Hi All,
I'm currently playing with the concept of nested states (toggle states) and a) having an issue when returning to the original state and b) not sure if there is a better way of writing the code I currently have.
I have one button that toggles between state 0 & state 1. When I press and hold the same button for a period of 1000 ms, the toggle state then changes to state 2. Now I can toggle between state 2 & state 3. The goal is that when I press and hold the same button for another period of time, it returns back to the default state of toggling between 0 & 1. However currently the serial monitor is printing a toggle change state of 0 & 2. Which is not ideal, as would like it to return to state 0 and stay there, until the button is released. Then i can toggle between 0 & 1 again.
I understand it most likely has something to do with the 'timeStamp' variable storing millis() and the duration passed, however I can think of how to improve it.
Here is my code. Any help would be awesome
int buttonPin = 12;
int ledPin = 13;
int buttonState;
int lastButtonState;
int mode = 0;
unsigned long timeStamp = 0;
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
buttonMode();
void buttonMode() {
buttonState = digitalRead(buttonPin);
//TOGGLE PRESS
if (buttonState != lastButtonState) {
timeStamp = millis();
if (buttonState == HIGH) {
if (mode == 0) {
mode = 1;
digitalWrite(ledPin, HIGH);
if (mode == 1) {
mode = 0;
digitalWrite(ledPin, LOW);
if (mode == 2) {
mode = 3;
if (mode == 3) {
mode = 2;
Serial.printf("Button Mode: %d\n", mode);
//TIMED PRESS
if (mode == 0 || mode == 1) {
if ((millis() - timeStamp) > 1000) {
mode = 2;
if (mode == 2 || mode == 3) {
if ((millis() - timeStamp) > 2000) {
mode = 0;
lastButtonState = buttonState;
