04-18-2018, 07:55 PM
#201
Senior Member+
Originally Posted by
Cyb3rn0id
NumLock feature doesn't work. When I hit num/lock for the joystick swap, board stucks, neither CRT ALT CANC reset, I must disconnet power
@others do you have this problem, too?
Cyb3rn0id
Sometimes screen initialization fails: screen is shifted
might be your display, or a connection problem.
The display-spi ist very fast, pls connect it directly to the board - no cables!
04-18-2018, 07:59 PM
#202
Senior Member+
I ordered 3.2'' SPI ILI9341 display in China, I am very curious if it works.
04-19-2018, 08:21 AM
#203
Frank B
Two months of waiting for shipment then?
With the same type of connection or flat cable? (the latter one, I've seen on AliExpress etc)
Would be fun with a slightly larger screen than the current 2.4" (yes, I went for 2.4 instead of 2.8 - didn't want to wait too long
04-19-2018, 09:39 AM
#204
Frank B
I've connected directly to board. Maybe a display issue. I'll order some others displays.
In the meanwhile I've tried connecting to IEC port some drives I have that works on a Commodore 64. A 1541 and a 1541-II. Don't works. After loading sometimes gives an out of data error, or garbage on the screen or nothing. The SD2IEC works even if a lot of games are not loaded.
04-20-2018, 12:46 PM
#205
Frank B
Are the ones with the 40-pin connector?
04-21-2018, 01:46 AM
#206
can someone post a hex file for the vga version. I have assemble the board and would like to test it. TIA
04-21-2018, 03:00 AM
#207
ron2way
Disregard the request for the hex file. I was able to get the board working.
04-21-2018, 06:25 AM
#208
Senior Member+
ron2way
Good work!
04-22-2018, 07:28 PM
#209
Senior Member+
Cyb3rn0id
This one:
https://www.aliexpress.com/item/3-2-...859744548.html
- You may not post replies
- You may not edit your posts
Forum Rules
