Results 1 to 5 of 5
Thread: Digital Guitar Effects with the Audio Toolkit
    May 2017
    5
    I was wondering, before I prder a Teenay 3.6 and an audio board if it could be something possible to achieve (I guess it could) and especially how to make sure the inputs will be right. Impedance wise, a guitar input is very different from a line input. How would you adapt the input and the output of the audio board to match a guitar stompbox typical specifications?
    26,398
    Maybe this thread can help?
    https://forum.pjrc.com/threads/42678...ar-Audio-Board
    This older project might also have some good info:
    http://openeffectsproject.com/
    May 2017
    5
    Sorry for the late reply! Thanks a lot for the pointers! I think Iíll be able to get what I need in there!
    Another question: would that be possible, with the library and the teensy, to use another DAC and do higher sample rates? Like 48 or 96khz? Maybe even floating point audio?
    Feb 2014
    Colmar, France
    2,600
    Technically, a lot of things are possible. Use the forum search function to find some flora extension which someone started creating for the audio library. And if nobody did already what you need exactly, it’s up to you to develop and contribute it here.
    May 2017
    5
    Iíll dig! Iíll dig! And whatever I come up with will be shared of course
