silveiraGo
On Teensy 3.2
I was using the encoder library with no problems, but suddenly they are not working properly anymore. It compiles but I get this big message
In the previous versions of my code it's still working fine. I think it might be something with the Audio Library. I'm building a synthesizer.
Here is the complete code:
Ps: I'm using an external class called "line", so you'll need to comment that to compile.
In file included from /Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/Encoder/Encoder.h:41:0,
from /Users/gustavosilveira/Dropbox/Arduino (sketches)/GuitarSynth/guitarSynth11_debug/guitarSynth11_debug.ino:74:
/Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/Encoder/utility/direct_pin_read.h:7:0: warning: "PIN_TO_BASEREG" redefined
#define PIN_TO_BASEREG(pin) (portInputRegister(digitalPinToPort(pin)))
In file included from /Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD_t3.h:50:0,
from /Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD.h:2,
from /Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/Audio/play_sd_raw.h:32,
from /Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/Audio/Audio.h:99,
from /Users/gustavosilveira/Dropbox/Arduino (sketches)/GuitarSynth/guitarSynth11_debug/guitarSynth11_debug.ino:1:
/Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/ioreg.h:46:0: note: this is the location of the previous definition
#define PIN_TO_BASEREG(pin) (portOutputRegister(pin))
/Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/Encoder/utility/direct_pin_read.h:8:0: warning: "PIN_TO_BITMASK" redefined
#define PIN_TO_BITMASK(pin) (digitalPinToBitMask(pin))
/Applications/Arduino 1.8.3.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/ioreg.h:47:0: note: this is the location of the previous definition
#define PIN_TO_BITMASK(pin) (1)
#include <SerialFlash.h>
AudioSynthWaveformDc dc2; //xy=3305,4372.5
AudioSynthWaveform waveform1; //xy=3332,4065.5
AudioSynthWaveform waveform4; //xy=3334,4200.5
AudioSynthWaveform waveform3; //xy=3336,4160.5
AudioSynthWaveform waveform2; //xy=3337,4119.5
AudioSynthWaveform filterFreqMod; //xy=3473,4298.5
AudioEffectEnvelope envelope3; //xy=3516,4372.5
AudioMixer4 mixer1; //xy=3562,4132.5
AudioMixer4 mixer4; //xy=3706.5000553131104,4260.5000648498535
AudioFilterStateVariable filter1; //xy=3871,4139.5
AudioSynthWaveform AMod; //xy=3976,4334.5
AudioSynthWaveformDc dc1; //xy=3986,4402.5
AudioEffectMultiply multiply1; //xy=4109,4219.5
AudioMixer4 mixer2; //xy=4150,4343.5
AudioEffectEnvelope envelope1; //xy=4347,4221.5
AudioMixer4 mixer3; //xy=4512,4240.5
AudioOutputI2S i2s1; //xy=4701,4240.5
AudioOutputUSB usb1; //xy=4708,4300.5
AudioConnection patchCord1(dc2, envelope3);
AudioConnection patchCord2(waveform1, 0, mixer1, 0);
AudioConnection patchCord3(waveform4, 0, mixer1, 3);
AudioConnection patchCord4(waveform3, 0, mixer1, 2);
AudioConnection patchCord5(waveform2, 0, mixer1, 1);
AudioConnection patchCord6(filterFreqMod, 0, mixer4, 0);
AudioConnection patchCord7(envelope3, 0, mixer4, 1);
AudioConnection patchCord8(mixer1, 0, filter1, 0);
AudioConnection patchCord9(filter1, 0, multiply1, 0);
AudioConnection patchCord10(AMod, 0, mixer2, 0);
AudioConnection patchCord11(dc1, 0, mixer2, 1);
AudioConnection patchCord12(multiply1, envelope1);
AudioConnection patchCord13(mixer2, 0, multiply1, 1);
AudioConnection patchCord14(envelope1, 0, mixer3, 0);
AudioConnection patchCord15(mixer3, 0, i2s1, 0);
AudioConnection patchCord16(mixer3, 0, i2s1, 1);
AudioConnection patchCord17(mixer3, 0, usb1, 0);
AudioConnection patchCord18(mixer3, 0, usb1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=4471,4405.5
// PWM bit shifter
// You can choose the latch pin yourself.
const int ShiftPWM_latchPin = 8;
// ** uncomment this part to NOT use the SPI port and change the pin numbers. This is 2.5x slower **
#define SHIFTPWM_NOSPI
const int ShiftPWM_dataPin = 11;
const int ShiftPWM_clockPin = 13;
// If your LED's turn on if the pin is low, set this to true, otherwise set it to false.
const bool ShiftPWM_invertOutputs = true;
// You can enable the option below to shift the PWM phase of each shift register by 8 compared to the previous.
// This will slightly increase the interrupt load, but will prevent all PWM signals from becoming high at the same time.
// This will be a bit easier on your power supply, because the current peaks are distributed.
const bool ShiftPWM_balanceLoad = false;
// line - creates a smooth line between one value and the other
line portamentoLine; //create a line for portamento
line filterLine; //cretaes a line for the cuttof
line volumeLine; //cretaes a line for the volume
#include <ShiftPWM.h> // include ShiftPWM.h after setting the pins!
#include <Encoder.h> //makes all the work for you on reading the encoder
#include <Multiplexer4067.h> // Multiplexer CD4067 library >> https://github.com/sumotoy/Multiplexer4067
//#include <AnalogSmooth.h> // Smooths the analog input (avarages)
// Multiplexer
Multiplexer4067 multiplexer = Multiplexer4067(0, 1, 22, 21, A10);
// Oscilators
int minFreq = 40;
int maxFreq = 2000;
// OSCs
const int oscN = 4;
int oscWaveForm[oscN] = {WAVEFORM_SAWTOOTH, WAVEFORM_SQUARE, WAVEFORM_TRIANGLE, WAVEFORM_SINE}; // 0 = Saw; 1 = square; 2 = tri; 3 = sine
float oscOctave[oscN][3] = {{1, 2, 4}, {1, 2, 4}, {1, 2, 4}, {0.5, 0.25}}; //Use this numbers to multipky the frequencies, so you get different octaves
float oscFreq[oscN] = {300, 300, 300, 300};
int oscLastFreq[oscN] = {300, 300, 300, 300};
float oscLevel[oscN] = {0.1, 0.1, 0.1, 0.1};
float oscPwm[oscN] = {0.5, 0.5, 0.5, 0.5};
int oscOctaveIndex[oscN] = {0, 0, 0, 0};
//line
byte glide = 1;
int portamentoLineTime = 10;
int filterLineTime = 20;
int volumeLineTime = 10;
//Filter
int filterFreq = 15000;
float filterQ = 0.7; //from 0.7-5.0
float filterOctaves = 2;
//boolean filterMoved = false;
// filterFreqMod
int filterLFOosc = WAVEFORM_SINE;
float filterLFOfreq = 2;
float filterLFOlevel = 1;
// amplitude modulation
int AMODosc = WAVEFORM_SINE;
float AMODfreq = 7;
float AMODlevel = 0;
boolean ampModOnOff = false;
//dc
int dcLevel = 1 + AMODlevel; //dc is used to invert the level of the AM
// mixers
float mixer1Gain[oscN] = {0.5, 0, 0, 0};
//mixer 3 - final mix
float mixer3Gain[oscN] = {0.7, 0, 0, 0};
// Amp modulation mix
float mixer2Gain[oscN] = {0, 1, 0, 0};
// mixers
float mixer4Gain[oscN] = {0, 0, 0, 0}; // Filter's LFO - Filter's ADSR
//// feedback delay mixer 1
//float fdMixer1Gain1 = 0.7; // wet signal
//float fdMixer1Gain0 = 1 - fdMixer1Gain1; // dry signal
////mixers out LR
//float mixerOutGain = 0.6;
////mixer out mono
//float mixerOutMonoGain = 1;
// note on/off
boolean noteIsPlaying = false; // stores if the note ins playing or not
// delay
int delayTime = 100; // milisseconds
// Leds
const byte ledNum = 24; // total number of leds used
unsigned char maxBrightness = 255;
unsigned char pwmFrequency = 75;
unsigned int numRegisters = 3;
unsigned int numOutputs = numRegisters * 8;
unsigned int numRGBLeds = numRegisters * 8 / 3;
unsigned int fadingMode = 0; //start with all LED's off.
byte encoderLed[ledNum] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23};
// Encoders
const int encoderN = 8; //number of encoders
const int encoderNPins = encoderN * 2; //number of pins used by the encoders
const int banksN = 2; //number of banks
//this array stores the two pins of every encoder
Encoder encoder[encoderN] = {{2, 3}, {4, 5}, {6, 7}, {18, 9}, {10, 19}, {12, 20}, {14, 15}, {16, 17}};
int lastEncoderValue[banksN][encoderN] = {127};
int encoderValue[banksN][encoderN] = {127};
//Buttons
const byte buttonN = 1;
const byte totalButtons = encoderN + buttonN;
byte buttonPin[totalButtons] = {0, 1, 2, 3, 4, 5, 6, 7, 14};
int buttonVal[totalButtons] = {0};
int buttonCState[totalButtons] = {0}; // estado atual da porta digital
int buttonPState[totalButtons] = {0}; // estado previo da porta digital
// Ribbon
const byte ribbonN = 4;
byte ribbonPin[ribbonN] = {8, 9, 10, 11};
int ribbonVal[ribbonN] = {0};
float ribbonFreq[ribbonN] = {659.256, 493.883, 391.995, 293.665}; // frequencies of each ribbon
// Potentiometers
const int NPots = 2; // *coloque aqui o numero de entradas analogicas utilizadas
const int potPin[NPots] = {12, 13}; // *neste array coloque na ordem desejada os pinos das portas analogicas utilizadas
float potCState[NPots] = {0}; // estado atual da porta analogica
float potPState[NPots] = {0}; // estado previo da porta analogica
int potVar = 0; // variacao entre o valor do estado previo e o atual da porta analogica
int midiCState[NPots] = {0}; // Current state of the midi value
int midiPState[NPots] = {0}; // Previous state of the midi value
unsigned long TIMEOUT = 300; //* Amount of time the potentiometer will be read after it exceeds the varThreshold
int varThreshold = 6; //* Threshold for the potentiometer signal variation
boolean potMoving = true; // If the potentiometer is moving
unsigned long PTime[NPots] = {0}; // Previously stored time
unsigned long timer[NPots] = {0}; // Stores the time that has elapsed since the timer was reset
// debounce
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 20; // the debounce time; increase if the output flickers
// Midi values
int midiMax = 254;
int midiCh = 1;
int note = 36;
// for the encoder banks
int Bank = 0;
int lastBank = 0;
// setup
Serial.println("START");
multiplexer.begin(); // initialize o multiplexer
// Leds
// Sets the number of 8-bit registers that are used.
ShiftPWM.SetAmountOfRegisters(numRegisters);
// SetPinGrouping allows flexibility in LED setup.
// If your LED's are connected like this: RRRRGGGGBBBBRRRRGGGGBBBB, use SetPinGrouping(4).
ShiftPWM.SetPinGrouping(1); //This is the default, but I added here to demonstrate how to use the funtion
ShiftPWM.Start(pwmFrequency, maxBrightness);
//ShiftPWM.SetAll(0);
// for (int i = 0; i < encoderN; i++) {
// ShiftPWM.SetRGB(i, encoderValue[Bank][i], 0, 255 - encoderValue[Bank][i]);
// Encoders
encoder[i].write(127);
for (int z = 0; z < banksN; z++) {
lastEncoderValue[z][i] = {127};
encoderValue[z][i] = {127};
for (int i = 0; i < encoderN; i++) { //write leds to the previous bank values
// Audio stuff
AudioMemory(120);
sgtl5000_1.enable(); //starts sgtl5000
sgtl5000_1.volume(0.9); //headphones level
sgtl5000_1.lineOutLevel(30); //line level 13-31
// sgtl5000_1.audioPostProcessorEnable();
// sgtl5000_1.surroundSoundEnable(); // enables surround
// sgtl5000_1.surroundSound(7, 3); // how much surround 0-7
//start osc 1
// setOsc1(4); // 1 = saw; 2 = sqr; 3 = tri; 4 = sin; 5 = pulse
// blSaw1.begin(osc1level, osc1freq, osc1);
// blSaw1.begin(osc1freq, osc1level);
//start oscs
waveform1.begin(oscLevel[0], (oscFreq[0]*oscOctave[0][oscOctaveIndex[0]]), oscWaveForm[0]);
waveform2.begin(oscLevel[1], (oscFreq[1]*oscOctave[1][oscOctaveIndex[0]]), oscWaveForm[1]);
waveform3.begin(oscLevel[2], (oscFreq[2]*oscOctave[2][oscOctaveIndex[0]]), oscWaveForm[2]);
waveform4.begin(oscLevel[3], (oscFreq[3]*oscOctave[3][oscOctaveIndex[0]]), oscWaveForm[3]);
//start filterFreqMod
filterFreqMod.begin(filterLFOlevel, filterLFOfreq, oscWaveForm[3]);
//start amplitude modulation
AMod.begin(AMODlevel, AMODfreq, oscWaveForm[3]);
//dc - for controllinf ampMod amplitude
dc1.amplitude(dcLevel);
dc2.amplitude(1.0);
//start mixer 1 - for OCSs
for (int i = 0; i < oscN; i++) {
mixer1.gain(i, mixer1Gain[i]);
//start mixer 2 - amp mod
mixer2.gain(i, mixer2Gain[i]);
//start mixer 3 - atenuates signal from filter
mixer3.gain(i, mixer3Gain[i]);
//start mixer 4 - LFO and ADSR for the filter
mixer4.gain(i, mixer4Gain[i]);
// //filter
filter1.octaveControl(filterOctaves);
filter1.frequency(filterFreq);
// MIDI IN
// usbMIDI.setHandleControlChange(OnControlChange);
// usbMIDI.setHandleNoteOn(OnNoteOn);
// usbMIDI.setHandleNoteOff(OnNoteOff);
// usbMIDI.setHandleVelocityChange(OnVelocityChange);
// Envelelope - Sound envelope
envelope1.attack(5);
envelope1.decay(5);
envelope1.sustain(1);
envelope1.release(5);
// Envelelope - Filter envelope
envelope3.attack(200);
envelope3.decay(100);
envelope3.sustain(1);
envelope3.release(5);
//Line
volumeLine.begin();
filterLine.begin();
setWaveform(0);
Serial.println("END");
// loop
//Serial.println("LOOP");
updateButtons();
updateEncoders();
updateRibbons();
updatePotentiometers();
//volumeLine.update();
// filterLine.update();
// filter1.frequency(filterLine.getCurrentValue());
// POTENTIOMETERS
void updatePotentiometers() {
for (int i = 0; i < NPots; i++) { // Loops through all the potentiometers
// float analog = analogRead(multiplexer.readChannel(potPin[i])); //reads analog pin
// float analogSmooth = as10.smooth(analog); //smooths analog pin
// potCState[i] = analogSmooth;
potCState[i] = multiplexer.readChannel(potPin[i]); // Reads the pot and stores it in the potCState variable
midiCState[i] = map(potCState[i], 0, 1023, 0, 127); // Maps the reading of the potCState to a value usable in midi
potVar = abs(potCState[i] - potPState[i]); // Calculates the absolute value between the difference between the current and previous state of the pot
if (potVar > varThreshold) { // Opens the gate if the potentiometer variation is greater than the threshold
PTime[i] = millis(); // Stores the previous time
timer[i] = millis() - PTime[i]; // Resets the timer 11000 - 11000 = 0ms
if (timer[i] < TIMEOUT) { // If the timer is less than the maximum allowed time it means that the potentiometer is still moving
potMoving = true;
else {
potMoving = false;
if (potMoving == true) { // If the potentiometer is still moving, send the change control
if (midiPState[i] != midiCState[i]) { //sends midi cc
usbMIDI.sendControlChange(11 + i, midiCState[i], midiCh);
if (potCState[i] != potPState[i]) { // for using with the synth
//prints data if pot moves
Serial.print("Joytick ");
Serial.print(i);
Serial.print(": ");
Serial.print((int)potCState[i]);
Serial.print(" ");
potPState[i] = potCState[i]; // Stores the current reading of the potentiometer to compare with the next
midiPState[i] = midiCState[i];
//read ribbons
void readRibbons() {
for (int i = 0; i < ribbonN; i++) {
ribbonVal[i] = multiplexer.readChannel(ribbonPin[i]);
//Serial.print(ribbonVal[i]); Serial.print(" ");
//Serial.println();
//update ribbons
void updateRibbons() {
//float oscLastFreq;
readRibbons();
if (ribbonVal[i] > 10) {
// chooses the frequency and multiply by the correct octave
waveform1.frequency(map(ribbonVal[i], 0, 1023, ribbonFreq[i] * oscOctave[0][oscOctaveIndex[0]], (ribbonFreq[i] * 2.5)*oscOctave[0][oscOctaveIndex[0]]));
waveform2.frequency(map(ribbonVal[i], 0, 1023, ribbonFreq[i] * oscOctave[1][oscOctaveIndex[1]], (ribbonFreq[i] * 2.5)*oscOctave[1][oscOctaveIndex[1]]));
waveform3.frequency(map(ribbonVal[i], 0, 1023, ribbonFreq[i] * oscOctave[2][oscOctaveIndex[2]], (ribbonFreq[i] * 2.5)*oscOctave[2][oscOctaveIndex[2]]));
waveform4.frequency(map(ribbonVal[i], 0, 1023, ribbonFreq[i] * oscOctave[3][oscOctaveIndex[3]], (ribbonFreq[i] * 2.5)*oscOctave[3][oscOctaveIndex[3]]));
//just gives a note On if it got a note off before
// this way it doesn't play a thousand note ons
if (noteIsPlaying == false) {
envelope1.noteOn();
envelope3.noteOn();
//oscLastFreq = ribbonVal[i];
// Serial.println(oscLastFreq);
noteIsPlaying = true;
Serial.println("note on");
if ((ribbonVal[0] < 5) && (ribbonVal[1] < 5) && (ribbonVal[2] < 5) && (ribbonVal[3] < 5)) {
if (noteIsPlaying == true) {
//waveform1.frequency(oscLastFreq);
//Serial.println(oscLastFreq);
envelope1.noteOff();
envelope3.noteOff();
Serial.println("note off");
//read encoder buttons
void readButtons() {
for (int i = 0; i < totalButtons; i++) {
buttonVal[i] = multiplexer.readChannel(buttonPin[i]);
if (i == 8) { //inverts the joystick button value
buttonVal[i] = 1023 - buttonVal[i];
//Serial.println(buttonVal[8]);
if (buttonVal[i] > 1000) {
buttonCState[i] = HIGH;
else {
buttonCState[i] = LOW;
// read buttons
void updateButtons() {
readButtons();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (buttonCState[i] != buttonPState[i]) {
lastDebounceTime = millis();
if (buttonCState[i] == HIGH) {
if (i < encoderN) { //encoder buttons
Serial.print("Button: "); Serial.print(i + 1); Serial.println(" On");
usbMIDI.sendNoteOn(note + i, 127, midiCh); // envia NoteOn(nota, velocity, canal midi)
// Serial.print("Note: "); Serial.print(note + i); Serial.println(" On");
buttonPState[i] = buttonCState[i];
if (i == 8) { //joystick button
changeBank();
else {
usbMIDI.sendNoteOn(note + i, 0, midiCh);
Serial.print("Button: "); Serial.print(i + 1); Serial.println(" Off");
// Serial.print("Note: "); Serial.print(note + i); Serial.println(" Off");
//read encoder values
void readEncoders() { //read encoder
encoderValue[Bank][i] = encoder[i].read();
//write encoder values
void updateEncoders() { //do whatever needs to be done with the encoder values
readEncoders();
if (encoderValue[Bank][i] != lastEncoderValue[Bank][i]) {
checkEncoderValue(i); //check if it's > than 255, or < then 0
sendCC(i);
printEncoderValue(i);
writeEncoderValue(i);
lastEncoderValue[Bank][i] = encoderValue[Bank][i];
//sends encoder's midi cc
void sendCC(byte i) {
usbMIDI.sendControlChange(i, map(encoderValue[Bank][i], 0, 255, 0, 127), Bank + 1);
void checkEncoderValue(int i) {
if (encoderValue[Bank][i] > 254) {
encoderValue[Bank][i] = 254;
encoder[i].write(254);
if (encoderValue[Bank][i] < 1) {
encoderValue[Bank][i] = 1;
encoder[i].write(1);
void writeEncoderValue(byte i) {
// float encoderValueTemp = float(encoderValue[i]);
if (Bank == 0) {
if(i<4) {
mixer1Gain[i] = mapfloat(encoderValue[0][i], 1, 255, 0, 1);
Serial.print("Gain: ");
Serial.println(mixer1Gain[i]);
//print encoder values in the serial monitor
void printEncoderValue(byte i) {
Serial.print("Bank: "); Serial.print(Bank); Serial.print(" ");
Serial.print("Encoder "); Serial.print(i); Serial.print(": ");
Serial.println(encoderValue[Bank][i]);
// Changes the bank of the encoders
void changeBank() {
Bank = !Bank;
Serial.println(Bank);
// switch (Serial.read()) {
// case '0':
// Bank = 0;
// Serial.print("Bank: ");
// Serial.println(Bank);
// break;
// case '1':
// Bank = 1;
// break;
// case '2':
// Bank = 2;
// break;
// default:
// Serial.print("*Invalid number*");
// break;
encoder[i].write(encoderValue[Bank][i]);
// sets the waveform
int setWaveform (int a) {
int waveForm = 0;
switch (a) {
case 0:
waveForm = WAVEFORM_SAWTOOTH;
case 1:
waveForm = WAVEFORM_SQUARE;
case 2:
waveForm = WAVEFORM_TRIANGLE;
case 3:
waveForm = WAVEFORM_SINE;
return waveForm;
// Map float function
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
