Results 1 to 3 of 3
Thread: Equivalent to AVR ports?
    Sep 2017
    2
    Hi, I am currently designing a device for controlling cameras using the Teensy 3.6. In the future, I might want to record the ExposureActive signal of multiple cameras, with an accuracy of a few Ás. Think of some kind of logic analyser with a few hundred kHz speed. On an AVR, I would choose the ports associated with the inputs to be on one port. Is there a Teensy equivalent to stuff like PORTA/B ... on an AVR, or are there ports that suggest themselves for something like that?
    Sep 2017
    2
    Spot on, thanks!
    I updated the list for the Teensy 3.6 (some pins changed!), added a column for the timer and put it into Google Docs so one can easily sort by the column of interest:
    https://docs.google.com/spreadsheets...it?usp=sharing
