
int ii, jj;
uint16_t word1, word2, wordx, checksum_spi, checksum_verify;
uint16_t nblock, data[8];
bool SYNC;
// Initialize variables
for (ii=0; ii<8; ii++) data[ii]=0;
// Sync with Pixy
SYNC = 0;
word1 = 0;
word2 = pixy_spi_read_16bit( target, SETX, CSX);
jj = 0;
while ( SYNC==0 && jj<PIXY_SPI_TRY)
jj++;
word1 = word2;
if (word1==PIXY_START_WORD && (word2==PIXY_START_WORD || word2==PIXY_START_WORD_CC) ) {
SYNC = 1;
wordx = word2;
// Read Pixy Data Blocks
nblock=0;
while (SYNC==1)
SYNC=0;
if ( wordx==PIXY_START_WORD || wordx==PIXY_START_WORD_CC )
data[0] = wordx; // Object type: Normal (0xaa55), Color Code (0xaa56)
data[1] = pixy_spi_read_16bit( target, SETX, CSX); // Checksum
data[2] = pixy_spi_read_16bit( target, SETX, CSX); // Signature No.
data[3] = pixy_spi_read_16bit( target, SETX, CSX); // X Center of object
data[4] = pixy_spi_read_16bit( target, SETX, CSX); // Y Center of object
data[5] = pixy_spi_read_16bit( target, SETX, CSX); // Width of object
data[6] = pixy_spi_read_16bit( target, SETX, CSX); // Height of object
if (wordx==PIXY_START_WORD) data[7]=0; // Angle not available for Normal Objects
if (wordx==PIXY_START_WORD_CC) data[7]=pixy_spi_read_16bit( target, SETX, CSX); // Angle of object for Color-Coded-Objects
// Verify CHECKSUM
checksum_spi = data[1];
checksum_verify = data[2] + data[3] + data[4] + data[5] + data[6] + data[7];
// Capture Block Data
if (checksum_spi==checksum_verify && nblock<PIXY_MAX_BLOCKS)
SYNC = 1;
nblock++;
pixy->sig = data[2];
pixy->x = data[3];
pixy->y = data[4];
pixy->wd = data[5];
pixy->ht = data[6];
pixy->phi = (int16_t)data[7];
pixy++; // Increment pointer to PIXY struct array
wordx = pixy_spi_read_16bit( target, SETX, CSX); // Advance to next data block
} // if ( wordx==PIXY_START_WORD || wordx==PIXY_START_WORD_CC )
} // while (SYNC==1)
return nblock;
#define MAXLINE 136
char nmeac[MAXLINE];
int ii, jj, kk;
uint16_t nblock;
PIXY pixy[PIXY_MAX_BLOCKS];
// INITIALIZE SPI
pinMode( PIXY_SPI_CS, OUTPUT);
digitalWrite( PIXY_SPI_CS,HIGH);
SPI.setMOSI(MOSIX);
SPI.setMISO(MISOX);
SPI.setSCK(SCKX);
SPI.begin();
delayMicroseconds(1000000);
Serial.println("Initializing...");
// Stream Pixy Data Blocks
for( ii=0; ii<10000; ii++)
nblock = pixy_parse_data( PIXY_SYNC_BYTE_DATA, PIXYSPI, PIXY_SPI_CS, pixy);
if (nblock>0)
for (jj=0; jj<nblock; jj++)
sprintf(nmeac, " %d %d %d %d %d %d %d\r\n", nblock, pixy[jj].sig, pixy[jj].x, pixy[jj].y, pixy[jj].wd, pixy[jj].ht, pixy[jj].phi );
Serial.print(nmeac);
else Serial.println("0");
delayMicroseconds(20000); // Delay=0.02sec (50 Hz sample rate)
