Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 74
Thread: Minimal Blink fails with void yield()
    7,347
    In response to a query about code/RAM used on base USB sketch - I did this to see the current numbers without USB. I started with Teensy :: arduino-1.8.4\examples\01.Basics\Blink
    This fails on a T_3.1 - 'No USB' - compiled 'smallest code' { with and without LTO } [also fails FAST w/LTO}.
    Uploading with TeensyLoader 1.39 and IDE 1.8.4 on Windows, Larger code executed with no problem when using PJRC yield(). NOTE: Another recent post with a 'void yield()' in library code was dying on start, removing that allowed it to run.
    Blink as below fails to show 'LED' signs of running when using this to further reduce base code: void yield(void) {};
    int led = 13;
      // initialize the digital pin as an output.
      pinMode(led, OUTPUT);
      digitalWriteFast(led, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(1000);               // wait for a second
      digitalWriteFast(led, LOW);    // turn the LED off by making the voltage LOW
    // USB type : No USB
    // Smallest Code - PJRC Yield - T_3.1 :: Uploads and Blinks
    // Sketch uses 3508 bytes (1%)
    // Global variables use 900 bytes (1%)
    // Smallest Code - void Yield - T_3.1 :: Uploads, then Blink fails
    // Sketch uses 2280 bytes (0%)
    // Global variables use 488 bytes (0%)
    // Smallest Code w/LTO - void Yield - T_3.1 :: Uploads, then Blink fails
    // Sketch uses 1680 bytes (0%)
    // Global variables use 480 bytes (0%)
    // Fast w/LTO - void Yield - T_3.1 :: Uploads, then Blink fails
    // Sketch uses 3104 bytes (1%)
    // Global variables use 1544 bytes (2%)
    7,347
    This is the thread where void yield() stopped another project until removed from external library - in that case the user was using USB Serial: Need-Help-with-Teensy-3-6-Serial-COM-port-disappears-after-uploading-code
    1,787
    With 1.8.3/1.37 blink works with your yield() and Smallest on T3.2 (and no USB). I'm wondering if EventResponder stuff that was added to 1.8.4/1.38 is affecting things? 1.8.4 yield() has an EventResponder check.
    can you re-test with 1.8.3? or one could modify your in-sketch yield() to do various event checking pieces as taken from
    hardware/teensy/avr/cores/teensy3/yield.cpp
    ... further study required
    3,809
    Yes - the system appears to depend on runFromYield() being called.
    #include "EventResponder.h"
    int led = 13;
    void yield(void) {
        EventResponder::runFromYield();
    Germany NRW
    5,027
    This can't be the whole truth.. I have sketches without, and they work. Don't know why.
    3,809
    Yep - I think the whole truth is, that the yield code called runfromYield... So the event responder code was brought in.
    The actual code that is really needed was the systick timer ISR, which counted millis... Which is now in EventResponder.cpp
    extern "C" volatile uint32_t systick_millis_count;
    void systick_isr(void)
    	systick_millis_count++;
    	MillisTimer::runFromTimer();
    So whole program right now is:
    int led = 13;
    void yield(void) {
    Germany NRW
    5,027
    Oh, wow.. thank you for your examination..
    That means.. if I don't want these additions, it is not enough to override yield() (i need nothing of the stuff there..), no, with the new versions I have to override (eh..no, it is not "weak"(?)) / redirect the systick too.
    Thanks Kurt !
    Would have been nice to mention that on a place that gets read..
    2,004
    Some sort of Wiki? It will not happen... (or maybe, sometime,...)
    3,809
    I am thinking out loud, that maybe the default systick timer code should be in a core place.
    Maybe only if someone uses the event code and sets the first event that uses call on yield, should it either replace the vector and/or the default one should have function pointer to call, that if non-null gets called...
    Germany NRW
    5,027
    +1
    Ok, in case someone reads this:
    To disable the new behaviour:
    void mySystick_isr(void);
    void setup(){
        _VectorsRam[15] = mySystick_isr;
    (I hope there will be a better way to do this, in future)
    If you want to disable the stuff in yield() :
    void yield(void){}
    But something like yield() can be useful sometimes, because it gets called not only after loop() but in some cases when the core waits for things, too.
    In this case:
    void yield(void){
      static volatile uint8_t running = 0;
      if (running) return;
      running = 1;
      //Add your code here
      running = 0;
    But be careful what you do here.
    For reference, this is the original yield():
    void yield(void)
        static uint8_t running=0;
        if (running) return; // TODO: does this need to be atomic?
        running = 1;
        if (Serial.available()) serialEvent();
        if (Serial1.available()) serialEvent1();
        if (Serial2.available()) serialEvent2();
        if (Serial3.available()) serialEvent3();
    #ifdef HAS_KINETISK_UART3
        if (Serial4.available()) serialEvent4();
    #ifdef HAS_KINETISK_UART4
        if (Serial5.available()) serialEvent5();
    #if defined(HAS_KINETISK_UART5) || defined (HAS_KINETISK_LPUART0)
        if (Serial6.available()) serialEvent6();
        running = 0;
    (btw, isn't this a bug ? Shouldn't be "running = 0" AFTER EventResponder::runFromYield(); ??)
    Germany NRW
    5,027
    It was there
    Germany NRW
    5,027
    Is it really necessary to start EventResponder::runFromYield(); 1000 times a second ? 1000 is minimum from systick - it gets called more often....in addition, in runs with every loop(), and way more often when the core waits...
    And yes, in EVERY Sketch. Regardless if it needed or not. In 99.999% a Sketch does not need it...!
    7,347
    With 1.8.3 blink works with your yield() and Smallest on T3.2 (and no USB). I'm wondering if EventResponder stuff that was added to 1.8.4 is affecting things? 1.8.4 yield() has an EventResponder check.
    My 1.8.3 must have EventR...() Beta - but confirm IDE 1.8.1 builds and runs fine same sketch my machine.
    Wow - Glad I wrote that up . . . in the middle of stuff here looks like I started a fun PARTY ... will be back later.
    It doesn't add a lot of code - just a critical link that breaks - size is about the same:
    // IDE 1.8.1 :: Smallest Code - void Yield - T_3.1 :: Uploads and Blinks
    // Sketch uses 2304 bytes (0%)
    7,347
    Good research @manitou!
    As a WIP - hopefully this can get cleaned up in a way to avoid overhead. As yield() indeed 'can be' unneeded overhead and as a weak is nice to disable, but now that no longer works as core function was moved in.
    IIRC : isn't EventResponder going to end up running/driving some core interfaces behind the scenes over time?
    > WIKI would be cool! Not sure it would have brought this out like a simple sketch did - but now known - it could be documented.
    > it seems "running = 0;" should be the last of yield() to prevent re-entry
    Windy storm and rain just blew in - must get out and tend to stuff.
    Germany NRW
    5,027
    Tim,
    I don't know your exact setting when blink failed - can you try this patch please : https://github.com/PaulStoffregen/cores/pull/254
    3,809
    Tim,
    Frank, this might work, but there may be an interesting issue, with using Teensy Threads, that will also try to set that same vector. So it may be last one wins.
    Germany NRW
    5,027
    Ok, yes, depends on the order. Without the patch, Teensy Threads always wins, correct ? (I don't know what it does...)
    On c64, long years ago, we used a kind of chaining, where the new interrupt called the old routine. - if i remember correctly, after 30 years...or it wasn't the c64 but an other machine...lol..
    3,809
    Yep - I have not looked at their stuff lately, but I remember there being an issue that was fixed during one of the recent betas...
    Yes - I believe old MSDOS programs used to chain interrupts as well. Hold on to the previous interrupt handler and put yours in, and then if appropriate pass an interrupt on down the chain...
    It was always fun on being able to remove the hooks. It was easy to remove the last one added, but I remember having code around that would have to leave a stub function if your program exited that had a hook and you were not the first one in the chain... Memories...
    Germany NRW
    5,027
    Oh yes, it was msdos.. you are right. It was fun.
    Anyway, I think the best way for both is, to use "IntervalTimer" instead. It handles such things better and doesnot influence myriads of innocent sketches
    7,347
    Frank - Indeed I hand made the edits and that code compiles and works - nothing special to compile - just creating a "void vield()":
    // Smallest Code w/LTO - void Yield - T_3.1 :: Uploads and Blinks
    Sketch uses 1712 bytes (0%)
    Chaining came to mind for Teensy Threads - but that can get ugly.
    Must be a good solution. When EventResponder finalizes it should be outside yield() as that has always been 'weak'. If it becomes 'always on' - perhaps 'EventResponder::runFromYield();' would be added to main() - renamed to EventResponder::runFromMain(); ?
    Germany NRW
    5,027
    Hi Tim,
    If it was me, I'd remove that yield() completely But I don't think that's up for debate.
    Chaining: I can imagine a small c++ library in the core, that can do it.. an, as a nice side-effect, for every interrupt.
    Teensy Threads: I've looked at the source. RE: Millis, It does almost exactly the same as Events.. would be better to use an other timer...PIT..or...FTM..
    But ok... my solution seems not to find friends.. correct ?
    7,347
    Frank - your solution works - it would be up to Paul to decide the direction as it will tie up a resource? Since the EventResponder is a WIP it seems PJRC might incorporate best answer.
    yield() is an Arduino compatibility thing - so not likely to go away - though being able to remove that overhead since serialEvent#() isn't really as cool as it seemed when I first saw it.
    Germany NRW
    5,027
    yield() :
    Why not - simply - set a flag when all the checks are needed ?
    Serial1...SerialX and even Event Responder could set a global volatile flag IN their INTERRUPT (which is called anyway).
    All SerialX can set the same Flag.
    So yield could look like
    if (!running && flag) {
    do_all_the _checks_and call_events_like_orginal_yield()
    This would be *much* faster than now and would not hurt apps so much that are not interested in this stuff.. ;-)
    And 100% compatible.
    Nope this time no pullrequest... don't like to invest work for nothing when nobody even answers... even a "no, because" would be helpful or nice. but not nothing.
    Dec 2016
    Montreal, Canada
    2,878
    such a precious waste of memory (for a bool? ), hopefully we have enough left over for our projects lol
    7,347
    I thought the same Frank - Maybe I made a bad start of it - but I tried it once and it wasn't faster? And yes, lots of overhead to allocate a bool, set the bool, test the bool: a few times over.
    It is nice to just kill the 'weak' yield() - but that is broken. As noted "EventResponder is a WIP it seems PJRC might incorporate best answer" ... but alas a week after posting and no answer . . .
    Manitou first noted in p#3 that it was EventResponder - but referred to IDE build - but this is a bug in TeensyDuino build when the hack to yield() was introduced?
    It was 3 months back - I just posted a comment on github: This yield.cpp change for EventResponder::runFromYield(); breaks removal of 'weak' yield and results in a non-functional upload when that common practice is done. and linked back to this thread.
