hello folks:
I'm wondering if anyone has insight into the problem ia having trying to play raw files from spi flash.
I'm using my own board with an SGTL5000 that a Teensy 3.2 plugs into. So far it has worked perfectly to stream WAV files from SD out through the SGTL5000. I've also done wavetable synthesis, so I am thinking that hardware is OK.
Yesterday I added a Spansion S70FL256P0XMFI001 SPI flash. Erase, listfiles and copy from SD to flash all work as expected. It's screaming fast.. 1.2MB per second!
I'm now trying to get the play raw files working form SPI flash, but I am unsuccessful.
Audio files have been exported as signed, little endian, 44.1K 16 bit pcm RAW, and then exported to the newly erased SPI flash from an SD card.
When i run the code below, it always hangs when it gets to the line playFlashRaw1.play(filename).
Code is below. Thanks for any ideas you might have.
Daniel
Daniel
#include <SerialFlash.h>
AudioPlaySerialflashRaw playFlashRaw1; //xy=201.80308532714844,253.8939208984375
AudioOutputI2S i2s1; //xy=702.871337890625,260.2803039550781
AudioConnection patchCord1(playFlashRaw1, 0, i2s1, 0);
AudioConnection patchCord2(playFlashRaw1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=742.1666717529297,337.1666717529297
#define FLASH_CHIP_SELECT 6
sgtl5000_1.enable();
sgtl5000_1.volume(.7);
// Start SerialFlash
if (!SerialFlash.begin(FLASH_CHIP_SELECT)) {
while (1) {
Serial.println ("Cannot access SPI Flash chip");
delay (1000);
else {
Serial.println ("OK access to SPI Flash chip");
AudioMemory(20);
Serial.println ("exiting setup");
void playFile(const char *filename)
Serial.print("Playing file: ");
Serial.println(filename);
// Start playing the file. This sketch continues to
// run while the file plays.
Serial.print("just before the playflashraw command");
playFlashRaw1.play(filename);
Serial.print("after the playflashraw command");
// A brief delay for the library read WAV info
delay(10);
// Simply wait for the file to finish playing.
while (playFlashRaw1.isPlaying()) {
Serial.print("inside the while playing loop");
// uncomment these lines if you audio shield
// has the optional volume pot soldered
//float vol = analogRead(15);
//vol = vol / 1024;
// sgtl5000_1.volume(vol);
Serial.println ("entered main loop");
playFile("21.RAW");
playFile("30.RAW");
playFile("41.RAW");
playFile("51.RAW");
playFile("60.RAW");
