Hello all, pretty new user wanting to try Teensy for an audio project using bluetooth connection to an android app. So basically I would like to take signals, do some processing on the teensy 3.2/3.6 then after transmit in real time the processed audio via bluetooth to the android app to visualize and listen to the processed sound. I was looking at possible bluetooth modules to use with the teensy and came across BC127 bluetooth module. This looks like a promising candidate and wanted to find out if anyone has used it with the teensy before or other alternatives for the bluetooth module that fits the teensy 3.2/3.6 (small fitting size preferrably). I'm hoping to use it two way though, to send commands from the mobile app and also transmit processed audio from the teensy. Any guide would be really appreciated.
Thanks in advance.
Thanks in advance.
