I'm using a WIZ820io adaptor board. I'd like to use the PWDN option because the system is going to be run from a battery. I've cut the trace between the pads on the board but I'm still getting continuity between the the centre and pad linked to pin9. Is there anything else that I have to cut in order to make this work? I've had a look, of course, but haven't been able to spot anything obvious, other than perhaps removing the left pad which seems a bit drastic.
Many thanks
David
Many thanks
David
