I have been having issues with the Teensy 3.2 RTC not reliably starting using a 12.5 pF crystal. I am using one of the crystals (+/- 10ppm) recommended on this page:
https://www.pjrc.com/teensy/td_libs_Time.html
https://www.digikey.com/product-detail/en/citizen-finedevice-co-ltd/CFS-20632768EZFB/300-8762-ND/2217073
We use a fair number of Teensy's and have seen about 1/10 not correctly start the RTC oscillator. The observed behavior is that the RTC does not tick. We have also seen some work intermittently. There are no shorts and there are good connections to the K20 pins. Changing the crystal does not always solve the issue.
Looking at the core code, it seems the internal capacitors are set to be 20 pF
https://github.com/PaulStoffregen/cores/blob/a587b3dd1e849d1262f49bf17c91c52ecb04c2a2/teensy3/mk20dx128.c
#ifdef KINETISK
// if the RTC oscillator isn't enabled, get it started early
if (!(RTC_CR & RTC_CR_OSCE)) {
RTC_SR = 0;
RTC_CR = RTC_CR_SC16P | RTC_CR_SC4P | RTC_CR_OSCE;
Assuming no stray capacitance, then a 10 pF crystal would be more appropriate, and if there is internal stray capacitance something even lower would be called for. Is this correct?
I will try a lower capacitance crystal and also experiment with changing the core code (but I don't like that solution for future Teensy core updates), but I wanted to make sure I understood what could be going wrong.
#ifdef KINETISK
RTC_SR = 0;
