It depends....
But if the device side (as opposed to the host side) is a 32 bit Teensy, the USB hardware has only one 1.5K pullup resistor inside the chip, internally connected to the D+ line. So unless you add external circuitry to pull up the D- line, the hardware simply isn't capable of telling the host to use low speed mode.
