Results 1 to 3 of 3
Thread: Teensy Programming without Windows Drivers
    Dec 2014
    306
    Hi all,
    perhaps the topic name wasn't the best.
    Currently we are using TyQt to program a number of teensy's on a computer with the arduino environment.
    Problem being that windows seems to spend ages installing drivers for each new teensy that is connected, so takes a while before TyQt can pick them up.
    Is there a way of programming them without having to do this?
    Thanks in advance,
    Cosford.
    Germany
    533
    The problem is that windows "installs" the driver for each combination of vid/pid and serial number. You can tell windows to use the same driver independently of the serial number of the plugged in Teensy.
    https://msdn.microsoft.com/en-us/library/windows/hardware/jj649944%28v=vs.85%29.aspx?
    f=255&MSPPError=-2147217396
    . Scroll down to IgnoreHWSerNum
    That worked for me.
    Dec 2014
    306
    That worked for me.
    Perfect. I figured that was the case. I'll give this a shot.
