Results 1 to 11 of 11
Thread: Ia anyone using the Fusion dual can shields or GPS shield
    Dec 2016
    Detroit, Michigan, USA
    104
    Is anyone using the Fusion dual can shields or GPS shield
    I just got these for a project I am working on with the Teensy 3.6.
    Issues:
    The dual-CAN shield blocks the VBATT pin. Has anyone done anything creative to get around this? I am considering just soldering a piece of wire to the pin to get it out from under the shield.
    The GPS shield blocks the reset button. I am not even sure how I can get around this. I quite often need to press the reset button and this is a real show-stopper for me.
    Jun 2014
    253
    Have you had a look at the pics on the product pages? I'm not sure how you'd get near the reset button, although you could move the whole board down of course (you might not want to pull the needed current from pins other than dedicated 3.3V pin as pictured).
    There is really no universal way to design these boards. Everyone's project can be a bit different and I'd have to design a different board for each one.
    Dec 2016
    104
    Thanks Fyod!
    I thought for some reason the GPS shield mounted in the same manner as the CAN shields.
    You are the man, again! Thanks.
    Jun 2014
    253
    No problem
    Dec 2016
    104
    Sigh. Maybe electronics aren't my thing.
    Dec 2016
    104
    Got it. Thanks Fyod for the support.
    I desoldered the wrong SMD.. then removed the correct one, soldered the one I removed back on, and gave it about 5 minutes. 12 locked satellites, position fix, and I guess my desk is moving at 1.06 kph! hahaha.
    Greatly appreciate the messages! Glad it's sorted now.
    Jun 2014
    253
    Awesome!
    Yep there might be slight deviations between positions, but that usually settles down the more sattelites get locked.
    Dec 2016
    104
    Is there a better, perhaps amplified antenna you would suggest?
    I created a timer and whenever there is a power-down event, it's taking well over 5 minutes to even lock 3 satellites. The intention was to use this for speedometer, but starting the vehicle 10 minutes before it's to be driven is just a tad too long.
    Dec 2016
    104
    Going on an hour now after a reset and no satellites showing locked. The time updated to the proper date and time though, so there's that.
    What are the use-case scenarios for this shield with a passive antenna? What are the options for an active antenna? None for me, I assume since I had to desolder that resistor.
    Jun 2014
    253
    Sorry I missed your previous message.
    You should get a lock within two minutes or so, under good conditions (outside or window sill, fair weather).
    It is hard to say what could be causing the delay as there is no feedback from the antenna other, than the signal itself.
    If you choose to use an active antenna, all you need to do is use a 0ohm or 10ohm resistor in place of the one you removed.
    Active antennas generally perform better, but are also more expensive ($8-12).
    Dec 2016
    104
    Quote Originally Posted by Fyod View Post
    Greatly appreciated Fyod. I'll order up an active antenna and see what kind of results I get.
    I appreciate the support post-purchase and it's because of this that you will always be my go-to when it comes to modules for the Teensy such as this.
