Results 1 to 7 of 7
Thread: Is Paul's SerialFlash library compatible with MT29F2G01ABAGDSF-IT:G ?
    Oct 2017
    2
    I'm working on a project that require's quite a bit of memory, and I was looking at MT29F2G01ABAGDSF-IT:G as it has a 2Gbit capacity. Looking at the tests doc on the github (https://github.com/PaulStoffregen/Se...ster/tests.txt) I see that MT29F2G01ABAGDWB-IT:G is slated to be tested, but that has not been completed yet. So like the title says, does anyone know if MT29F2G01ABAGDSF-IT:G will be compatible with the library? If not, could anyone recommend a reasonably priced flash chip, with a 1-2 Gbit capacity that is compatible? I mention reasonably priced, because I'm looking to produce 1k-2k units, and the micron N25Q00AA13GSF40G is ~$13, and the spansion S70FL01GSAGMFI011 is roughly the same. The MT29F2G01ABAGDSF-IT:G has everything I need, that is if it will work with this library! Thank you for any help or advice you can offer!
    20,442
    Quote Originally Posted by bradroan View Post
    Honestly hasn't even started yet, other than buying the chip and soldering it to a test board. I simply haven't had time to do much with this library lately.
    Oct 2017
    2
    Paul, you for the reply, and thank you for writing the library, even if I don't end up getting it to work on these bigger flash chips.
    Mar 2013
    651
    That's a lot of storage space
    The fact you have to request a datasheet from Micron is a real turn off....
    Maybe poke around in this thread also, Memory-board-add-on-requirements.
    That reminds me I gotta figure out what I did with the W25Q64FVSSIG I bought a long time ago lol.
    Aug 2019
    2
    For a project I will also need a flash with 8Gbit and the family MT29F (NAND) is easily found on the market.
    I analyzed the SerialFlash library (with my basic knowledge) but it seems to me rather oriented for NOR flash rather than NAND.
    Is it correct?
    Thank you
    Pierre
    20,442
    No NAND flash chips have been tested. None of them existed when this library was created.
    Perhaps early next year (2020) I may work on SerialFlash again and update it for many newer chips. But with the recent release of Teensy 4.0, I currently have many other much higher priorities. There's only so many hours in every day....
    Unless you hear a first hand account from someone who used a NAND chip, or I (eventually) update the library, you can assume no NAND chips will work with SerialFlash.
    Aug 2019
    2
    Thank you for quick reply.
