oddson
Set pinMode via const array for pin numbers? (sorted sort of)
Is there a reason this will not work for me?
If I use the commented line instead it works fine.
To test I have a current-limited LED sourced by PIN12.
I was hoping to initialize a set of pins as OUTPUT with a loop. When it didn't work I determined it was not the loop but trying to read the constant array value that was failing.
Anyone have insight on this for me?
EDIT - I swear I tested this a dozen times before posting but on the first test after posting it's suddenly is working... :S
const int SO_PINS[4] = {12,1,2,3}; //array size is (M_PINS)^-2
pinMode(SO_PINS[0], OUTPUT);
//pinMode(12, OUTPUT);
digitalWrite(12,HIGH);
