Results 1 to 5 of 5
Thread: Help!
    Sep 2017
    2
    Help!
    Dear reader, I bought a TEENSY 2.0. I want to make an external ‘enter key’. Can anyone tell me how to do this? I'm not getting out of it.
    Thank you all.
    17,459
    Install Arduino & Teensyduino.
    Run Arduino, select Teensy 2.0 from Tools > Boards.
    Then click File > Examples > Teensy > USB_Keyboard > Buttons. Upload this code to your Teensy and watch how it works. If you don't have a button connected, you can make the connection by touching a wire or paperclip between GND and the nearby pins.
    Once you have this working, hopefully you can look at the code and try to understand how to edit it to your needs...
    Sep 2017
    2
    Hello
    Hey, for so far I have it working.
    Now I have another problem. When I pressed the button, an automatic text was displayed. I have removed these so so now it's only an enter key. but when I press the button 1 times, he is doing 3 enters how can i make sure there's only 1 time enter
    6,374
    Possibly button bounce - or loop() processing it multiple times while pressed in some fashion. Please "#" post the code as you have it.
Tags for this Thread
