Results 1 to 14 of 14
Thread: TeensyStep build errors
    The example HelloStepper fails to compile. First error is:
    PIT.h: 30:2: error: 'KINETISK_PIT_CHANNEL_t' does not name a type
    KINETISK_PIT_CHANNEL_t* channel = nullptr
    Any suggestions on how to resolve the error?
    21,315
    Do you have the right board selected in Tools > Boards?
    If so, please give us a link to the code in question.
    https://github.com/luni64/TeensyStep...s/HelloStepper
    Teensy 3.2/3.1 is selected.
    I'm using Visual Studio 2015.
    10,595
    Try with Arduino & TeensyDuino install instance. That is easier to debug given the code if it fails.
    I didn't think I'd ever hear the Arduino IDE was easier to use
    It fails with the same error.
    21,315
    I tried just now, with Arduino 1.8.5 and Teensyduino 1.4.0, using Teensy 3.2 selected in Tools > Boards.
    It compiles without any error. Here's a screenshot.
    10,595
    Quote Originally Posted by Elf View Post
    that was easier to 'debug' - as for usage . . . that involves a user
    With VisStudio in use, assuming Windows:: For easiest w/Windows usage pull the IDE ZIP down of the version Paul used - extract to a fresh directory - install TeensyDuino 1.40 there. That should give a true starting point - uses about 650MB.
    Updating Teensyduino cured the problem.
    Jun 2017
    19
    Hi. I ereceive the same error:
    error: 'KINETISK_PIT_CHANNEL_t' does not name a type KINETISK_PIT_CHANNEL_t* channel = nullptr
    I'm running Teensy Installer Ver 1.31. I assume I need to update to a later version.
    I ran the Teensyduino 1.44 installer, and it is asking me to "Choose Arduino location to install Teensyduino". However I',not sure which folder to pick. I've tried the Aduino folder under Program Files (x86) and also the Arduini folder and users\...\documents\arduino. As I navigate through the file structure the "Next" button stays greyed out so I cannot proceed with the installation.
    Advice please.
    Germany
    718
    I assume your Arduino version is not compatible with Teensyduino 1.44. According to the homepage. Teensyduino 1.44 supports Arduino versions 1.0.6 and 1.6.5-r5 and 1.8.1 and 1.8.5 and 1.8.6 and 1.8.7. Best would be to upate Arduino to 1.8.7 and after that install Teensyduino 1.4.4
    Jun 2017
    19
    I'm running Arduino version 1.6.12
    Is there a risk that by updating to 1.8.7 that any of my previous projects will not compile ?
    Germany NRW
    6,204
    The risk is very small. If you want to be sure, why not just make a backup first.
    Germany
    718
    You can also install the new version parallel to the old version: Just download the Arduino zip file and extract it wherever you want without touching the old version.
    21,315
    Quote Originally Posted by Ausplex View Post
    Advice please.
    Each installer only recognizes a few versions of Arduino. The supported versions are shown on the first page (which nobody reads) and the website right below the download links (also a place people don't usually read). Look at either of those to see which versions of Arduino can be used. If you have a different version, you'll need to install one of the supported Arduino versions.
    As Luni mentioned, you can extract the ZIP file in a new location on your PC and then install into that copy, if you want to keep the old install intact. But if you have 2 or more copies of Arduino+Teensyduino on your PC, remember where they are located and which one you're using. Many people have gone down that path and later faced confusing problems when they double-click on a file and Windows runs a different copy of Arduino than they expected. Remember to look at the the title bar of each window, or click Help > About to check which version you're really using.
