I am trying to get a NNTP time sync via esp8266 to my Teensy LC, following this guide: https://www.geekstips.com/arduino-time-sync-ntp-server-esp8266-udp/ for a word clock project.
The esp part works like a charm, putting the unix time code out over serial as message like "UNX1509820636"
But on the teensy side I got only fragments of the timecode messages, never a complete and valid timecode.
Communication speed is 115200 on both sides, I am using the latest Teensyduino 1.40.
Any help would be appreceated...
This is the code (the serial communication is at the beginning of the main loop):
(c) 2014 - Markus Backes - https://backes-markus.de/blog/
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
//Library includes
#include <FastLED.h> // library for ws2812 led arry
#include <Wire.h> // library for serial communication
#include <TimeLib.h> // library for time handling / needed for RTC and DCF77
#include <Timezone.h>
#include <DS3232RTC.h> // library for DS3231/2 RTC
#include <IRremote.h> // library for infrared remote
//#include "default_layout.h"
//#include "alt_layout1.h"
#include "alt_layout2.h" // alt. layout horizontal alternating row
// IR defines
#define ONOFF 0xFF02FD
#define AUTO 0xFFF00F
#define BLUE_DOWN 0xFF48B7
#define BLUE_UP 0xFF6897
#define BRIGHTER 0xFF3AC5
#define DIM 0xFFBA45
#define DIY1 0xFF30CF
#define DIY2 0xFFB04F
#define DIY3 0xFF708F
#define DIY4 0xFF10EF
#define DIY5 0xFF906F
#define DIY6 0xFF50AF
#define FLASH 0xFFD02F
#define QUICK 0xFFE817
#define SLOW 0xFFC837
// Touch threshold
#define TTS 50
// Sync timeout
#define SYNCTIMEOUT 1*1000 // 1min
// LED defines
#define NUM_LEDS 114
// PIN defines
#define STRIP_DATA_PIN 17 // LED strip
#define IR_RECV_PIN 11 // IR Receiver
#define ARDUINO_LED 13 //Default Arduino LED
#define LDR_PIN 15 // LDR for light level sensing
#define TOUCH_PIN 22 // touch sensor input
// RTC PINs (müssen nicht definiert werden, nur zur Info)
// SCL 19
// SDA 18
// timeout for time sync
int timestart = millis();
int timenow = 0;
boolean timeout = 0;
boolean forcedcf = 0; // 1 = kein Timeout
// led array
uint8_t strip[NUM_LEDS];
uint8_t stackptr = 0;
CRGB leds[NUM_LEDS];
// ir receiver
IRrecv irrecv = IRrecv(IR_RECV_PIN);
decode_results irDecodeResults;
// touch control
int touchNull = 0;
uint8_t selectedLanguageMode = 0;
const uint8_t RHEIN_RUHR_MODE = 0; //Define?
const uint8_t WESSI_MODE = 1;
boolean autoBrightnessEnabled = true;
// automatic brightness control via ldr
int newBrightness = 128;
int oldBrightness = 128;
int displayMode = DIY1;
CRGB defaultColor = CRGB::White;
uint8_t colorIndex = 0;
int testHours = 0;
int testMinutes = 0;
const unsigned long DEFAULT_TIME = 1506816000; // Oct 1 2017
// multitasking helper
const long oneSecondDelay = 1000;
const long halfSecondDelay = 500;
long waitUntilRtc = 0;
long waitUntilParty = 0;
long waitUntilOff = 0;
long waitUntilFastTest = 0;
long waitUntilHeart = 0;
long waitUntilTree = 0;
long waitUntilDCF = 0;
long waitUntilLDR = 0;
// switch
int modeSwitch = 1;
int set = 0;
int set2 = 0;
int dark = 0;
// forward declaration
void fastTest();
void doTouchLogic();
void clockLogic();
void doIRLogic();
void doLDRLogic();
void makeParty();
void off();
void showHeart();
void pushToStrip(int ledId);
void resetAndBlack();
void resetStrip();
void displayStripRandomColor();
void displayStrip();
void displayStrip(CRGB colorCode);
void timeToStrip(uint8_t hours,uint8_t minutes);
void doDCFLogic();
int baudRate = 115200;
char unixString[11];
long unixTime;
boolean dataSync = false;
#define DEBUG
#ifdef DEBUG
#define DEBUG_PRINT(str) Serial.println (str)
#define DEBUG_PRINTLN(str) Serial.println (str)
#else
#ifdef DEBUG
pinMode(ARDUINO_LED, OUTPUT);
pinMode(LDR_PIN, INPUT);
//setup leds incl. fastled
for(int i = 0; i<NUM_LEDS; i++) {
strip[i] = 0;
FastLED.addLeds<WS2812B, STRIP_DATA_PIN, GRB>(leds, NUM_LEDS);
resetAndBlack();
displayStrip();
touchNull = touchRead(TOUCH_PIN);
Serial1.begin(baudRate);
// get time from RTC
setSyncInterval(3600); //every hour
setSyncProvider(RTC.get); // the function to get the time from the RTC
// ende RTC
//setup ir
irrecv.enableIRIn();
// read time manually from Terminal (via USB-Serial)
if (Serial.available()) {
time_t t = processSyncMessage();
if (t != 0) {
RTC.set(t); // set the RTC and the system time to the received value
setTime(t);
// end RTC read from Serial
// read time from ESP8266 (via Serial1)
char buffer[30];
int i = 0;
// while the ESP output available, push it
// into the buffer and set the flag true
while (Serial1.available()) {
buffer[i++] = Serial1.read();
dataSync = true;
// if data is available, parse it
if (dataSync == true) {
if ((buffer[0] == 'U') && (buffer[1] == 'N') && (buffer[2] == 'X')) {
// if data sent is the UNX token, take it
unixString[0] = buffer[3];
unixString[1] = buffer[4];
unixString[2] = buffer[5];
unixString[3] = buffer[6];
unixString[4] = buffer[7];
unixString[5] = buffer[8];
unixString[6] = buffer[9];
unixString[7] = buffer[10];
unixString[8] = buffer[11];
unixString[9] = buffer[12];
unixString[10] = '\0';
// print the UNX time on the UNO serial
DEBUG_PRINT();
DEBUG_PRINTLN("NNTP Time message received form ESP: ");
DEBUG_PRINT(unixString[0]);
DEBUG_PRINT(unixString[1]);
DEBUG_PRINT(unixString[2]);
DEBUG_PRINT(unixString[3]);
DEBUG_PRINT(unixString[4]);
DEBUG_PRINT(unixString[5]);
DEBUG_PRINT(unixString[6]);
DEBUG_PRINT(unixString[7]);
DEBUG_PRINT(unixString[8]);
DEBUG_PRINT(unixString[9]);
DEBUG_PRINTLN(unixString[10]);
unixTime = atol(unixString);
// Synchronize the time with the internal clock and RTC external clock module
if (unixTime > DEFAULT_TIME) { // simple check if received time is valid (bigger than default time)
time_t loctime, utc;
TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +120};
TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +60};
Timezone ger(mesz, mez);
loctime = ger.toLocal(unixTime);
DEBUG_PRINT("Unix time: ");
DEBUG_PRINT (unixTime);
DEBUG_PRINT(" | Local time: ");
DEBUG_PRINTLN(loctime);
setTime(loctime);
RTC.set(loctime);
DEBUG_PRINT("NNTP time set");
dataSync = false;
doLDRLogic();
doTouchLogic();
doIRLogic();
switch(displayMode) {
case ONOFF:
off();
case DIY1:
clockLogic();
case DIY2:
makeParty();
case DIY3:
showHeart();
case DIY4:
showTree();
case DIY5:
fastTest();
default:
clockLogic();
void digitalClockDisplay(){
// digital clock display of the time on serial port
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
/* code to process time sync messages from the serial port */
#define TIME_HEADER "T" // Header tag for serial time sync message
unsigned long processSyncMessage() {
unsigned long pctime = 0L;
unsigned long loctime;
TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +2};
TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +1};
if(Serial.find(TIME_HEADER)) {
pctime = Serial.parseInt();
RTC.set(pctime);
Serial.print("Set time to ");
Serial.println(pctime);
loctime = ger.toLocal(pctime);
Serial.print("Set loctime to ");
Serial.println(loctime);
return loctime;
if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
pctime = 0L; // return 0 to indicate that the time is not valid
return pctime;
// end serial time setting
// Abfrage der kapazitiven Schalter
// Jeder Druck schaltet durch die vier Displaymodi
void doTouchLogic() {
//DEBUG_PRINT("doing Touch logic");
if (touchRead(TOUCH_PIN) > (touchNull + TTS) && set2 == 0) {
if ( (modeSwitch == 1) && (dark == 0) && set2 == 0 ) {
dark = 1;
DEBUG_PRINT("Dark");
displayMode = ONOFF;
off();
set2 = 1;
if ( (modeSwitch == 1) && (dark == 1) && set2 == 0 ) {
dark = 0;
DEBUG_PRINT("Light");
displayMode = DIY1;
//to force display update
testMinutes = -1;
testHours = -1;
set2 = 1;
if (dark == 0) {
modeSwitch --;
set2 = 1;
DEBUG_PRINT("-");
DEBUG_PRINT(modeSwitch);
if (touchRead(TOUCH_PIN) < (touchNull + TTS) && set2 == 1) {
set2 = 0;
if (modeSwitch > 6) {
modeSwitch = 1;
if (modeSwitch < 1) {
modeSwitch = 6;
switch(modeSwitch) {
case 1:
// Clock
displayMode = DIY1;
case 2:
// Party
displayMode = DIY2;
case 3:
// Heart
displayMode = DIY3;
case 4:
// Tree
displayMode = DIY4;
case 5:
// Test
displayMode = DIY5;
default:
displayMode = DIY1;
void doLDRLogic() {
if(millis() >= waitUntilLDR && autoBrightnessEnabled) {
DEBUG_PRINT("doing LDR logic");
waitUntilLDR = millis();
int ldrVal = map(analogRead(LDR_PIN), 0, 1000, 0, 100);
//int ldrVal = analogRead(LDR_PIN);
const int threshold = 20;
DEBUG_PRINT("Read:");
DEBUG_PRINT(analogRead(LDR_PIN));
int newBrightness = (255-(ldrVal));
if ((newBrightness > (oldBrightness+threshold)) xor (newBrightness < (oldBrightness-threshold))) {
FastLED.setBrightness(newBrightness);
FastLED.show();
oldBrightness = newBrightness;
DEBUG_PRINT("Value:");
DEBUG_PRINT(ldrVal);
DEBUG_PRINT("Brightness:");
DEBUG_PRINT(newBrightness);
waitUntilLDR += oneSecondDelay;
void doIRLogic() {
uint8_t brightness = 0;
if (irrecv.decode(&irDecodeResults)) {
DEBUG_PRINT("Received IR code");
delay(50);
switch(irDecodeResults.value) {
case ONOFF:
case AUTO:
autoBrightnessEnabled = !autoBrightnessEnabled;
case BLUE_DOWN:
//TODO
case BLUE_UP:
//TODO
case BRIGHTER:
autoBrightnessEnabled = false;
brightness = FastLED.getBrightness();
if(brightness <= 255 - 50) {
FastLED.setBrightness(brightness + 50);
FastLED.setBrightness(255);
FastLED.show();
case DIM:
if(brightness >= 50) {
FastLED.setBrightness(brightness - 50);
FastLED.setBrightness(0);
FastLED.show();
case DIY1:
displayMode = DIY1;
testMinutes = -1;
testHours = -1;
case DIY2:
displayMode = DIY2;
case DIY3:
displayMode = DIY3;
case DIY4:
displayMode = DIY4;
case DIY5:
displayMode = DIY5;
case DIY6:
displayMode = DIY6;
case FLASH:
displayMode = FLASH;
case QUICK:
defaultColor = nextColor();
displayStrip();
case SLOW:
defaultColor = prevColor();
displayStrip();
default:
DEBUG_PRINT("IR DEFAULT");
irrecv.resume();
//DISPLAY MODES
void clockLogic() {
if(millis() >= waitUntilRtc) {
DEBUG_PRINT("doing clock logic");
digitalClockDisplay();
waitUntilRtc = millis();
if(testMinutes != minute() || testHours != hour()) {
testMinutes = minute();
testHours = hour();
resetAndBlack();
timeToStrip(testHours, testMinutes);
displayStrip(defaultColor);
waitUntilRtc += oneSecondDelay;
void off() {
if(millis() >= waitUntilOff) {
DEBUG_PRINT("switching off");
waitUntilOff = millis();
resetAndBlack();
displayStrip(CRGB::Black);
waitUntilOff += halfSecondDelay;
void makeParty() {
if(millis() >= waitUntilParty) {
DEBUG_PRINT("YEAH party party");
waitUntilParty = millis();
resetAndBlack();
for(int i = 0; i<NUM_LEDS;i++) {
leds[i] = CHSV(random(0, 255), 255, 255);
FastLED.show();
waitUntilParty += halfSecondDelay;
void showHeart() {
if(millis() >= waitUntilHeart) {
DEBUG_PRINT("showing heart");
waitUntilHeart = millis();
resetAndBlack();
pushToStrip(L29); pushToStrip(L30); pushToStrip(L70); pushToStrip(L89);
pushToStrip(L11); pushToStrip(L48); pushToStrip(L68); pushToStrip(L91);
pushToStrip(L7); pushToStrip(L52); pushToStrip(L107);
pushToStrip(L6); pushToStrip(L106);
pushToStrip(L5); pushToStrip(L105);
pushToStrip(L15); pushToStrip(L95);
pushToStrip(L23); pushToStrip(L83);
pushToStrip(L37); pushToStrip(L77);
pushToStrip(L41); pushToStrip(L61);
pushToStrip(L59);
displayStrip(CRGB::Red);
waitUntilHeart += oneSecondDelay;
void showTree() {
if(millis() >= waitUntilTree) {
DEBUG_PRINT("showing x-mas tree");
waitUntilTree = millis();
resetAndBlack();
pushToStrip(L50); pushToStrip(L48); pushToStrip(L68);
pushToStrip(L32); pushToStrip(L72); pushToStrip(L33); pushToStrip(L73);
pushToStrip(L25); pushToStrip(L85);
pushToStrip(L24); pushToStrip(L84);
pushToStrip(L16); pushToStrip(L96);
pushToStrip(L17); pushToStrip(L97);
pushToStrip(L1); pushToStrip(L18); pushToStrip(L98); pushToStrip(L101);
pushToStrip(L21); pushToStrip(L38); pushToStrip(L41); pushToStrip(L58); pushToStrip(L61); pushToStrip(L78); pushToStrip(L81);
pushToStrip(L59);
displayStrip(CRGB::Green);
waitUntilTree += oneSecondDelay;
void fastTest() {
if(millis() >= waitUntilFastTest) {
DEBUG_PRINT("test test test");
waitUntilFastTest = millis();
if(testMinutes >= 60) {
testMinutes = 0;
testHours++;
if(testHours >= 24) {
testHours = 0;
//Array leeren
resetAndBlack();
testMinutes++;
waitUntilFastTest += oneSecondDelay;
CRGB prevColor() {
if(colorIndex > 0) {
colorIndex--;
return getColorForIndex();
CRGB nextColor() {
if(colorIndex < 9) {
colorIndex++;
CRGB getColorForIndex() {
switch(colorIndex) {
case 0:
return CRGB::White;
case 1:
return CRGB::Blue;
case 2:
return CRGB::Aqua;
case 3:
return CRGB::Green;
case 4:
return CRGB::Lime;
case 5:
return CRGB::Red;
case 6:
return CRGB::Magenta;
case 7:
return CRGB::Olive;
case 8:
return CRGB::Yellow;
case 9:
return CRGB::Silver;
default:
colorIndex = 0;
return CRGB::White;
void pushToStrip(int ledId) {
strip[stackptr] = ledId;
stackptr++;
void resetAndBlack() {
resetStrip();
leds[i] = CRGB::Black;
void resetStrip() {
stackptr = 0;
strip[i] = 0;
void displayStripRandomColor() {
for(int i = 0; i<stackptr; i++) {
leds[strip[i]] = CHSV(random(0, 255), 255, 255);
FastLED.show();
void displayStrip() {
void displayStrip(CRGB colorCode) {
leds[strip[i]] = colorCode;
FastLED.show();
pushES_IST();
//show minutes
if(minutes >= 5 && minutes < 10) {
pushFUENF1();
pushNACH();
} else if(minutes >= 10 && minutes < 15) {
pushZEHN1();
pushNACH();
} else if(minutes >= 15 && minutes < 20) {
pushVIERTEL();
pushNACH();
} else if(minutes >= 20 && minutes < 25) {
if(selectedLanguageMode == RHEIN_RUHR_MODE) {
pushZWANZIG();
pushNACH();
} else if(selectedLanguageMode == WESSI_MODE) {
pushZEHN1();
pushVOR();
pushHALB();
} else if(minutes >= 25 && minutes < 30) {
pushFUENF1();
pushVOR();
pushHALB();
} else if(minutes >= 30 && minutes < 35) {
pushHALB();
} else if(minutes >= 35 && minutes < 40) {
pushFUENF1();
pushNACH();
pushHALB();
} else if(minutes >= 40 && minutes < 45) {
pushZWANZIG();
pushVOR();
pushZEHN1();
pushNACH();
pushHALB();
} else if(minutes >= 45 && minutes < 50) {
pushVIERTEL();
pushVOR();
} else if(minutes >= 50 && minutes < 55) {
pushZEHN1();
pushVOR();
} else if(minutes >= 55 && minutes < 60) {
pushFUENF1();
pushVOR();
int singleMinutes = minutes % 5;
switch(singleMinutes) {
case 1:
pushONE();
case 2:
pushONE();
pushTWO();
case 3:
pushONE();
pushTWO();
pushTHREE();
case 4:
pushONE();
pushTWO();
pushTHREE();
pushFOUR();
if(hours >= 12) {
hours -= 12;
if(minutes >= 25) {
hours++;
if(minutes >= 20) {
hours++;
if(hours == 12) {
hours = 0;
//show hours
switch(hours) {
case 0:
pushZWOELF();
case 1:
if(minutes > 4) {
pushEINS(true);
pushEINS(false);
case 2:
pushZWEI();
case 3:
pushDREI();
case 4:
pushVIER();
case 5:
pushFUENF2();
case 6:
pushSECHS();
case 7:
pushSIEBEN();
case 8:
pushACHT();
case 9:
pushNEUN();
case 10:
pushZEHN();
case 11:
pushELF();
//show uhr
if(minutes < 5) {
pushUHR();
//PUSH WORD HELPER
void pushES_IST() {
pushToStrip(L9);
pushToStrip(L10);
pushToStrip(L30);
pushToStrip(L49);
pushToStrip(L50);
void pushFUENF1() {
pushToStrip(L70);
pushToStrip(L89);
pushToStrip(L90);
pushToStrip(L109);
void pushFUENF2() {
pushToStrip(L74);
pushToStrip(L85);
pushToStrip(L94);
pushToStrip(L105);
void pushNACH() {
pushToStrip(L73);
pushToStrip(L86);
pushToStrip(L93);
pushToStrip(L106);
void pushZEHN1() {
pushToStrip(L8);
pushToStrip(L11);
pushToStrip(L28);
pushToStrip(L31);
void pushVIERTEL() {
pushToStrip(L47);
pushToStrip(L52);
pushToStrip(L67);
pushToStrip(L72);
pushToStrip(L87);
pushToStrip(L92);
pushToStrip(L107);
void pushVOR() {
pushToStrip(L6);
pushToStrip(L13);
pushToStrip(L26);
void pushHALB() {
pushToStrip(L5);
pushToStrip(L14);
pushToStrip(L25);
pushToStrip(L34);
void pushFUNK() {
pushToStrip(L33);
pushToStrip(L46);
pushToStrip(L53);
pushToStrip(L66);
void pushONE() {
pushToStrip(L113);
void pushTWO() {
pushToStrip(L110);
void pushTHREE() {
pushToStrip(L111);
void pushFOUR() {
pushToStrip(L112);
void pushZWANZIG() {
pushToStrip(L48);
pushToStrip(L51);
pushToStrip(L68);
pushToStrip(L71);
pushToStrip(L88);
pushToStrip(L91);
pushToStrip(L108);
void pushZWOELF() {
pushToStrip(L61);
pushToStrip(L78);
pushToStrip(L81);
pushToStrip(L98);
pushToStrip(L101);
void pushEINS(bool s) {
pushToStrip(L4);
pushToStrip(L15);
pushToStrip(L24);
if(s) {
pushToStrip(L35);
void pushZWEI() {
pushToStrip(L75);
pushToStrip(L84);
pushToStrip(L95);
pushToStrip(L104);
void pushDREI() {
pushToStrip(L3);
pushToStrip(L16);
pushToStrip(L23);
pushToStrip(L36);
void pushVIER() {
pushToStrip(L76);
pushToStrip(L83);
pushToStrip(L96);
pushToStrip(L103);
void pushSECHS() {
pushToStrip(L2);
pushToStrip(L17);
pushToStrip(L22);
pushToStrip(L37);
pushToStrip(L42);
void pushSIEBEN() {
pushToStrip(L1);
pushToStrip(L18);
pushToStrip(L21);
pushToStrip(L38);
pushToStrip(L41);
pushToStrip(L58);
void pushACHT() {
pushToStrip(L77);
pushToStrip(L82);
pushToStrip(L97);
pushToStrip(L102);
void pushNEUN() {
pushToStrip(L39);
pushToStrip(L40);
pushToStrip(L59);
pushToStrip(L60);
void pushZEHN() {
pushToStrip(L0);
pushToStrip(L19);
pushToStrip(L20);
pushToStrip(L39);
void pushELF() {
pushToStrip(L54);
pushToStrip(L65);
pushToStrip(L74);
void pushUHR() {
pushToStrip(L80);
pushToStrip(L99);
pushToStrip(L100);
