Results 1 to 14 of 14
Thread: Teensy 3.2 with IIC 128x64 OLED Module
    Dec 2015
    17
    I try to use an I2C 128x64 Oled display with the Teensy 3.2
    http://www.robotshop.com/en/iic-128-...dule-blue.html
    It works perfectly with an Arduino Nano but the same code with a Teensy 3.2 gives a black sceen
    Do I need to change the code from Nano to Teensy?
    Any idea what is wrong?
    Thank you for your help.
    Germany NRW
    5,027
    Is the nano powered with 3.3V, too ?
    Do you have the needed pullup-resitors to the I2C lines attached ?
    Dec 2015
    17
    No, as I read in the spec, the operating voltage for the screen is 3.3-5v.
    You suggest to place a resistor on SCL and SDA to the 3.3v pin of the Teensy? What value? 10k?
    Thanks!
    Germany NRW
    5,027
    Yes, the teensy needs the external pullups for I2C. I'd use 3k3.
    Dec 2015
    17
    Thank you for your help, I try that ASAP
    Oct 2017
    8
    I briefly tried a couple packages with all the bells and whistles, like u8g2 https://github.com/olikraus/u8g2/ which is not Teensy friendly
    Or SSD_13XX https://github.com/sumotoy/SSD_13XX which may be the hot solution for Teensys, but doesn't handle the cheapest with SSD1306 drivers (due to lack of buffers
    One simple one with limited features that big bangs the I2C worked on first try with the under $3, 2 control wire (no reset) displays one finds on Ebay.
    It's evilOLED https://github.com/evilnick/evilOLED
    Just spotted this promising library: "Enhanced I2C library for Teensy 3.x devices "
    https://github.com/nox771/i2c_t3
    Here's the examples I just got from China, getting a few other things spreads out the big $1.85 shipping fee
    http://www.ebay.com/itm/0-96-I2C-IIC...-/311953510285
    Oct 2017
    8
    I believe the OLEDs all operate at 3.3V (Adafruit says they re all 3.3 interface safe) you can spot the little 3 lead voltage regulator chip coming off the VCC pin that drops the 5V input to 3.3. My test with bitbanged I2C was successful without pullup resistors.
    I noticed a post elsewhere that declared:
    real pullup resistors for SDA and SCL are required when using Teensy 3.x or Teensy-LC.
    Dec 2015
    17
    Does not work with pullups neither... Same code work on Arduino nano).
    Question: I've found a movie with a Teensy running without pullups...
    https://www.youtube.com/watch?v=qLCPHe3Ytko
    Dec 2015
    17
    Any clue to solve this problem? Is it possible to drive this oled display with a teensy?
    Thx
    Feb 2014
    Colmar, France
    2,114
    Sometimes, I2C works without extra pull-ups but only if the target device (the display) has integrated pull-up resistors. You should look that information up in the display’s data sheet.
    If code works on the Nano, but not with the Teensy, it might be a pin problem, but I think you made sure to use the correct pins, or a speed problem - the Teensy is incredibly faster. Which I2C data rate did you select on the Nano and which one on the Teensy?
    Dec 2015
    17
    I use this setup for both
    U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_NO_ACK|U8G_I2C_OPT_FAST);  // Fast I2C / TWI
    Feb 2014
    Colmar, France
    2,114
    You see, the problem is most probably the U8G_I2C_OPT_FAST #define. I guess it resolves much faster on the Teensy (and thus too fast for the OLED) as on the Nano. I’ll have a look into the library’s code if you tell which one of the above listed you are finally trying.
    Since the Oli Kraus library uses U8g2() as constructor, it can’t already be that one....
    Dec 2015
    17
    Indeed I am using U8glib. I have tried all samples from the library: no problem with the nano and no result with the teensy.
    You're right, the initialization of the library is probably different. I have to dig that way.
    Dec 2015
    17
    Update: work perfectly with pullup, U8g2lib and U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
