Synchronous ADC read and DMA transfer
I am a beginner in microcontroller and teensy world. I need to read say for example voltages and currrent from two ADC's synchronously for 200 samples(Or by using Timer) and transfer to DMA (should notify its able to read 200 or if its full). I dont want to use analogread() cause its blocking method. Can anyone post a pesudocode or anypointers for how to implement??
Senior Member+
You've just to study the source codes of the Teensy ADC and Audio libraries which come with each Teensyduino installation and are both available on GitHub, too.
There are many different use cases and that (known working) code is IMNSHFO the best tutorial.
- You may not post replies
- You may not edit your posts
Forum Rules
