Datasheet : http://www.ti.com/lit/ds/scds084g/scds084g.pdf
(See page 5 with diagrams)
This is a bidirectional levelshifter. According to the datasheet, the output-voltage should be about 3V. VCC is 5.19 Volt.
If I add a 1K pullup (to VCC) to a "A" pin, "B" is about 3.55 Volt, which is a little too much.. and more than stated in the datasheet. How can this be ? Am I overlooking something ?
Is 3.55 Volt OK for the Teensy 3.6 ? (Pin-config will be OUPUT_OPENDRAIN)
