Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: FastLed vs Neopixel vs Audio library - CPU overload?
  1. #26
    Feb 2019
    4
    Hello there,
    I have a similar problem and I think all the posts above should give me the answer, but I can't seem to find it.
    I want to build a light saber for a school project, but haven't really worked with microcontrollers in the past.
    When I 'power up' the lightsaber, the LEDs work, but the sound stops playing very shortly after and tries to start again multiple times a second. I tried implementing the things posted above and switched from FastLED to Paul's WS2812Serial library, but I must still do something wrong. The basic test example, included in the library, worked just fine.
    I use a Teensy 3.2 with a prop shield (no LC).
    I am german, so I hope you understand me. Thank you very much!
    Paul
    #include <WS2812Serial.h> //LED
    #include <Audio.h> //Audio
    #include <NXPMotionSense.h> //Motion
    #include <Wire.h> //Audio, Motion
    #include <EEPROM.h> //Motion
    #include <SPI.h> //Audio
    #include <SD.h> //Audio
    #include <SerialFlash.h> //Audio
    //LED strip
    const int numled = 144;
    const int pin = 1;
    byte drawingMemory[numled*3];         //  3 bytes per LED
    DMAMEM byte displayMemory[numled*12]; // 12 bytes per LED
    WS2812Serial leds(numled, displayMemory, drawingMemory, pin, WS2812_GRB);
    #define RED    0xFF0000
    #define GREEN  0x00FF00
    #define BLUE   0x0000FF
    #define LBLUE  0x00FFFF
    #define ORANGE 0xFF8000
    #define BLACK  0x000000
    // Taster, DG
    #define POWER_PIN 15
    #define COLOR_PIN 17
    //Audio
    #define SDCARD_CS_PIN    4
    #define SDCARD_MOSI_PIN  11
    #define SDCARD_SCK_PIN   13
    // Variable for changing colors
    int d = 0;
    int LAST_POWER_STATUS=LOW;
    // lightsaber status
    bool RUNNING = false;
    NXPMotionSense imu;
    NXPSensorFusion filter;
    //Audio
    AudioPlaySdWav           playSdWav1;
    AudioOutputAnalog        dac1;
    AudioConnection          patchCord1(playSdWav1, 0, dac1, 0);
    AudioConnection          patchCord2(playSdWav1, 1, dac1, 1);
    //Motion
    int a;
    int acc_rms;
    //function power up lightsaber
    void einschalten(int color, int wait){
       playSdWav1.play("TeensySF/out01.wav");
       delay(10); // wait for library to parse WAV info
       for (int i=0; i < leds.numPixels(); i++) {
        leds.setPixel(i, color);
        leds.show();
        delayMicroseconds(wait);
        leds.setPixel(i, RED);
      leds.show();
      RUNNING = true;
    //function power off lightsaber
    void ausschalten(int color, int wait){
      playSdWav1.play("TeensySF/in01.wav");
       for (int i=144; i >= 0; i--) {
        leds.show();
      RUNNING = false;
      int d=0;
      imu.begin();
      filter.begin(100);
      pinMode(POWER_PIN, INPUT);
      pinMode(COLOR_PIN, INPUT);
      pinMode(pin, OUTPUT);
      leds.begin();
      leds.show();
      //Audio
      AudioMemory(8);
      dac1.analogReference(EXTERNAL); // much louder!
      delay(50);             // time for DAC voltage stable
      pinMode(5, OUTPUT);
      digitalWrite(5, HIGH); // turn on the amplifier
      delay(10);             // allow time to wake up
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
    }  //Audio ende
        int POWER_PIN_STATUS=digitalRead(POWER_PIN); // LOW when pressed / HIGH not
        int COLOR_PIN_STATUS=digitalRead(COLOR_PIN);
        Serial.println(POWER_PIN_STATUS);
        int microsec = 1500 / leds.numPixels();
         //Hum
      float ax, ay, az;
      float gx, gy, gz;
      float mx, my, mz;
      float roll, pitch, heading;
      if (imu.available()) {
        // Read the motion sensors
        imu.readMotionSensor(ax, ay, az, gx, gy, gz, mx, my, mz);
        // Update the SensorFusion filter
        filter.update(gx, gy, gz, ax, ay, az, mx, my, mz);
        // print the heading, pitch and roll
        roll = filter.getRoll();
        pitch = filter.getPitch();
        heading = filter.getYaw();
        Serial.print("Orientation: ");
        Serial.print(heading);
        Serial.print(" ");
        Serial.print(pitch);
        Serial.print(" ");
        Serial.println(roll);
        a=abs(roll/3);
        Serial.print(" ");
        acc_rms=sqrt(ax*ax+ay*ay+az*az)/3;
        Serial.println(acc_rms);
        //condition clash activation
        if(acc_rms==1 && RUNNING)
          leds.show();
          Serial.println("ShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShakeShake");
          // power on and off button
        if(POWER_PIN_STATUS != LAST_POWER_STATUS && POWER_PIN_STATUS == LOW){
          if(RUNNING){
            ausschalten(BLACK, microsec);
          }else {
            einschalten(RED, microsec);
        LAST_POWER_STATUS = POWER_PIN_STATUS;
        // different running colors
        if(RUNNING && d==0) {
          leds.show();
          Serial.println("Just runnin red");
        if(RUNNING && d==1) {
          leds.setPixel(i, GREEN);
          leds.show();
          Serial.println("Just runnin green");
         if(RUNNING && d==2) {
          leds.setPixel(i, LBLUE);
          leds.show();
          Serial.println("Just runnin light blue");
         if(RUNNING && d==3) {
          leds.setPixel(i, BLUE);
          leds.show();
          Serial.println("Just runnin blue");
        if(RUNNING && d==4) {
          leds.setPixel(i, ORANGE);
          leds.show();
          Serial.println("Just runnin orange");
       if (  RUNNING) { //
        Serial.println("Start playing");
        playSdWav1.play("SmthJedi/hum01.wav");
        delay(10); // wait for library to parse WAV info}
        if(COLOR_PIN_STATUS==LOW && RUNNING)
          {d++;
          delay(200);}
          Serial.println(d);
        if (RUNNING == false) d=0;
        if (d == 5) d = 0;
  2. #27
    Feb 2019
    4
    I implemented Bounce 2 and now the sound does not stop after a short time. Next I want to get rid of alle the unnecessary delays and replace them with millis and I have to get rid of the gap between the start up sound and the humming.
    Another problem that occured now is, that by pressing my color switch button once, it is registered as two pushes.
    But I am happy that things are getting better. It seems like the sheer thought of you helping me out already helps me
    #include <Bounce2.h>
    //LED strip
    const int pin = 1;
    // Taster, DG
    // Instantiate two Bounce objects
    Bounce debouncer1 = Bounce(); //Power Pin
    Bounce debouncer2 = Bounce(); //Color Pin
    //Audio
    int d = 0;
    NXPMotionSense imu;
    //Audio
    //Motion
    int a;
    int acc_rms;
        leds.show();
      leds.show();
      RUNNING = true;
        leds.show();
      RUNNING = false;
      int d=0;
      imu.begin();
      filter.begin(100);
      pinMode(POWER_PIN, INPUT_PULLUP);
      debouncer1.attach(POWER_PIN); //POWER_PIN is assigned to debouncer1
      debouncer1.interval(10); //interval
      pinMode(COLOR_PIN, INPUT_PULLUP);
      debouncer2.attach(COLOR_PIN); //COLOR_PIN is assigned to debouncer2
      debouncer2.interval(10);
      leds.begin();
      leds.show();
      //Audio
      AudioMemory(8);
      pinMode(5, OUTPUT);
        while (1) {
    }  //Audio ende
       // update Bounce instances
      debouncer1.update();
      debouncer2.update();
        int POWER_PIN_STATUS=debouncer1.read(); // LOW when pressed / HIGH not
        int COLOR_PIN_STATUS=debouncer2.read();
         //Hum
      float ax, ay, az;
      float gx, gy, gz;
      float mx, my, mz;
        Serial.print(" ");
        Serial.print(" ");
        a=abs(roll/3);
        Serial.print(" ");
          leds.show();
          if(RUNNING){
          }else {
          leds.show();
          leds.show();
          leds.show();
          leds.show();
          leds.show();
       if (playSdWav1.isPlaying() == false  &&  RUNNING) { //
          {d++;
          delay(200);}
          Serial.println(d);
        if (d == 5) d = 0;
  3. #28
    2,943
    You might want to use the Bounce2 function fell that returns true when the pin returns LOW for the first time after debouncing. Similarly, rose returns true when the pin transitions from LOW to HIGH.
  4. #29
    Feb 2019
    4
    Thank you for the tip, I've looked through many threads and it's amazing how fast you are with replying to problems.
    I'll try fell() and rose() out later. For now I kind of cheated, by changing the code so that the colors changes when the counter goes up by two.
  5. #30
    Feb 2019
    4
    Unfortunately there is another problem occuring, after a while, but almost always after shaking the teensy to trigger the clash-action, it crashes. I thought the motion sensor might be the problem's cause, but commenting these parts out didn't make a difference.
    Does anyone have any advice for me or is able to find the root of the problem?
    #include <Bounce2.h> //reading button status won't interfere with sound
    #include <millisDelay.h> // used to avoid delays
    #include <EEPROM.h> //Motion, access the calibrated motion sensor data stored in eeprom
    //LED strip
    const int pin = 1;
    #define REDF   0x780707
    #define GREENF  0x009c00
    #define BLUEF   0x0505ab
    #define LBLUEF  0x07a3a3
    //Flicker
    float delayStart = 0; // the time the delay started
    bool delayRunning = false; // true if still waiting for delay to finish
    bool flicker = false; // keep track of the led state
    // Taster & DG
    //Audio
    long randclsh;
    int d = 0;
    //Audio
    AudioPlaySdWav           playSdWav1;     //xy=72,268
    AudioPlaySdWav           playSdWav2;     //xy=79,388
    AudioEffectFade          fade2;          //xy=215,304
    AudioEffectFade          fade1;          //xy=220,229
    AudioMixer4              mixer1;         //xy=358,250
    AudioOutputAnalog        dac1;           //xy=527,254
    AudioConnection          patchCord1(playSdWav1, 0, fade1, 0);
    AudioConnection          patchCord2(playSdWav1, 1, fade2, 0);
    AudioConnection          patchCord3(playSdWav2, 0, mixer1, 1);
    AudioConnection          patchCord4(playSdWav2, 1, mixer1, 3);
    AudioConnection          patchCord5(fade2, 0, mixer1, 2);
    AudioConnection          patchCord6(fade1, 0, mixer1, 0);
    AudioConnection          patchCord7(mixer1, dac1);
    //Motion
    NXPMotionSense imu;
    int a;
    int acc_rms;
       playSdWav2.play("SmthJedi/out01.wav");
        fade1.fadeIn(100);
        fade2.fadeIn(100);
        leds.show();
      leds.show();
      RUNNING = true;
      playSdWav2.play("SmthJedi/in01.wav");
        leds.show();
        fade1.fadeOut(1000);
        fade2.fadeOut(1000);
      RUNNING = false;
      int d=0;
      imu.begin();
      filter.begin(100);
     //Flicker
        flicker = false;
        delayStart = millis();
        delayRunning = true;
      leds.begin();
      leds.show();
      //Audio
      AudioMemory(8);
      pinMode(5, OUTPUT);
        while (1) {
       mixer1.gain(0, 0.5);
       mixer1.gain(1, 0.4);
       mixer1.gain(2, 0.5);
       mixer1.gain(3, 0.4);
    //Audio ende
    //currentMillis = millis();
    if ( playSdWav1.isPlaying() == false && RUNNING) { //
    //Motion
      float ax, ay, az;
      float gx, gy, gz;
      float mx, my, mz;
        Serial.print(" ");
        Serial.print(" ");
        a=abs(roll/3);
        Serial.print(" ");
        randclsh = random (1,9);
          String cstring1 = "SmthJedi/clsh0";
          String cstring2 = ".wav";
          String clsh = cstring1 + randclsh + cstring2;
     if(acc_rms==1 && RUNNING )
          playSdWav2.play(clsh.c_str());
          delay(10);
          leds.show();
          delay(random(10,80));
          Serial.println("Shake");
          if(RUNNING){
          }else {
    int DELAY_TIME = random(70,100);
          if (delayRunning && ((millis() - delayStart) >= DELAY_TIME)) {
        delayStart += DELAY_TIME; // this prevents drift in the delays
        // toggle the led
        flicker = !flicker;
        if (flicker) {
          leds.show();
        else {
         for (int i=0; i < leds.numPixels(); i=i+2) {
          leds.setPixel(i, REDF);
          leds.show();
          Serial.println("Just runnin dark red");
       if(RUNNING && d==2) {if (delayRunning && ((millis() - delayStart) >= DELAY_TIME)) {
        // toggle the led
        flicker = !flicker;
        if (flicker) {
          leds.show();
        else {
          leds.setPixel(i, GREENF);
          leds.show();
          Serial.println("Just runnin dark green");
        // toggle the led
        flicker = !flicker;
        if (flicker) {
          leds.show();
        else {
          leds.setPixel(i, BLUEF);
          leds.show();
          Serial.println("Just runnin dark blue");
         if(RUNNING && d==6) {
        // toggle the led
        flicker = !flicker;
        if (flicker) {
          leds.show();
          Serial.println("Just runnin lblue");
        else {
          leds.setPixel(i, LBLUEF);
          leds.show();
          Serial.println("Just runnin dark lblue");
          {d++;
         // delay(200);
        // Serial.println(d);
        if (d == 8) d = 0;
