Wav file play from SD card (Audio shield) conflicts with Other SPI device(DWM1000)
byungjun
Now I'm testing DWM1000 module with wav play from SD card.
Library for DWM1000 is Decaduino,
https://www.irit.fr/~Adrien.Van-Den-Bossche/decaduino/
Wav play and Decaduino ranging, each works fine but when I combine the code, it crashes.
Hardware connection is
Dwm1000 SCK --> teensy3.2 pin14
Dwm1000 MOSI --> teensy3.2 pin14
Dwm1000 MISO --> teensy3.2 pin12
Dwm1000 CS --> teensy3.2 pin15
Dwm1000 IRQ --> teensy3.2 pin16
Dwm1000 RST--> teensy3.2 pin3
Here's complete code that I'm working on.
/*Developing to Tag
   Audio file play and check noise
   Read 10times and get average
   Desitination Address(anchor_adrees[]), my_short_address
   anchor_address[4] = { 100, 101, 102, 103}
#include <SerialFlash.h>
#include <DecaDuino.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
AudioPlaySdWav           playWav1;
// Use one of these 3 output types: Digital I2S, Digital S/PDIF, or Analog DAC
AudioOutputI2S           audioOutput;
//AudioOutputSPDIF       audioOutput;
//AudioOutputAnalog      audioOutput;
AudioConnection          patchCord1(playWav1, 0, audioOutput, 0);
AudioConnection          patchCord2(playWav1, 1, audioOutput, 1);
AudioControlSGTL5000     sgtl5000_1;
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
#define my_pan_id  0
#define bat_pin 17
#define TIMEOUT 5 // ms
#define total_anchor_num 2 // for test
#define total_check_time 10 // number of ranging with anchor for averaging
#define  bat_check_interval 1000
#define  range_interval 1000
byte anchor_address[4] = { 100, 101, 102, 103};
byte anchor_number = 0;
byte channel = 1;
byte check_time = 0;
float max_distance[4] = {10.0, 10.0, 10.0, 10.0}; //maximum distance from anchor 1, 2, 3, 4
float min_distance[4] = {0, 0, 0, 0}; //minimum distance from anchor 1, 2, 3, 4
float average[4] = {0, 0, 0, 0};
float sum;
#define my_short_address 0
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define AIR_SPEED_OF_LIGHT 229702547.0
#define DW1000_TIMEBASE 15.65E-12
#define COEFF AIR_SPEED_OF_LIGHT*DW1000_TIMEBASE
#define X_CORRECTION 1.0000000
//#define Y_CORRECTION 0.230000000
#define Y_CORRECTION 0.000000000
#define TWR_ENGINE_STATE_INIT 1
#define TWR_ENGINE_STATE_WAIT_NEW_CYCLE 2
#define TWR_ENGINE_STATE_SEND_START 3
#define TWR_ENGINE_STATE_WAIT_SEND_START 4
#define TWR_ENGINE_STATE_MEMORISE_T1 5
#define TWR_ENGINE_STATE_WATCHDOG_FOR_ACK 6
#define TWR_ENGINE_STATE_RX_ON_FOR_ACK 7
#define TWR_ENGINE_STATE_WAIT_ACK 8
#define TWR_ENGINE_STATE_MEMORISE_T4 9
#define TWR_ENGINE_STATE_WATCHDOG_FOR_DATA_REPLY 10
#define TWR_ENGINE_STATE_RX_ON_FOR_DATA_REPLY 11
#define TWR_ENGINE_STATE_WAIT_DATA_REPLY 12
#define TWR_ENGINE_STATE_EXTRACT_T2_T3 13
#define TWR_ENGINE_STATE_DISPLAY 14
#define TWR_ENGINE_STATE_GET_SUM 15
#define TWR_ENGINE_STATE_CHECK_NUM_ERROR 16
#define TWR_ENGINE_STATE_DISPLAY 17
#define TWR_ENGINE_STATE_FINISH 18
#define TWR_ENGINE_STATE_UNABLE_TO_REACH_ANCHOR 19
#define TWR_ENGINE_STATE_CHECK_ONE_CYCLE 20
#define TWR_MSG_TYPE_UNKNOWN 0
#define TWR_MSG_TYPE_START 1
#define TWR_MSG_TYPE_ACK 2
#define TWR_MSG_TYPE_DATA_REPLY 3
int i;
int rxFrames;
uint64_t t1, t2, t3, t4;
int32_t tof;
DecaDuino decaduino;
uint8_t txData[128];
uint8_t rxData[128];
uint16_t rxLen;
int state;
int timeout;
float distance[4];
byte division_factor;
float bat_voltage;
int reading;
boolean ranging_flag = false;
byte num_ranging_error = 0; // how many errors amongst 10 readings
boolean ranging_error[4] = {false, false, false, false};
unsigned long last_time_check_range, last_time_check_bat,  audio_timer= 0;
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
  pinMode(13, OUTPUT);
  pinMode(A3, INPUT);
  // Audio connections require memory to work.  For more
  AudioMemory(40);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.5);
  // use altenate pins for SPI
  //https://www.pjrc.com/teensy/td_libs_SPI.html#altpins
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0, 0);
    // stop here, but print a message repetitively
    while (1) {
      display.println("Unable to access the SD card");
      display.display();
  if ( !decaduino.init() ) {
    display.println("decaduino init failed");
    display.print("TAG ");
    display.print(my_short_address);
    display.display();
    while (1) {
      digitalWrite(13, HIGH);
      delay(50);
      digitalWrite(13, LOW);
      delay(50);
  decaduino.setPanId(my_pan_id);
  decaduino.setShortAddress(my_short_address);
  decaduino.setChannel(channel);
  display.println("decaduino A initialized");
  display.print("PanID: ");
  display.println(decaduino.getPanId()); // FFFF 65535
  display.print("Short Address: ");
  display.println(decaduino.getShortAddress());
  display.print("Channel: ");
  display.println(decaduino.getChannel());
  display.display();
  // Set RX buffer
  decaduino.setRxBuffer(rxData, &rxLen);
  state = TWR_ENGINE_STATE_INIT;
  delay(2000);
  byte from_address, destination_adress;
  if (millis() > last_time_check_bat + bat_check_interval) {
    reading = analogRead(A3);
    //bat_voltage = 3.3 * reading / 1024.0;
    //bat_voltage = 3.3 * 2 * reading / 1280.0;
    bat_voltage = 3.13 * 2 * reading / 1024.0;
    last_time_check_bat = millis();
  // time to check all the anchors
  if (ranging_flag == false && millis() > last_time_check_range + range_interval) {
    anchor_number = 0; // anchor1
    check_time = 0;
    sum = 0;
    ranging_error[0] = false;
    ranging_error[1] = false;
    ranging_error[2] = false;
    ranging_error[3] = false;
    division_factor = total_check_time;
    ranging_flag = true;
    last_time_check_range = millis();
    //  blinkLED(1);
AudioNoInterrupts();
  // check all the anchors and the the average
  if (ranging_flag == true) {
    // check Range with all the anchors
    from_address = anchor_address[anchor_number]; // when receive
    destination_adress = anchor_address[anchor_number]; // when send
    getRangeFromAnchor();
AudioInterrupts();
  // check the distance and play audio
  average[0] = 4;
  int playduration = 5000;
  if( average[0] > 3 && millis() > (audio_timer + playduration)){
    playFile("SDTEST1.WAV");
    blinkLED(1);
    audio_timer = millis();
  }else if(average[0] <= 3 && millis()> (audio_timer + playduration)){
    playFile("SDTEST2.WAV");
    blinkLED(1);
void blinkLED(int times) {
  for (int i = 0; i < times; i++) {
    delay(10);
    delay(10);
void playFile(const char *filename)
  //Serial.print("Playing file: ");
  //Serial.println(filename);
  // Start playing the file.  This sketch continues to
  // run while the file plays.
  playWav1.play(filename);
  // A brief delay for the library read WAV info
  //delay(5);
  // Simply wait for the file to finish playing.
  while (playWav1.isPlaying()) {
    // uncomment these lines if you audio shield
    // has the optional volume pot soldered
    //float vol = analogRead(15);
    //vol = vol / 1024;
    // sgtl5000_1.volume(vol);
void getRangeFromAnchor() {
  switch (state) {
    case TWR_ENGINE_STATE_INIT:
      decaduino.plmeRxDisableRequest();
      state = TWR_ENGINE_STATE_WAIT_NEW_CYCLE;
    case TWR_ENGINE_STATE_WAIT_NEW_CYCLE:
      state = TWR_ENGINE_STATE_SEND_START;
    case TWR_ENGINE_STATE_SEND_START:
      // destination_address, my_address,
      txData[0] = anchor_address[anchor_number];
      txData[1] = my_short_address;
      txData[2] = TWR_MSG_TYPE_START;  // 1
      decaduino.pdDataRequest(txData, 3);
      state = TWR_ENGINE_STATE_WAIT_SEND_START;
    case TWR_ENGINE_STATE_WAIT_SEND_START:
      if ( decaduino.hasTxSucceeded() ) { ////////////////// sent data
        state = TWR_ENGINE_STATE_MEMORISE_T1;
    case TWR_ENGINE_STATE_MEMORISE_T1:
      t1 = decaduino.lastTxTimestamp;
      state = TWR_ENGINE_STATE_WATCHDOG_FOR_ACK;
    case TWR_ENGINE_STATE_WATCHDOG_FOR_ACK:
      timeout = millis() + TIMEOUT;  // 20ms is the timeout
      state = TWR_ENGINE_STATE_RX_ON_FOR_ACK;
    case TWR_ENGINE_STATE_RX_ON_FOR_ACK:
      decaduino.plmeRxEnableRequest(); //Sets transceiver mode to receive mode.
      state = TWR_ENGINE_STATE_WAIT_ACK;
    case TWR_ENGINE_STATE_WAIT_ACK:
      if ( millis() > timeout ) { ///////////////////////////////// all anchors are off
        // state = TWR_ENGINE_STATE_INIT;
        ///////////////////////////////////////////////////// timeout! go to the beginning.
        if (num_ranging_error < 2) {
          //blinkLED(1);
          num_ranging_error++;
        } else { ////////////////////////////////////////////// if it fails 3times
          state = TWR_ENGINE_STATE_UNABLE_TO_REACH_ANCHOR;
        ///////////////////////////////////////////////////////////// // we got Ack, one or more anchors are On
        //blinkLED(1);
        if ( decaduino.rxFrameAvailable() ) {
          /////////////////////////////// check if it's the one from the anchor we want
          if ( rxData[0] == my_short_address && rxData[1] == anchor_address[anchor_number] && rxData[2] == TWR_MSG_TYPE_ACK ) {
            state = TWR_ENGINE_STATE_MEMORISE_T4;
            //////////////////////////////// it's not the one from the anchor we want
            // go back and wait for another one
    case TWR_ENGINE_STATE_UNABLE_TO_REACH_ANCHOR:
      // blinkLED(1);
      ranging_error[anchor_number] = true;
      state = TWR_ENGINE_STATE_CHECK_ONE_CYCLE;
    case TWR_ENGINE_STATE_MEMORISE_T4:
      t4 = decaduino.lastRxTimestamp;
      state = TWR_ENGINE_STATE_RX_ON_FOR_DATA_REPLY;
    case TWR_ENGINE_STATE_WATCHDOG_FOR_DATA_REPLY:
    case TWR_ENGINE_STATE_RX_ON_FOR_DATA_REPLY:
      state = TWR_ENGINE_STATE_WAIT_DATA_REPLY;
    case TWR_ENGINE_STATE_WAIT_DATA_REPLY:
          if ( rxData[0] == my_short_address && rxData[1] == anchor_address[anchor_number] && rxData[2] == TWR_MSG_TYPE_DATA_REPLY ) {
            state = TWR_ENGINE_STATE_EXTRACT_T2_T3;
          } else state = TWR_ENGINE_STATE_RX_ON_FOR_DATA_REPLY;
    case TWR_ENGINE_STATE_EXTRACT_T2_T3:
      t2 = decaduino.decodeUint64(&rxData[3]);
      t3 = decaduino.decodeUint64(&rxData[9]);
      tof = (t4 - t1 - (t3 - t2)) / 2;
      distance[anchor_number] = tof * COEFF * X_CORRECTION + Y_CORRECTION;
      // if the distance is out of range then ignore this reading by making it 0
      if (distance[anchor_number] > max_distance[anchor_number] || distance[anchor_number] < min_distance[anchor_number]) {
        distance[anchor_number] = 0;
      state = TWR_ENGINE_STATE_GET_SUM;
    case  TWR_ENGINE_STATE_GET_SUM:
      // check if it's time to get the sum
      //  check_time 0~9 total_check_time = 10
      if (check_time < (total_check_time - 1)) {  // it did't reach 10 readings
        // still need to ranging the anchor
        sum +=  distance[anchor_number];
        check_time++;
      } else { // it reached 10 readings
        state = TWR_ENGINE_STATE_CHECK_NUM_ERROR;
    case TWR_ENGINE_STATE_CHECK_NUM_ERROR:
      // it reached 10times. check if the ranging_error > 5. it means we got more than 5 success.
      if ( num_ranging_error >= 4) {
        ///////////////////////////////////////////////////////////////////// get the average
        average[anchor_number] = sum / (division_factor - num_ranging_error);
        ranging_error[anchor_number] = false;
    case TWR_ENGINE_STATE_CHECK_ONE_CYCLE:
      // anchor_number 0~3
      if (anchor_number < (total_anchor_num - 1)) {
        ///////////////////////////////////////////// move on to the next anchor
        anchor_number++;
        check_time = 0;
        sum = 0;
        //////////////////////////////////////////// we finished whole(4) anchors reading
        state = TWR_ENGINE_STATE_DISPLAY;
    case TWR_ENGINE_STATE_DISPLAY:
      // We checked 1 anchor and averaged the value
      // Let's display the result and then move on to the next anchor
      // we got all the average and print them
      display.print("Bat : ");
      display.print(bat_voltage);
      //display.print(reading);
      display.println("V");
      display.println();
      for (int i = 0; i < total_anchor_num; i++) {
        display.print("anchor");
        display.print(i + 1);
        display.print(": ");
        if (ranging_error[i] == true) {
          display.println("Error");
          display.print(average[i]);
          display.println("m");
      //t4 - t1
      display.print("one cycle time : ");
      display.print( millis() - last_time_check_range);
      display.display();
      state = TWR_ENGINE_STATE_FINISH;
    case TWR_ENGINE_STATE_FINISH:
      ////////////////////////////////////////////////////////////// we checked all the sensor so change the flag and get ready
    default:
Any help regarding this issue will be highly appreciated since it's urgent project!
Best jun
Ummm, you have SCK and MOSI being on the same pin (14). Due to I2S pin assignment, the audio shield uses the alternate pins for SCK and MOSI:
  • Pin 14 for SCK (pin 13 is the normal SCK)
  • Pin 7 for MOSI (pin 11 is the normal MOSI)
  • Pin 12 for MISO (this is the normal pin)
  • Pin 15 is wired to the POT for volume control, and it has extra resistors/capacitors on the pin.
So, you need to move the CS pin to pins 0-5, 8, 16-17, 20-21 which are unused by the audio shield (of course you have used pin 3 and 16, so you need to use other pins).
You probably need to check whether the DWM1000 supports SPI transactions. I suspect it may not. If it does not, you may need to either get the author to modify it, or reset things yourself before calling the DMW1000 routines.
ah that was my typing mistake.
DWM1000 MOSI pin is connected to Teensy3.2 pin 7.
DWM1000 does support SPI and Decaduino library works without the Audio shield Wav play.
Sharing MOSI(7), MISO(12), and SCK(14) in 1 SPI bus.
youmay check the schematic below.
https://drive.google.com/open?id=0B7M3wVr_3UxPY3J2THVLR1I3U1E
Each library(DWM1000 and wav play) works fine on it's own but when it's together in the same SPI bus then it crashes.
Will I need multiple SPI bus which is dedicated to each device?
Do you suggest anything else?
Thank you very much, jun
As I said, you may need to look to see if the DWM1000 supports SPI transactions. Perhaps each device uses different SPI bus speeds or other things:
Or perhaps, either the DWM1000 or the SD devices aren't setting the CS pin to the appropriate value (high/low) in between calls.
Other than that, you are out of my depth, and one of the SPI experts would need to weigh in.
From the application note, http://thetoolchain.com/mirror/dw1000/aps019_driving_dw1000_from_8-bit_mcu_v1.0.pdf
2.4.3
SPI interface
The DW1000 transceiver is controlled through its slave SPI interface by the external microcontroller.
This slave SPI interface has a maximum SPI clock rate of 20 MHz.
And from this thread SD library in teensy audio shield is working in 25MHz right?
https://forum.pjrc.com/threads/29356-teensy-3-1-SD-SPI-clock-rates-n-such
Then maybe it's a clock issue.
May I solve this problem by editing the library somewhere?
Best, Jun
