Results 1 to 9 of 9
Thread: Output to Serial from functions in .cpp file
    Oct 2017
    3
    How can I reference and use Serial defined in main module in .cpp functions?
    22,500
    #include <Arduino.h>
    Then you can use any Arduino functions.
    Oct 2017
    3
    Thank you. Still unpredictably hangs ( like
    int Show()
      Serial.print("*");
    is ok but
    int Show()
      Serial.print("***");
    hangs forever o.O
    Dec 2016
    Montreal, Canada
    3,420
    did you even do Serial.begin() before calling that?
    2,723
    not needed for Serial (is usb serial)
    Oct 2017
    3
      // initialize serial communication at 9600 bits per second:
    // the loop routine runs over and over again forever:
      Show();
    22,500
    Nobody can meaningfully help you resolve these problems when you don't post your complete code. Since you're not using Arduino, you must also post a clear description of how you've building the code (eg, a makefile, script, exact compiler commands, etc). We have the "Forum Rule" at the top of every page for exactly this reason, to help give you the best possible help with your problem. If your program is too large or contains secret or proprietary info, the expectation is you can trim it to only a small sample which demonstrate the issue without disclosing anything confidential.
    Please, follow the Forum Rule. It saves everyone a lot of time, and it really does result in much better help for you.
    ] We have the "Forum Rule" at the top of every page for exactly this reason, to help give you the best possible help with your problem.
    I'm amazed at ho many times you have to say this, and yet, people still do not post their code! Off topic, but perhaps you should change the forum CSS to format that message in huge bold type with a yellow background.
    22,500
    Yeah, messages lacking essential info are an ongoing problem, but compared to other forums we actually do pretty well here. And the most important part, we usually do figure out issues when photos & code are posted.
    I've actually considered extra css or javascript tricks on the new topic page. Maybe someday...
