chris.sallis
New member
I'm using a Teensy 3.6 to intercept individual channel PWM output signals from a flight controller that are used to control individual ESCs for a multi-rotor. Reading the incoming 400 Hz signals has not been an issue, but I don't have a way to pass them out at 400 Hz. Modifying the standard Servo library only allows up to ~130 Hz. I'm looking for completed code or library that allows me to generate 400 Hz PWM signals with similar structure to the existing Servo library. I am an entry level Arduino programmer without formal training. I know this is possible and has been completed by several other projects but I'm having difficulty finding documentation. For example, the Ardupilot APM 2.5 was based on an Arduino Mega was was used as a multi-rotor aircraft flight controller. Thanks!
