Results 1 to 14 of 14
Thread: An Audio Phase-Locked-Loop (PLL) Block
    May 2016
    256
    I'm pleased to post a new Audio Block that implements a real-time phase-locked-loop for use with the Teensy Audio Board. The necessary files are contained in the AudioPLL.zip file here: AudioPLL.zip
    What is a PLL? Well, they are found everywhere in modern electronics. They are a feedback control system, but with a special purpose. They have an in-built frequency synthesizer that is "locked" to an external waveform in frequency and phase, by a feedback loop that continuously measures the instantaneous phase difference between the two signals, and modifies the synthesizer so as to reduce the phase difference to zero, thus locking the two signals together. They are most common in high frequency rf communications work.
    The AudioPLL block works at audio frequencies, currently from less than 100Hz to about 12kHz, and over a >40dB range in the reference level. Further tweaking of the loop filter should extend the upper frequency limit. Internally the algorithms use quadrature processing, and a Hilbert Transformer is used to convert from the single input channel to quadrature.
    These can be tricky little devils to understand, so I've put a bit of effort into comments in the code. In addition I've included a document that describes some of the issues in the designing analog hardware PLLs, it may help understand the concepts.
    The necessary files are included in AudioPLL.zip, as well as another block, AudioSerialPlotter, that will let you view the output on the Arduino Serial Plotter. The set up is simple - here is the attached sketch included:
    // Simple test sketch for AudioPLL phase-locked-loop audio block
    // D. Rowell      Sept 20,2017
    #include <SerialFlash.h>
    #include "AudioPLL.h"
    #include "AudioSerialPlotter.h"
    AudioSynthWaveformSine   ReferenceInput;
    AudioPLL                 PLL;
    AudioSerialPlotter       Plotter;
    AudioOutputI2S           myOutput;
    AudioControlSGTL5000     audioShield;
    AudioConnection c2(ReferenceInput,0, PLL,0);
    AudioConnection c3(PLL,0,            Plotter,0);    // Plot outputs on Arduino SerialPlotter
    AudioConnection c4(PLL,1,            Plotter,1);    // (or view on SerialMonitor :-) )
       Serial.begin(57600); while(!Serial){};
       audioShield.enable();
       AudioMemory(20);
       audioShield.inputSelect(AUDIO_INPUT_LINEIN);
       float frequency = 500;
       float amplitude = 0.5;
       ReferenceInput.frequency(frequency);
       ReferenceInput.amplitude(amplitude);
       PLL.enable();
    //  PLL.analysisOutputs();      // Output synthesized output + frequency
       PLL.quadratureOutputs();     // Output quadrature outputs
    // Plotter.disable();
      // Switch frequency every 3 secs.
      ReferenceInput.frequency(200.);
      delay(3000);
      ReferenceInput.frequency(1500.);
      delay(3000);
    The block processing time is 330 usec on a Teensy 3.6 at 180 MHz.
    Ongoing work includes generating a waveform that is related to, but not identical to, the reference. For example - a waveform that is offset from the reference frequency by a constant, or an arbitrary multiple of the reference (eg an integer harmonic or subharmonic, or a fractional factor).
    PLLs can also be used to find and report (with sub-Hz) accuracy the frequency of the reference. The AudioPLL has a function myFrequency = myPLL.getFrequency that returns a float, BUT it can also stream the running frequency estimates as an int16() in Hz through the channel 1 output. by setting myPLL.analysisOutputs(), while if you set myPLL.quadratureOutputs() Channels 0 and 1 will contain the two synthesizer waveforms, that is cos(wt) and sin(wt).
    Comments, criticisms, suggestions etc are all welcome
    Derek
    Sep 2017
    8
    Well done. Should check this out.
    Jul 2017
    120
    Great job. Thanks alot Derek. I have gone through with all your codes and read the Analog PLL design document as well.
    You have done a great effort on writing comments. It will explain well about how things work. You have a really good explanation ability. Firstly when i read the code comments i didn't understood much. But now i can understand well after gone through with lot of theoretical stuff.
    Your PLL code block will be really useful on Software Defined Radio (SDR) systems.
    I have attached two documents which helped me to understand about digital PLL
    Anyway this software phase lock loop block can be use on my project. Once you have told me
    can use set of software phase-locked-loop (PLL's) to lock on to the fundamentals and overtones and track their frequencies exactly in real-time
    Could you please explain this more. Then i can check your PLL block for fundamentals and overtones. So since I'm using microphone signals i can set the adc output into PLL input(reference) right? To set the fundamental frequency and adjust bandwidth, need to change the parameters of the filter right? Since i really don't know how to change filter parameters you could help me with that. For analysis i guess i can use "PLL.analysisOutputs();" Also how to identify whether pll get locked?
    Thank you
    Attached Files Attached Files
    May 2016
    256
    Why don't you simply play your .wav file through the PLL, watch the output on the Serial Monitor and report back here what happens.
    Jul 2017
    120
    This are some of the results. I can't understand the pattern. But seems like its trying to give some valuable information
    31586 , -3782
    23760 , -3104
    13998 , -2090
    6238 , -1419
    986 , -849
    -1803 , -347
    -2705 , -40
    -2636 , 68
    -2348 , 53
    -2122 , 41
    -1997 , 10
    -1934 , 14
    -1878 , 9
    -1890 , -16
    -1916 , 5
    -1872 , 13
    -1796 , 17
    -1740 , 6
    -1696 , 10
    -1659 , 5
    -1627 , 8
    -1583 , 9
    -1533 , 10
    -1502 , 1
    -1483 , 6
    -1445 , 9
    -1395 , 12
    -1357 , 4
    -1326 , 8
    -17354 , -7278
    -27461 , 1160
    -31617 , -5535
    -32712 , 2606
    -32700 , -4293
    -25777 , -4168
    -13479 , -2593
    -3774 , -1739
    2460 , -938
    5347 , -308
    6077 , -9
    21558 , -7455
    30186 , 1087
    32654 , -5545
    32545 , 2762
    32057 , -4056
    23446 , -3881
    10539 , -2718
    175 , -1805
    -6066 , -884
    -3112 , 2162
    11787 , 4339
    26491 , 3716
    32469 , 3230
    31652 , 2326
    27552 , 2033
    21783 , 1782
    15323 , 1595
    8751 , 1441
    2666 , 1209
    -2611 , 1054
    -6688 , 712
    -9368 , 472
    -10296 , -55
    -9349 , -370
    -7112 , -620
    -4398 , -561
    -2191 , -389
    -1100 , -80
    -1282 , 158
    -2504 , 364
    -4454 , 475
    -6946 , 608
    -9806 , 659
    -12921 , 763
    -16151 , 782
    -19387 , 871
    -22502 , 868
    -25392 , 950
    -27931 , 931
    -30031 , 1013
    -31589 , 986
    -32523 , 1071
    -32753 , 1042
    -32217 , 1133
    -30861 , 1109
    -28629 , 1209
    -25487 , 1199
    -21418 , 1311
    -16363 , 1349
    -10356 , 1478
    -3194 , 1665
    4919 , 1820
    15815 , 3137
    30417 , 6500
    32659 , -2282
    28782 , -3586
    19744 , -2393
    11121 , -1825
    4179 , -1241
    -1081 , -1017
    -4709 , -545
    -6848 , -386
    -7706 , 9
    -7479 , 88
    -6553 , 317
    -5044 , 337
    -3250 , 436
    -1119 , 477
    1224 , 526
    3873 , 612
    6681 , 605
    9727 , 743
    12851 , 683
    16090 , 864
    19305 , 775
    22488 , 997
    25450 , 871
    28184 , 1180
    30456 , 1032
    32118 , 1474
    32766 , 1343
    31818 , 2020
    28136 , 2150
    20757 , 2719
    8853 , 3072
    -4653 , 2772
    -16770 , 2773
    -25546 , 2237
    -30631 , 2167
    -32630 , 1653
    -32435 , 1619
    -30871 , 1187
    -28422 , 1326
    -25232 , 1077
    -21081 , 1451
    -14950 , 1709
    -5732 , 2476
    10038 , 4366
    26363 , 4390
    32737 , 3965
    29284 , 3142
    20873 , 2684
    10973 , 2220
    1664 , 1863
    -6393 , 1608
    -13031 , 1377
    -18370 , 1238
    -22734 , 1172
    -26262 , 1116
    -29049 , 1132
    -31081 , 1098
    -32325 , 1121
    -32765 , 1097
    -32391 , 1117
    -31207 , 1105
    -29251 , 1110
    -26540 , 1125
    -23152 , 1114
    -19163 , 1132
    -14659 , 1126
    -9776 , 1133
    -4647 , 1124
    615 , 1139
    5861 , 1122
    10931 , 1129
    15715 , 1120
    20064 , 1109
    23885 , 1108
    27095 , 1095
    29634 , 1100
    31445 , 1091
    32489 , 1085
    32756 , 1086
    32243 , 1073
    30978 , 1075
    28981 , 1082
    26303 , 1075
    23003 , 1081
    19147 , 1083
    14854 , 1073
    10212 , 1083
    5304 , 1085
    257 , 1089
    -4815 , 1091
    -9776 , 1093
    -14496 , 1089
    -18879 , 1098
    -22806 , 1090
    -26171 , 1090
    -28907 , 1090
    -30928 , 1070
    -32214 , 1077
    -32748 , 1048
    -32539 , 1059
    -31611 , 1028
    -30028 , 1012
    -27842 , 1004
    -25131 , 980
    -21996 , 962
    -18521 , 937
    -14788 , 923
    -10909 , 887
    -6965 , 872
    -3050 , 828
    753 , 803
    4378 , 755
    7760 , 721
    10824 , 648
    13570 , 619
    15969 , 533
    18009 , 490
    19754 , 425
    21186 , 360
    22377 , 324
    23384 , 280
    24270 , 271
    25086 , 261
    25896 , 292
    26727 , 305
    27607 , 371
    28543 , 407
    29505 , 483
    30454 , 529
    31319 , 589
    32039 , 638
    32542 , 681
    32760 , 729
    32631 , 767
    32101 , 795
    31143 , 813
    29709 , 863
    27795 , 861
    25391 , 911
    22501 , 908
    19183 , 939
    15418 , 964
    11298 , 973
    6871 , 1003
    2259 , 996
    -2479 , 1038
    -7241 , 1027
    -11863 , 1046
    -16249 , 1038
    -20287 , 1051
    -23860 , 1028
    -26965 , 1091
    -29448 , 1020
    -31241 , 1052
    -32345 , 997
    -32761 , 1024
    -25893 , 8468
    6822 , 7274
    29198 , 5226
    32434 , 3380
    27791 , 2462
    21326 , 1805
    15583 , 1186
    11033 , 951
    6994 , 850
    3061 , 857
    -955 , 865
    -4982 , 869
    -8975 , 883
    -12863 , 887
    -16526 , 872
    -19949 , 896
    -23080 , 887
    -25829 , 888
    -28185 , 906
    -30090 , 896
    -31526 , 943
    -32441 , 953
    -32766 , 988
    -32435 , 1048
    -31374 , 1062
    -29434 , 1215
    -26308 , 1367
    -21469 , 1689
    -13679 , 2295
    -1075 , 3291
    16073 , 4369
    29631 , 4296
    32509 , 3655
    26996 , 3048
    17835 , 2467
    8599 , 1886
    1111 , 1367
    -4622 , 1095
    -9374 , 992
    -13651 , 968
    -17546 , 933
    -21047 , 929
    -24142 , 907
    -26783 , 896
    -28956 , 887
    -30644 , 871
    -31838 , 860
    -32545 , 857
    -32765 , 846
    -32508 , 846
    -31782 , 838
    -30609 , 834
    -29005 , 834
    -26997 , 833
    -24608 , 834
    -21869 , 836
    -18822 , 834
    -15507 , 834
    -11968 , 837
    -8266 , 832
    -4454 , 836
    -597 , 823
    3255 , 829
    7043 , 817
    10706 , 814
    14190 , 801
    17444 , 793
    20423 , 775
    23111 , 767
    25470 , 744
    27494 , 733
    29184 , 714
    30522 , 685
    31527 , 669
    32219 , 638
    32622 , 617
    32764 , 593
    32670 , 573
    32369 , 542
    31885 , 534
    31232 , 515
    30428 , 508
    29474 , 504
    28364 , 511
    27085 , 519
    25615 , 541
    23936 , 560
    22023 , 593
    19849 , 619
    17401 , 658
    14653 , 694
    11622 , 724
    8326 , 759
    4789 , 790
    1042 , 823
    -2843 , 844
    -6805 , 875
    -10748 , 880
    -14591 , 908
    -18277 , 920
    -21672 , 919
    -24733 , 945
    -27379 , 935
    -29553 , 959
    -31210 , 968
    -32289 , 973
    -32751 , 1004
    -32557 , 1008
    -31657 , 1067
    -29981 , 1102
    -27464 , 1165
    -23890 , 1319
    -19108 , 1411
    -12696 , 1744
    -3687 , 2260
    8575 , 3042
    22967 , 4146
    32206 , 4409
    30074 , 3918
    19644 , 3382
    6362 , 2904
    -6406 , 2602
    -16873 , 2230
    -24496 , 2031
    -29500 , 1845
    -32127 , 1699
    -32735 , 1689
    -31505 , 1610
    -28635 , 1610
    -24304 , 1586
    -18760 , 1588
    -12341 , 1549
    -5348 , 1572
    1965 , 1572
    9222 , 1591
    16151 , 1639
    22400 , 1693
    27672 , 1859
    31410 , 2023
    32757 , 2344
    30363 , 2748
    22796 , 3096
    10152 , 3285
    -4995 , 3287
    -18568 , 3025
    -27700 , 2659
    -32023 , 2261
    -32679 , 1763
    -31286 , 1440
    -28856 , 1254
    -25738 , 1186
    -22042 , 1141
    -17878 , 1114
    -13354 , 1097
    -8576 , 1079
    -3600 , 1093
    1438 , 1070
    6472 , 1105
    11398 , 1091
    16035 , 1100
    20311 , 1109
    24082 , 1095
    27262 , 1109
    29770 , 1098
    31531 , 1085
    32523 , 1069
    32750 , 1062
    32241 , 1035
    31053 , 1009
    29253 , 994
    26907 , 970
    24082 , 965
    20883 , 924
    17433 , 902
    13815 , 864
    10176 , 813
    6644 , 753
    3380 , 663
    546 , 554
    -1621 , 375
    -2868 , 160
    -2893 , -149
    -1477 , -457
    1224 , -698
    4739 , -814
    8283 , -735
    11227 , -587
    13226 , -335
    14151 , -100
    14060 , 145
    12937 , 383
    10860 , 572
    7943 , 733
    4390 , 818
    402 , 898
    -3855 , 930
    -8157 , 947
    -12411 , 976
    -16504 , 982
    -20316 , 996
    -23770 , 1009
    -26761 , 1013
    -29214 , 1025
    -31065 , 1029
    -32257 , 1036
    -32752 , 1036
    -32535 , 1039
    -31606 , 1040
    -29989 , 1035
    -27713 , 1044
    -24836 , 1032
    -21413 , 1046
    -17525 , 1029
    -13291 , 1031
    -8776 , 1027
    -4105 , 1017
    596 , 1001
    5223 , 992
    9655 , 961
    13764 , 927
    17492 , 894
    20576 , 732
    22967 , 642
    24244 , 146
    23071 , -873
    14630 , -3596
    -1426 , -3515
    -14010 , -2076
    -20415 , -1165
    -23390 , -552
    -24228 , 29
    -23359 , 511
    -21014 , 856
    -17552 , 984
    -13485 , 997
    -9114 , 1001
    -4553 , 999
    56 , 984
    4658 , 994
    9173 , 988
    13513 , 997
    17582 , 988
    21301 , 997
    24603 , 992
    27416 , 1001
    29689 , 1003
    31357 , 999
    32389 , 1005
    32763 , 1019
    32453 , 1020
    31454 , 1029
    29759 , 1047
    27385 , 1054
    24357 , 1074
    20723 , 1079
    16536 , 1106
    11892 , 1108
    6884 , 1136
    1608 , 1148
    -3793 , 1170
    -9192 , 1195
    -14445 , 1223
    -19392 , 1258
    -23834 , 1287
    -27615 , 1351
    -30518 , 1397
    -32302 , 1467
    -32733 , 1541
    -31577 , 1615
    -28689 , 1666
    -24014 , 1762
    -17694 , 1778
    -10177 , 1797
    -1959 , 1798
    6219 , 1724
    13810 , 1704
    20345 , 1594
    25501 , 1524
    29273 , 1466
    31637 , 1382
    32686 , 1336
    32549 , 1252
    31412 , 1186
    29499 , 1086
    27095 , 976
    24378 , 914
    21652 , 732
    19407 , 504
    18172 , 142
    18297 , -205
    20159 , -779
    23402 , -1086
    26857 , -1233
    29543 , -1052
    31130 , -770
    31885 , -424
    32140 , -87
    32069 , 236
    31664 , 514
    30801 , 724
    29336 , 869
    27275 , 898
    24669 , 942
    21553 , 949
    18009 , 959
    14072 , 980
    9805 , 986
    5391 , 959
    935 , 961
    -3356 , 880
    -7345 , 854
    -10998 , 778
    -14106 , 666
    -16591 , 539
    -18422 , 390
    -19629 , 246
    -20263 , 96
    -20326 , -61
    -19904 , -166
    -19169 , -224
    -18298 , -228
    -17594 , -131
    -17301 , -14
    -17578 , 156
    -18588 , 364
    -20233 , 510
    -22351 , 685
    -24733 , 786
    -27061 , 848
    -29167 , 922
    -30889 , 945
    -32102 , 1003
    -32713 , 1034
    -32622 , 1075
    -31758 , 1102
    -30080 , 1129
    -27557 , 1174
    -24207 , 1186
    -20079 , 1223
    -15246 , 1244
    -9830 , 1273
    -3924 , 1320
    2290 , 1347
    8575 , 1388
    14726 , 1439
    20463 , 1487
    25474 , 1548
    29433 , 1617
    31980 , 1688
    32754 , 1765
    31452 , 1851
    27890 , 1919
    22170 , 1945
    14636 , 1989
    5898 , 1971
    -3125 , 1911
    -11658 , 1855
    -19011 , 1728
    -24778 , 1622
    -28916 , 1518
    -31468 , 1394
    -32635 , 1320
    -32622 , 1242
    -31613 , 1180
    -29758 , 1145
    -27189 , 1106
    -23997 , 1095
    -20287 , 1070
    -16168 , 1060
    -11711 , 1052
    -7051 , 1034
    -2291 , 1028
    2447 , 1004
    7080 , 1004
    11522 , 982
    15671 , 974
    19483 , 965
    22868 , 942
    25800 , 939
    28244 , 923
    30171 , 915
    31567 , 899
    32427 , 892
    32760 , 900
    32564 , 880
    31848 , 894
    30643 , 860
    28990 , 867
    26907 , 854
    24445 , 849
    21628 , 852
    18546 , 823
    15222 , 840
    11716 , 810
    8077 , 826
    4322 , 814
    502 , 828
    -3362 , 832
    -7222 , 846
    -11051 , 864
    -14794 , 884
    -18381 , 902
    -21766 , 937
    -24864 , 958
    -27560 , 977
    -29789 , 1015
    -31460 , 1039
    -32473 , 1060
    -32759 , 1095
    -32258 , 1102
    -30940 , 1129
    -28789 , 1151
    -25813 , 1179
    -22024 , 1209
    -17477 , 1242
    -12271 , 1268
    -6559 , 1292
    -465 , 1338
    5725 , 1327
    11816 , 1386
    17582 , 1388
    22684 , 1396
    26946 , 1427
    30141 , 1413
    32105 , 1421
    32766 , 1420
    32083 , 1425
    30082 , 1428
    26814 , 1447
    22363 , 1463
    16867 , 1493
    10492 , 1524
    3492 , 1555
    -3855 , 1600
    -11204 , 1645
    -18083 , 1665
    -24053 , 1701
    -28701 , 1712
    -31672 , 1718
    -32762 , 1726
    -31915 , 1674
    -29282 , 1653
    -25099 , 1615
    -19689 , 1587
    -13417 , 1541
    -6701 , 1490
    144 , 1464
    6853 , 1433
    13117 , 1392
    18769 , 1389
    23595 , 1335
    27467 , 1336
    30326 , 1307
    32074 , 1260
    32756 , 1280
    32382 , 1217
    31033 , 1219
    28816 , 1160
    And i'm reading .wav file from sd card. I modified the code to read sd .wav
    AudioPlaySdWav           playSdWav1;
    AudioPLL                 PLL;
    AudioConnection c2(playSdWav1,0, PLL,0);
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    // Use these with the Teensy 3.5 & 3.6 SD card
    //#define SDCARD_CS_PIN    BUILTIN_SDCARD
    //#define SDCARD_MOSI_PIN  11  // not actually used
    //#define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
    // Use these with the Teensy Adaptor
    //#define SDCARD_CS_PIN    10
       audioShield.volume(0.5);
       SPI.setMOSI(SDCARD_MOSI_PIN);
       SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
       AudioMemory(20);
    //   float frequency = 500;
    //   float amplitude = 0.5;
    //   ReferenceInput.frequency(frequency);
    //   ReferenceInput.amplitude(amplitude);
    //  playSdWav1.play("FE55L.WAV");
      playSdWav1.play("FE55M.WAV");
    //  playSdWav1.play("FE55LW.WAV");
    //  playSdWav1.play("FE53L.wav");
    //  playSdWav1.play("FE53M.WAV");
    //  playSdWav1.play("FE53LW.WAV");
    //  playSdWav1.play("FE52L.WAV");
    //  playSdWav1.play("FE52M.WAV");
    //  playSdWav1.play("FE52LW.WAV");
    //  playSdWav1.play("FE49L.WAV");
    //  playSdWav1.play("FE49M.WAV");
    //  playSdWav1.play("FE49LW.WAV");
    //  playSdWav1.play("FE47L.WAV");
    //  playSdWav1.play("FE47M.WAV");
    //  playSdWav1.play("FE47LW.WAV");
    //  playSdWav1.play("FE46L.WAV");
    //  playSdWav1.play("FE46M.WAV");
    //  playSdWav1.play("FE46LW.WAV");
      PLL.enable();
    //   PLL.quadratureOutputs();     // Output quadrature outputs
    //  ReferenceInput.frequency(350.);
    //  delay(3000);
    //  ReferenceInput.frequency(1500.);
    //  delay(3000);
    .wav file if needed
    May 2016
    256
    The documentation will tell you what the two channels on the Serial Monitor output are in "analysis" mode: the first is the output waveform from the synthesizer, the second is the instantaneous frequency (dPhase/dt) in Hz, reported at 44.1ksamples/sec. Now I have absolutely no idea what is actually on your files - or its integrity/validity, so I can't interpret the data.
    I did make several spot checks where I compared the indicated frequency (column 2), and the period (in samples) of the osc. output, and that all seems to make sense. However, the indicated frequency seems to be changing very fast, so I question whether the PLL is failing to lock, OR whether there is anything in the data to lock on to? It would be much better to look at the graphical output on the Serial Plotter instead of the numbers on the Monitor. The big question is: what do we really expect to see? Only you can answer that.
    What you really need to do is find a way of plotting your raw .wav data right on top of the PLL synthesizer output (allowing for processing loop delays) so you can see directly whether the PLL frequency is following the input signal. You could do it on a 'scope, or on the Serial Plotter. It would be very easy to do, but I don't have time to do it just now. Maybe in a few days...
    May 2016
    256
    @Wicky21
    I just took a look at your data. I think it might not be quite as you imagine it! It might be quite interesting from an entomological point of view but this particular data set is DEFINITELY NOT suited to FFT type spectral analysis! Remember that FFT's rely on the fact that there are NO changes in the spectral content, or time-domain statistics, within the data record. Otherwise the results are simply garbage! And that is what I assert is probably happening with your analysis, at least in this particular record. (I think it is an interesting question as to what is happening acoustically - are you REALLY seeing the wing beat frequency, or just acoustic non-linear effects of micro-turbulence and flexural dynamics of the wing membrane generating acoustic energy at random frequencies. I, of course, have no idea )
    I read Female55_Mid.wav into MATLAB, and plotted out segments in 1000 sample blocks. What I see is that there are many, many very short data segments with obviously different spectral characteristics, and sudden switches between them. For example, here is a plot of samples 117300 - 118300:
    Note that 1000 samples represents just 1/44.1 secs (or 22.7 msec) of data. There is an apparent sudden switch in the center of the plot, where the lower frequency on the left computes to a period of (533-40)/9 samples, or a frequency of 805 Hz, while on the right hand side it looks almost like its second-harmonic, with a period of (982-533)/16 samples, or a frequency of 1571 Hz. My quick look through your data shows this sort of thing happening over and over. This will completely mess up any FFT analysis... No wonder your Audacity spectrum was so wide.
    These frequencies I see here are also much higher than you have suggested in earlier posts.
    I also think that this is what I see happening in the PLL output data you posted - sudden jumps in frequency in the same broad frequency band of 500-1500 Hz.
    BUT what is clear is that if this particular .wav file is typical, then the mosquito data is NOT suitable for FFT type spectral analysis to determine wing beat frequency because it is not statistically "stationary". You will always get numbers out, but you must ask yourself if those numbers mean anything.
    Jul 2017
    120
    The main reason im using PLL is to identify the presence of a species and start to record when PLL get lock.(lock in the sense just trigger. No need to keep lock for a long time) Once I have done hardware PLL by using LM567. In that case I made center freq around 850Hz which has the highest amplitude of the signal after analysing spectrogram. In that case when I play the .wav file through my mobile it recognized. (As a output I only used led and it blinks until .wav is over) So this hardware PLL can only used on one center frq with limited bandwidth. So what if I use 2 or 3 Software PLL' s and identify at the same moment from each PLL gives some threshold outputs. Let's say PLL1 set threshold something like 800-890, PLL2 set threshold something like 1100-1200 like wise and check each PLL gives output at the same moment. If it gives output same moment then I can trigger hardware to start recording the sound into SD card for further analysing. What about that approach? I'm trying to use some mechanism to identify the presence.
    (Also Derek check your inbox I PM you regarding STFT. If you have time read that and rply back. )
    Oct 2012
    Portland OR
    712
    The audio library offers a FFT1024 object so you can analyze all frequencies at once. I would think that would offer the greatest flexibility when you are interested in more than one frequency.
    Jul 2017
    120
    Quote Originally Posted by JBeale View Post
    Yes im using FFT1024 for further analysis of samples. But rather than that thought about other mechanisms something like PLL for real time capturing frequencies. Without high end of processing.
    May 2016
    256
    I was very curious to see how my AudioPLL block actually did on tracking the mosquito wing data, so I modified it to stream the input data and the synthesizer output to the Serial Plotter, and recorded the output from Female55_mid.zip. As I found from my quick scan in MATLAB above, that input file is a complete mess with large frequency jumps all over the place. A sample PLL output is shown here:
    The blue line is from the raw input file, the red is the PLL synthesizer output. Again we see a large frequency jump, this time downwards, halfway through this 500 sample segment. As far as I am concerned, the PLL has done a remarkable job of tracking the phase in this data file. Remember, we don't expect the traces to overlay one another, 1) because the synthesizer is a fixed amplitude device (in steady-state), and 2) we expect the dynamics of the PLL loop-filter (feedback controller) to cause transient phase errors during phase transients in the input. I was delighted to see how well it did on a wonky waveform.
    A quick estimate on the frequency on the lefthand side shows 8 periods in approx 210 samples, which comes out as 1680 Hz at a sampling frequency of 44.1kHz. On the righthand side it's anybody's guess what is going on...
    BTW - in order to look at more data in a single screen, I have modified AudioSerialPlotter to just display every nth output to the screen, I didn't use it on the above plot but it was very handy in looking at the data in real time. I'll publish it soon.
    Jul 2017
    120
    Impressive. Keep remember all this recordings were made at noisy background.
    Here i attached another sample file. Its a different species .wav file. Can check both of .wav files have the same typical characteristics.
    Anyway i hope your PLL block can be used to identify the frequencies right?
    I mean just to capture the presence of a mosquito. Because i really needed to use your PLL on my project. I only needed to trigger the teensy to start record. At the end of the recording By using Short Time Fourier Transformation and peak analysis method can extract more information. Something like What are the exact frequency value of fundamental and harmonics. As well as the what are the Amplitude values of the each harmonics. Then i can take amplitude ratios between maximum peak harmonic to other harmonic and check whether is there any pattern.
    But i have to wait until you release your next Multiple peak detection block
    "To-do" list
    1) Report the magnitude (and possibly phase) of the peaks when they lie between lines. I have already written code (for another project) to do interpolation between spectral lines using Whittaker (cardinal) interpolation, and I just need to incorporate that.
    2) Investigate the use of the Hilbert transform to produce an analytic signal, which hopefully should minimize image reflection from the negative frequency components at very low frequencies. (I also have the transform code, from yet another project)
    3) Include a detection threshold to prevent noise peaks from being included.
    BTW: What i understand was Fundamental peak cannot detect exactly by using amplitude detection method. But for duffy's noteFreq block it can capture well the fundamental. So no problem about fundamental. But Derek your multiple peak detection block can be used to identify the maximum amplitude harmonics. Since harmonics have the higher amplitudes.(refer to PM STFT i have explained it more)
    Jul 2017
    120
    Publish it soon. Anyway i have to do more experiments with species and recordings. Actually at research labs we'r capturing wing beat sound by trapping mosquito's inside a cage. By using Doppler optical or ultrasonic measurements of reflections off of the wings. Sampling around 96KHz. So what i have attached .wav files were, i just played the recorded wav files at research labs through speaker and by using Leons microphone board again i recorded through teensy at 3 different sound levels. Maybe there are some issues. I have to put the microphone inside the cage and should get some recordings.
    Anyway as i felt your PLL block is perfectly works right? Also if i input some square wave pulse it should detect fundamental and harmonic as well right? So i have another question since PLL block can identify fundamental and harmonics at which time filter parameters should change?
    May 2016
    9
    How is this going? I would like to experiment with using phased lock loops to reinforce a frequency with an arbitrary offset, was planning a hardware logic approach but I wonder if a software approach would work...
