The Teensy 3.5 has the same usb host pins as the Teensy 3.6. Is it possible to use these pins to connect a usb device? Will the USB host library of the Teensy 3.6 work on the Teensy 3.5?
the pcbs are the same for both models, except theres no usb host on the 3.5's chip, you do, however, have access to 2 analog pins there, but thats about it
