padvinder95
I've written a class that handles a serial-based menu and eeprom parameter storage. I would like to pass it a pointer to a serial port, so that I can decide later which port it'll be:
Problem: teensy's usb serial is not a HardwareSerial; both only inherit from Stream.
Same issue was discussed in https://forum.pjrc.com/threads/3114...ial?highlight=hardwareserial+usb_serial_class and it was suggested to use Stream and call begin in the setup() function instead of in the class init.
I can live with that. However, I would like to make use of the print and println methods, which are not part of Stream.
I've thought about overloading my class's constructor to accept a HardwareSerial* and usb_serial_class*, have those set a member pointer and set a boolean to know which one was called:
However, then I would have to replace all my p_serial->print statements… So I thought about making a helper method print() that would do this check, but then I have to define all overloaded print() methods (chars, ints, floats) and then might as well just stick with Stream and implement print() myself on that…
Any other suggestions?
class EEPROMParams{
HardwareSerial* p_serial;
EEPROMParams(HardwareSerial* ser) : p_serial(ser) {};
public:
void write_something() { p_serial->println("Hello world"); };
class EEPROMParams{
usb_serial_class* teensy_serial;
bool use_teensy_serial;
EEPROMParams(HardwareSerial* ser) : p_serial(ser), use_teensy_serial(false) {};
EEPROMParams(usb_serial_class* ser): teensy_serial(ser), use_teensy_serial(true) {};
public:
void write_something() { if(use_teensy_serial) teensy_serial->println("Hello world"); else p_serial->println("Hello world"); };
