Results 1 to 6 of 6
Thread: Selecting Alternative Functions of a Pin
    Hello
    I am drawing a PCB that uses a Teensy 3.6 but I have not yet got the physical board to do the tests.
    I need Serial 1 and also SPI1 working but SPI1 uses pins 0 and 1, which are also used by Serial1. I think the Serial 1 pins can move up to Pin 27 and Pin 26 but I'm not sure how to do it or even if it can be done.
    Would something like this work?
    *portConfigRegister(0)  = PORT_PCR_MUX(2);	// Pin 0  >> SPI1_MOSI
    *portConfigRegister(1)  = PORT_PCR_MUX(2);	// Pin 1  >> SPI1_MISO
    *portConfigRegister(26) = PORT_PCR_MUX(3);	// Pin 26 >> Serial1_TX
    *portConfigRegister(27) = PORT_PCR_MUX(3);	// Pin 27 >> Serial1_RX
    For basic use, is it necessary to configure pin pull-up, pin filter and that stuff?
    *portConfigRegister(X) = PORT_PCR_MUX(Y) ) | PORT_PCR_PFE;
    Is there any tutorial for beginners on how to configure the alternative functions of the pins?
    Thanks and sorry for my awful English.
    16,219
    Quote Originally Posted by FAlameda View Post
    Serial1.setTX(26);
    Serial1.setRX(27);
    Detailed documentation here:
    https://www.pjrc.com/teensy/td_uart.html
    Dec 2016
    Canada
    826
    you could also use the alternate SPI1 pins 5,20,21 as well
    dont forget to *.begin AFTER you set the pins
    That would be a good thing to demonstrate on the PJRC page for proper function as one could wrongly intuit it as sensible to have it work the other way.
    16,219
    The latest versions of SPI, Wire and Serial# are all designed to allow changing the pins before or after you call begin().
    Of course, if you call something like SD.begin(), you must configure the pins before, since it actually does communication on the pins. Hopefully that's obvious? (and it's in many of the examples....)
    Nice .......
