Results 1 to 6 of 6
Thread: [posted] Antenna Analyzer
    Jul 2017
    10
    This antenna analyzer can be used to find out, at which frequencies a short-wave antenna is matched to the 50 Ohm impdedance of the cable and the transceiver. This behaviour is presented by the so called "voltage standing wave ratio (VSWR)". To get this value for a frequency range, a Teensy 3.5 controls a DDS (Direct digital synthesizer) signal generator, which sweeps frequencies between 100kHz and 30 MHz. The hf voltages on the signal generator and at the antenna under test are read by the Teensy and compiled by some calculations to derive the VSWR values. The results are shown on a TFT touch display.
    Due to the fast processing speed and the huge amount of program memory, it is possible to create different pages on the TFT display, showing real-time measurements and other information.
    Details of the project can be found on my homepage.
ID:	11693 Click image for larger version.
ID:	11694Click image for larger version.
ID:	11697Click image for larger version.
ID:	11695 Click image for larger version.
    Apr 2017
    201
    Really nice job, love the professional look.
    Administrator Robin's Avatar
    Oct 2012
    PJRC Global Headquarters
    316
    This went up on the blog today
    https://www.pjrc.com/antenna-analyzer/
    1,195
    @Robin. The link to the homepage requires a login name and password.
    Pete
    Oct 2012
    316
    Pete
    I can't do anything about the link to the homepage in the original post. Hopefully @PumpkinEater will fix it.
    Jul 2017
    10
    Sorry for that. I will enable the page in the next days again. BTW, I stopped my Project because I recognized that there are some hw limitations in the design and better alternatives are available.
    Peter
