So i got a hall sensor that reads rotations of the motor shaft.
Motor shaft has has 4 magnets on it (s n s n ) approximately 90 degrees apart.
The hall effect sensor is latching type and requires opposite pole to unlatch, outputting signal of encoder .
Now the strange part when rotating in one direction signal is normal. However when rotating in other direction the signal is not correct i will insert the pictures .
I tried to re position the sensor but no matter what i do it does the same thing.
If i flip the sensor 180 degrees it starts does exactly same thing except it switches in what direction of motor rotation it works.
Any ideas of what it might be?
