Results 1 to 19 of 19
Thread: Teensyduino 1.39 Released
    Administrator Paul's Avatar
    Oct 2012
    350
    Teensyduino 1.39 has been released.
    No changes were made since 1.39-beta2.
    Sep 2013
    Hamburg, Germany
    894
    I'm working on an update for DMASPI to work with the refactored SPI classes.
    Mar 2013
    Austin TX
    426
    Just FYI, please pull a new i2c_t3 release to include for your next TD version. There have been a few bug fixes since the version included in TD 1.39. Here is the link:
    https://github.com/nox771/i2c_t3
    21,298
    Quote Originally Posted by nox771 View Post
    Done, and I just sent you a pull request for the 1 tiny customization that was in my copy.
    Mar 2013
    Austin TX
    426
    I merged this. GitHub and forum download are updated.
    Sep 2013
    Hamburg, Germany
    894
    DMASPI was updated and tested on a T3.6 (SPI0 and SPI1). Thank you for creating a common base for the SPIs, Paul!
    21,298
    Kurt actually deserves most of the credit for unifying the SPI classes!
    Sep 2013
    Hamburg, Germany
    894
    It only took about two years to convince you: https://forum.pjrc.com/threads/28155...ll=1#post68641
    Would probably be longer if this was standard arduino...
    10,587
    EventResponder::runFromYield(); in yield breaks standing use of replacing/removing the 'weak' yield() to keep Teensy Bare Metal.
    Minimal-Blink-fails-with-void-yield()
    Sep 2013
    Hamburg, Germany
    894
    Patched yield() declaration (https://github.com/PaulStoffregen/co...8c3f8b8151bf81) also helps with the Zilch library (cooperative multitasking).
    I just tried to use SPI1 on a teensy 3.2. The compile failed with "SPI1 was not declared in this scope". If I compile as a Teensy 3.6, 3.5, or LC the compile completes. The compile fails on teensy 3.0 and 3.2/3.1. Doesn't the 3.2 have the second SPI hardware?
    3,482
    Cool
    Quote Originally Posted by dundakitty View Post
    No, the Teensy 3.1/3.2 only has 1 SPI bus. The LC has 2 SPI buses and the 3.5/3.6 have 3 SPI buses. Note, on the 3.5/3.6, only the first SPI is buffered, which means you might want to put high speed devices only on the first bus.
    On the LC/3.5/3.6, the standard 2nd SPI bus uses pin 0 for MOSI1 (pin 21/A7 is the alternate MOSI1) and pin 1 for MISO1 (pin 5 is the alternate MISO1).
    The MISO2/MOSI2 pins are on solder pads underneath the Teensy 3.5/3.6.
    6,088
    As far as I know the T3.2 does not have a second SPI port. If you look at the card that comes with the board you will notice that the SPI pins (11, 12, 13) are simply marked as DIN/DOUT/SCK...
    Where as on for example on the T3.5 they are marked as MOSI0, MISO0, SCK0. Note: the naming of the pins sort of changed from DOUT->MOSI (Data Out --- Master Out Slave IN)
    DIN->MISO (Data In --- Master In Slave Out)
    Thanks, I was trying to use 11, 12, 13 as SPI and 7,8,14 as SPI1. Guess it's a single SPI but alternate pins.
    3,482
    Yes, that is correct.
    4,588
    Know 1.40 is out but I just downloaded the lastest fastLED library and it threw an error for the T3.5 (see below). I deleted it and used the one downloaded with TD1.39 and it worked fine again. Just wanted to give you all a heads up.
    In file included from C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/FastLED.h:51:0,
                     from C:\Users\CyberPalin\Documents\Arduino\TeensyOpenMV2\TeensyOpenMV2.ino:10:
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/fastpin.h: In instantiation of 'class FastPin<31u>':
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/platforms/avr/clockless_trinket.h:96:49:   required from 'class ClocklessController<31u, 39, 39, 77, (EOrder)10u, 0, false, 10>'
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/chipsets.h:460:7:   required from 'class WS2811Controller800Khz<31u, (EOrder)10u>'
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/FastLED.h:110:52:   required from 'class WS2811<31u, (EOrder)10u>'
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/FastLED.h:297:39:   required from 'static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2811; unsigned char DATA_PIN = 31u; EOrder RGB_ORDER = (EOrder)10u]'
    C:\Users\CyberPalin\Documents\Arduino\TeensyOpenMV2\TeensyOpenMV2.ino:98:56:   required from here
    C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED/fastpin.h:206:2: error: static assertion failed: Invalid pin specified
      static_assert(validpin(), "Invalid pin specified");
    21,298
    I tried just now, but I was unable to reproduce the problem. Since I don't have TeensyOpenMV2.ino, I opened FastLED's DemoReel100 example. I selected Teensy 3.5 and left all the settings at their defaults.
    Here's a screenshot, using Arduino 1.8.5 and Teensyduino 1.40-beta2.
    4,588
    Thanks for checking Paul. I had two copies of FastLED, one in my Arduino Lib folder and one in the Teensy libraries that I downloaded with TD. The revision of both (library.properties) is at 3.1.6. Then I get the message (with both installed):
    Multiple libraries were found for "FastLED.h"
     Used: C:\Users\CyberPalin\Documents\Arduino\libraries\FastLED
     Not used: C:\Local Programs\arduino-1.8.5\hardware\teensy\avr\libraries\FastLED
    Error compiling for board Teensy 3.5.
    When I deleted the copy in the Arduino libraries folder it worked fine. Not sure why this would happen. But anyway, TeensyOpenMV is too big to send so I copied the FastLED stuff from it to its own sketch and was able to reproduce the problem (using 1.85/1.40 now) if I had the two libs installed since it only uses one or the other.
    Just by way of an update the version that I downloaded via the library manager in the IDE is the problem. The version that is part of the TD works fine. (Just tested as I was writing this).
    #include <FastLED.h>
    Mike
    //Malek Systems RGB LED WS2812B
    #define DATA_PIN 31
    #define NUM_LEDS 8
    #define BRIGHTNESS  64
    CRGB leds[NUM_LEDS];
      //LED Setup
      delay(2000);
      FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
      FastLED.setBrightness(  BRIGHTNESS );
      for(int whiteLed = 0; whiteLed < NUM_LEDS; whiteLed = whiteLed + 1) {
        // Turn our current led on to white, then show the leds
        leds[whiteLed] = CRGB::White;
        // Show the leds (only one of which is set to white, from above)
      FastLED.show();
    21,298
    Thanks for confirming. I'm taking this one off my issues list.
