I have Teensy 3.5 set to read Analog AO to collect voltage readings from MCP 9700A Thermister. At room temperature, I expect to see 0.70 to 0.75 volts output. Once hooked up, my oscilloscope confirmed the 0.72 reading although quite noisy.
Naively, I believed that reading the A0 pin would result in a float value of the voltage. What I actually read from Pin A0 is an integer ranging in value between 220 and 230, which tells me that the ADC has converted it. Now, I need to convert this back to a voltage to interpret as a temperature. Inc dentally, the on board temperature comes back at 220
The reading I have done on forums and datasheets suggests this is a 16 bit Pin (32768), default resolution is 10 (1024).
How do I convert a pin reading of 220 to a voltage of 0.70 volts? The math is no problem (220/1023 = 0.23) , but I am missing something??
thanks
Serial.println(myADC->analogRead(ADC_INTERNAL_SOURCE::TEMP_SENSOR));
thanks
