Teensy LC Serial1
lab
I am trying to get a NNTP time sync via esp8266 to my Teensy LC, following this guide: https://www.geekstips.com/arduino-time-sync-ntp-server-esp8266-udp/ for a word clock project.
The esp part works like a charm, putting the unix time code out over serial as message like "UNX1509820636"
But on the teensy side I got only fragments of the timecode messages, never a complete and valid timecode.
Communication speed is 115200 on both sides, I am using the latest Teensyduino 1.40.
Any help would be appreceated...
This is the code (the serial communication is at the beginning of the main loop):
(c) 2014 - Markus Backes - https://backes-markus.de/blog/
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
//Library includes
#include <FastLED.h>            // library for ws2812 led arry
#include <Wire.h>               // library for serial communication
#include <TimeLib.h>            // library for time handling / needed for RTC and DCF77
#include <Timezone.h>
#include <DS3232RTC.h>          // library for DS3231/2 RTC
#include <IRremote.h>           // library for infrared remote
//#include "default_layout.h"
//#include "alt_layout1.h"
#include "alt_layout2.h"       // alt. layout horizontal alternating row
// IR defines
#define ONOFF 0xFF02FD
#define AUTO 0xFFF00F
#define BLUE_DOWN 0xFF48B7
#define BLUE_UP 0xFF6897
#define BRIGHTER 0xFF3AC5
#define DIM 0xFFBA45
#define DIY1 0xFF30CF
#define DIY2 0xFFB04F
#define DIY3 0xFF708F
#define DIY4 0xFF10EF
#define DIY5 0xFF906F
#define DIY6 0xFF50AF
#define FLASH 0xFFD02F
#define QUICK 0xFFE817
#define SLOW 0xFFC837
// Touch threshold
#define TTS 50
// Sync timeout
#define SYNCTIMEOUT 1*1000 // 1min
// LED defines
#define NUM_LEDS 114
// PIN defines
#define STRIP_DATA_PIN 17 // LED strip
#define IR_RECV_PIN 11   // IR Receiver
#define ARDUINO_LED 13   //Default Arduino LED
#define LDR_PIN 15        // LDR for light level sensing
#define TOUCH_PIN 22  // touch sensor input
// RTC PINs (müssen nicht definiert werden, nur zur Info)
// SCL 19
// SDA 18
// timeout for time sync
int timestart = millis();
int timenow = 0;
boolean timeout = 0;
boolean forcedcf = 0; // 1 = kein Timeout
// led array
uint8_t strip[NUM_LEDS];
uint8_t stackptr = 0;
CRGB leds[NUM_LEDS];
// ir receiver
IRrecv irrecv = IRrecv(IR_RECV_PIN);
decode_results irDecodeResults;
// touch control
int touchNull = 0;
uint8_t selectedLanguageMode = 0;
const uint8_t RHEIN_RUHR_MODE = 0; //Define?
const uint8_t WESSI_MODE = 1;
boolean autoBrightnessEnabled = true;
// automatic brightness control via ldr
int newBrightness = 128;
int oldBrightness = 128;
int displayMode = DIY1;
CRGB defaultColor = CRGB::White;
uint8_t colorIndex = 0;
int testHours = 0;
int testMinutes = 0;
const unsigned long DEFAULT_TIME = 1506816000; // Oct 1 2017
// multitasking helper
const long oneSecondDelay = 1000;
const long halfSecondDelay = 500;
long waitUntilRtc = 0;
long waitUntilParty = 0;
long waitUntilOff = 0;
long waitUntilFastTest = 0;
long waitUntilHeart = 0;
long waitUntilTree = 0;
long waitUntilDCF = 0;
long waitUntilLDR = 0;
// switch
int modeSwitch = 1;
int set = 0;
int set2 = 0;
int dark = 0;
// forward declaration
void fastTest();
void doTouchLogic();
void clockLogic();
void doIRLogic();
void doLDRLogic();
void makeParty();
void off();
void showHeart();
void pushToStrip(int ledId);
void resetAndBlack();
void resetStrip();
void displayStripRandomColor();
void displayStrip();
void displayStrip(CRGB colorCode);
void timeToStrip(uint8_t hours,uint8_t minutes);
void doDCFLogic();
int baudRate = 115200;
char unixString[11];
long unixTime;
boolean dataSync = false;
#define DEBUG
#ifdef DEBUG
  #define DEBUG_PRINT(str)  Serial.println (str)
  #define DEBUG_PRINTLN(str)  Serial.println (str)
#else
  #ifdef DEBUG
  pinMode(ARDUINO_LED, OUTPUT);
  pinMode(LDR_PIN, INPUT);
  //setup leds incl. fastled
  for(int i = 0; i<NUM_LEDS; i++) {
    strip[i] = 0;
  FastLED.addLeds<WS2812B, STRIP_DATA_PIN, GRB>(leds, NUM_LEDS);
  resetAndBlack();
  displayStrip();
  touchNull = touchRead(TOUCH_PIN);
  Serial1.begin(baudRate);
  // get time from RTC
  setSyncInterval(3600); //every hour
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  // ende RTC
  //setup ir
  irrecv.enableIRIn();
  // read time manually from Terminal (via USB-Serial)
  if (Serial.available()) {
    time_t t = processSyncMessage();
    if (t != 0) {
      RTC.set(t);   // set the RTC and the system time to the received value
      setTime(t);
  // end RTC read from Serial
  // read time from ESP8266 (via Serial1)
  char buffer[30];
  int i = 0;
  // while the ESP output available, push it
  // into the buffer and set the flag true
  while (Serial1.available()) {
    buffer[i++] = Serial1.read();
    dataSync = true;
  // if data is available, parse it
  if (dataSync == true) {
    if ((buffer[0] == 'U') && (buffer[1] == 'N') && (buffer[2] == 'X')) {
      // if data sent is the UNX token, take it
      unixString[0] = buffer[3];
      unixString[1] = buffer[4];
      unixString[2] = buffer[5];
      unixString[3] = buffer[6];
      unixString[4] = buffer[7];
      unixString[5] = buffer[8];
      unixString[6] = buffer[9];
      unixString[7] = buffer[10];
      unixString[8] = buffer[11];
      unixString[9] = buffer[12];
      unixString[10] = '\0';
      // print the UNX time on the UNO serial
      DEBUG_PRINT();
      DEBUG_PRINTLN("NNTP Time message received form ESP: ");
      DEBUG_PRINT(unixString[0]);
      DEBUG_PRINT(unixString[1]);
      DEBUG_PRINT(unixString[2]);
      DEBUG_PRINT(unixString[3]);
      DEBUG_PRINT(unixString[4]);
      DEBUG_PRINT(unixString[5]);
      DEBUG_PRINT(unixString[6]);
      DEBUG_PRINT(unixString[7]);
      DEBUG_PRINT(unixString[8]);
      DEBUG_PRINT(unixString[9]);
      DEBUG_PRINTLN(unixString[10]);
      unixTime = atol(unixString);
      // Synchronize the time with the internal clock and RTC external clock module
      if (unixTime > DEFAULT_TIME) { // simple check if received time is valid (bigger than default time)
        time_t loctime, utc;
        TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +120};
        TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +60};
        Timezone ger(mesz, mez);
        loctime = ger.toLocal(unixTime);
        DEBUG_PRINT("Unix time: ");
        DEBUG_PRINT (unixTime);
        DEBUG_PRINT(" | Local time: ");
        DEBUG_PRINTLN(loctime);
        setTime(loctime);
        RTC.set(loctime);
        DEBUG_PRINT("NNTP time set");
        dataSync = false;
  doLDRLogic();
  doTouchLogic();
  doIRLogic();
  switch(displayMode) {
    case ONOFF:
      off();
    case DIY1:
      clockLogic();
    case DIY2:
      makeParty();
    case DIY3:
      showHeart();
    case DIY4:
      showTree();
    case DIY5:
      fastTest();
    default:
      clockLogic();
void digitalClockDisplay(){
  // digital clock display of the time on serial port
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
    Serial.print(digits);
/*  code to process time sync messages from the serial port   */
#define TIME_HEADER  "T"   // Header tag for serial time sync message
unsigned long processSyncMessage() {
  unsigned long pctime = 0L;
  unsigned long loctime;
  TimeChangeRule mesz = {"MESZ", Last, Mon, Mar, 2, +2};
  TimeChangeRule mez = {"MEZ", Last, Mon, Oct, 3, +1};
  if(Serial.find(TIME_HEADER)) {
     pctime = Serial.parseInt();
        RTC.set(pctime);
        Serial.print("Set time to ");
        Serial.println(pctime);
        loctime = ger.toLocal(pctime);
        Serial.print("Set loctime to ");
        Serial.println(loctime);
        return loctime;
         if( pctime < DEFAULT_TIME) { // check the value is a valid time (greater than Jan 1 2013)
           pctime = 0L; // return 0 to indicate that the time is not valid
  return pctime;
// end serial time setting
// Abfrage der kapazitiven Schalter
// Jeder Druck schaltet durch die vier Displaymodi
void doTouchLogic() {
    //DEBUG_PRINT("doing Touch logic");
   if (touchRead(TOUCH_PIN) > (touchNull + TTS) && set2 == 0) {
        if ( (modeSwitch == 1) && (dark == 0) && set2 == 0 ) {
          dark = 1;
          DEBUG_PRINT("Dark");
          displayMode = ONOFF;
          off();
          set2 = 1;
        if ( (modeSwitch == 1) && (dark == 1) && set2 == 0 ) {
          dark = 0;
          DEBUG_PRINT("Light");
          displayMode = DIY1;
        //to force display update
        testMinutes = -1;
        testHours = -1;
          set2 = 1;
        if (dark == 0) {
            modeSwitch --;
            set2 = 1;
            DEBUG_PRINT("-");
            DEBUG_PRINT(modeSwitch);
    if (touchRead(TOUCH_PIN) < (touchNull + TTS) && set2 == 1) {
      set2 = 0;
    if (modeSwitch > 6) {
      modeSwitch = 1;
    if (modeSwitch < 1) {
      modeSwitch = 6;
    switch(modeSwitch) {
        case 1:
      // Clock
      displayMode = DIY1;
        case 2:
      // Party
      displayMode = DIY2;
        case 3:
      // Heart
      displayMode = DIY3;
        case 4:
      // Tree
      displayMode = DIY4;
        case 5:
      // Test
      displayMode = DIY5;
        default:
      displayMode = DIY1;
void doLDRLogic() {
  if(millis() >= waitUntilLDR && autoBrightnessEnabled) {
    DEBUG_PRINT("doing LDR logic");
    waitUntilLDR = millis();
    int ldrVal = map(analogRead(LDR_PIN), 0, 1000, 0, 100);
    //int ldrVal = analogRead(LDR_PIN);
    const int threshold = 20;
    DEBUG_PRINT("Read:");
    DEBUG_PRINT(analogRead(LDR_PIN));
    int newBrightness = (255-(ldrVal));
    if ((newBrightness > (oldBrightness+threshold)) xor (newBrightness < (oldBrightness-threshold))) {
      FastLED.setBrightness(newBrightness);
      FastLED.show();
      oldBrightness = newBrightness;
    DEBUG_PRINT("Value:");
    DEBUG_PRINT(ldrVal);
    DEBUG_PRINT("Brightness:");
    DEBUG_PRINT(newBrightness);
    waitUntilLDR += oneSecondDelay;
void doIRLogic() {
  uint8_t brightness = 0;
  if (irrecv.decode(&irDecodeResults)) {
    DEBUG_PRINT("Received IR code");
    delay(50);
    switch(irDecodeResults.value) {
      case ONOFF:
      case AUTO:
        autoBrightnessEnabled = !autoBrightnessEnabled;
      case BLUE_DOWN:
        //TODO
      case BLUE_UP:
        //TODO
      case BRIGHTER:
        autoBrightnessEnabled = false;
        brightness = FastLED.getBrightness();
        if(brightness <= 255 - 50) {
          FastLED.setBrightness(brightness + 50);
          FastLED.setBrightness(255);
        FastLED.show();
      case DIM:
        if(brightness >= 50) {
          FastLED.setBrightness(brightness - 50);
          FastLED.setBrightness(0);
        FastLED.show();
      case DIY1:
        displayMode = DIY1;
        testMinutes = -1;
        testHours = -1;
      case DIY2:
        displayMode = DIY2;
      case DIY3:
        displayMode = DIY3;
      case DIY4:
        displayMode = DIY4;
      case DIY5:
        displayMode = DIY5;
      case DIY6:
        displayMode = DIY6;
      case FLASH:
        displayMode = FLASH;
      case QUICK:
        defaultColor = nextColor();
        displayStrip();
      case SLOW:
        defaultColor = prevColor();
        displayStrip();
      default:
        DEBUG_PRINT("IR DEFAULT");
    irrecv.resume();
//DISPLAY MODES
void clockLogic() {
  if(millis() >= waitUntilRtc) {
    DEBUG_PRINT("doing clock logic");
                digitalClockDisplay();
    waitUntilRtc = millis();
    if(testMinutes != minute() || testHours != hour()) {
      testMinutes = minute();
      testHours = hour();
      resetAndBlack();
      timeToStrip(testHours, testMinutes);
      displayStrip(defaultColor);
    waitUntilRtc += oneSecondDelay;
void off() {
  if(millis() >= waitUntilOff) {
    DEBUG_PRINT("switching off");
    waitUntilOff = millis();
    resetAndBlack();
    displayStrip(CRGB::Black);
    waitUntilOff += halfSecondDelay;
void makeParty() {
  if(millis() >= waitUntilParty) {
    DEBUG_PRINT("YEAH party party");
    waitUntilParty = millis();
    resetAndBlack();
    for(int i = 0; i<NUM_LEDS;i++) {
      leds[i] = CHSV(random(0, 255), 255, 255);
    FastLED.show();
    waitUntilParty += halfSecondDelay;
void showHeart() {
  if(millis() >= waitUntilHeart) {
    DEBUG_PRINT("showing heart");
    waitUntilHeart = millis();
    resetAndBlack();
    pushToStrip(L29); pushToStrip(L30); pushToStrip(L70); pushToStrip(L89);
    pushToStrip(L11); pushToStrip(L48); pushToStrip(L68); pushToStrip(L91);
    pushToStrip(L7); pushToStrip(L52); pushToStrip(L107);
    pushToStrip(L6); pushToStrip(L106);
    pushToStrip(L5); pushToStrip(L105);
    pushToStrip(L15); pushToStrip(L95);
    pushToStrip(L23); pushToStrip(L83);
    pushToStrip(L37); pushToStrip(L77);
    pushToStrip(L41); pushToStrip(L61);
    pushToStrip(L59);
    displayStrip(CRGB::Red);
    waitUntilHeart += oneSecondDelay;
void showTree() {
  if(millis() >= waitUntilTree) {
    DEBUG_PRINT("showing x-mas tree");
    waitUntilTree = millis();
    resetAndBlack();
    pushToStrip(L50); pushToStrip(L48); pushToStrip(L68);
    pushToStrip(L32); pushToStrip(L72); pushToStrip(L33); pushToStrip(L73);
    pushToStrip(L25); pushToStrip(L85);
    pushToStrip(L24); pushToStrip(L84);
    pushToStrip(L16); pushToStrip(L96);
    pushToStrip(L17); pushToStrip(L97);
    pushToStrip(L1); pushToStrip(L18); pushToStrip(L98); pushToStrip(L101);
    pushToStrip(L21); pushToStrip(L38); pushToStrip(L41); pushToStrip(L58); pushToStrip(L61); pushToStrip(L78); pushToStrip(L81);
    pushToStrip(L59);
    displayStrip(CRGB::Green);
    waitUntilTree += oneSecondDelay;
void fastTest() {
  if(millis() >= waitUntilFastTest) {
    DEBUG_PRINT("test test test");
    waitUntilFastTest = millis();
    if(testMinutes >= 60) {
      testMinutes = 0;
      testHours++;
    if(testHours >= 24) {
      testHours = 0;
    //Array leeren
    resetAndBlack();
    testMinutes++;
    waitUntilFastTest += oneSecondDelay;
CRGB prevColor() {
  if(colorIndex > 0) {
    colorIndex--;
  return getColorForIndex();
CRGB nextColor() {
  if(colorIndex < 9) {
    colorIndex++;
CRGB getColorForIndex() {
  switch(colorIndex) {
    case 0:
      return CRGB::White;
    case 1:
      return CRGB::Blue;
    case 2:
      return CRGB::Aqua;
    case 3:
      return CRGB::Green;
    case 4:
      return CRGB::Lime;
    case 5:
      return CRGB::Red;
    case 6:
      return CRGB::Magenta;
    case 7:
      return CRGB::Olive;
    case 8:
      return CRGB::Yellow;
    case 9:
      return CRGB::Silver;
    default:
      colorIndex = 0;
      return CRGB::White;
void pushToStrip(int ledId) {
  strip[stackptr] = ledId;
  stackptr++;
void resetAndBlack() {
  resetStrip();
    leds[i] = CRGB::Black;
void resetStrip() {
  stackptr = 0;
    strip[i] = 0;
void displayStripRandomColor() {
  for(int i = 0; i<stackptr; i++) {
    leds[strip[i]] = CHSV(random(0, 255), 255, 255);
  FastLED.show();
void displayStrip() {
void displayStrip(CRGB colorCode) {
    leds[strip[i]] = colorCode;
  FastLED.show();
  pushES_IST();
  //show minutes
  if(minutes >= 5 && minutes < 10) {
    pushFUENF1();
    pushNACH();
  } else if(minutes >= 10 && minutes < 15) {
    pushZEHN1();
    pushNACH();
  } else if(minutes >= 15 && minutes < 20) {
    pushVIERTEL();
    pushNACH();
  } else if(minutes >= 20 && minutes < 25) {
    if(selectedLanguageMode == RHEIN_RUHR_MODE) {
      pushZWANZIG();
      pushNACH();
    } else if(selectedLanguageMode == WESSI_MODE) {
      pushZEHN1();
      pushVOR();
      pushHALB();
  } else if(minutes >= 25 && minutes < 30) {
    pushFUENF1();
    pushVOR();
    pushHALB();
  } else if(minutes >= 30 && minutes < 35) {
    pushHALB();
  } else if(minutes >= 35 && minutes < 40) {
    pushFUENF1();
    pushNACH();
    pushHALB();
  } else if(minutes >= 40 && minutes < 45) {
      pushZWANZIG();
      pushVOR();
      pushZEHN1();
      pushNACH();
      pushHALB();
  } else if(minutes >= 45 && minutes < 50) {
    pushVIERTEL();
    pushVOR();
  } else if(minutes >= 50 && minutes < 55) {
    pushZEHN1();
    pushVOR();
  } else if(minutes >= 55 && minutes < 60) {
    pushFUENF1();
    pushVOR();
  int singleMinutes = minutes % 5;
  switch(singleMinutes) {
    case 1:
      pushONE();
    case 2:
      pushONE();
      pushTWO();
    case 3:
      pushONE();
      pushTWO();
      pushTHREE();
    case 4:
      pushONE();
      pushTWO();
      pushTHREE();
      pushFOUR();
  if(hours >= 12) {
    hours -= 12;
    if(minutes >= 25) {
      hours++;
    if(minutes >= 20) {
      hours++;
  if(hours == 12) {
    hours = 0;
  //show hours
  switch(hours) {
    case 0:
      pushZWOELF();
    case 1:
      if(minutes > 4) {
        pushEINS(true);
        pushEINS(false);
    case 2:
      pushZWEI();
    case 3:
      pushDREI();
    case 4:
      pushVIER();
    case 5:
      pushFUENF2();
    case 6:
      pushSECHS();
    case 7:
      pushSIEBEN();
    case 8:
      pushACHT();
    case 9:
      pushNEUN();
    case 10:
      pushZEHN();
    case 11:
      pushELF();
  //show uhr
  if(minutes < 5) {
    pushUHR();
//PUSH WORD HELPER
void pushES_IST()  {
  pushToStrip(L9);
  pushToStrip(L10);
  pushToStrip(L30);
  pushToStrip(L49);
  pushToStrip(L50);
void pushFUENF1() {
  pushToStrip(L70);
  pushToStrip(L89);
  pushToStrip(L90);
  pushToStrip(L109);
void pushFUENF2() {
  pushToStrip(L74);
  pushToStrip(L85);
  pushToStrip(L94);
  pushToStrip(L105);
void pushNACH() {
  pushToStrip(L73);
  pushToStrip(L86);
  pushToStrip(L93);
  pushToStrip(L106);
void pushZEHN1() {
  pushToStrip(L8);
  pushToStrip(L11);
  pushToStrip(L28);
  pushToStrip(L31);
void pushVIERTEL() {
  pushToStrip(L47);
  pushToStrip(L52);
  pushToStrip(L67);
  pushToStrip(L72);
  pushToStrip(L87);
  pushToStrip(L92);
  pushToStrip(L107);
void pushVOR() {
  pushToStrip(L6);
  pushToStrip(L13);
  pushToStrip(L26);
void pushHALB() {
  pushToStrip(L5);
  pushToStrip(L14);
  pushToStrip(L25);
  pushToStrip(L34);
void pushFUNK() {
  pushToStrip(L33);
  pushToStrip(L46);
  pushToStrip(L53);
  pushToStrip(L66);
void pushONE() {
  pushToStrip(L113);
void pushTWO() {
  pushToStrip(L110);
void pushTHREE() {
  pushToStrip(L111);
void pushFOUR() {
  pushToStrip(L112);
void pushZWANZIG() {
  pushToStrip(L48);
  pushToStrip(L51);
  pushToStrip(L68);
  pushToStrip(L71);
  pushToStrip(L88);
  pushToStrip(L91);
  pushToStrip(L108);
void pushZWOELF() {
  pushToStrip(L61);
  pushToStrip(L78);
  pushToStrip(L81);
  pushToStrip(L98);
  pushToStrip(L101);
void pushEINS(bool s) {
  pushToStrip(L4);
  pushToStrip(L15);
  pushToStrip(L24);
  if(s) {
    pushToStrip(L35);
void pushZWEI() {
  pushToStrip(L75);
  pushToStrip(L84);
  pushToStrip(L95);
  pushToStrip(L104);
void pushDREI() {
  pushToStrip(L3);
  pushToStrip(L16);
  pushToStrip(L23);
  pushToStrip(L36);
void pushVIER() {
  pushToStrip(L76);
  pushToStrip(L83);
  pushToStrip(L96);
  pushToStrip(L103);
void pushSECHS() {
  pushToStrip(L2);
  pushToStrip(L17);
  pushToStrip(L22);
  pushToStrip(L37);
  pushToStrip(L42);
void pushSIEBEN() {
  pushToStrip(L1);
  pushToStrip(L18);
  pushToStrip(L21);
  pushToStrip(L38);
  pushToStrip(L41);
  pushToStrip(L58);
void pushACHT() {
  pushToStrip(L77);
  pushToStrip(L82);
  pushToStrip(L97);
  pushToStrip(L102);
void pushNEUN() {
  pushToStrip(L39);
  pushToStrip(L40);
  pushToStrip(L59);
  pushToStrip(L60);
void pushZEHN() {
  pushToStrip(L0);
  pushToStrip(L19);
  pushToStrip(L20);
  pushToStrip(L39);
void pushELF() {
  pushToStrip(L54);
  pushToStrip(L65);
  pushToStrip(L74);
void pushUHR() {
  pushToStrip(L80);
  pushToStrip(L99);
  pushToStrip(L100);
I'm pretty sure the problem is due to using 114 WS2812 LEDs. FastLED needs to create timing sensitive waveforms to update the LEDs. Each LED takes 30 us, which adds up to 3.42 ms. During that update, FastLED interferes with interrupts which tends to result in either losing incoming serial data, or having the serial data interfere with the LEDs.
There are a few ways to solve this.
1: Using a very slow baud rate is the easiest, if you can live with the slow performance. 2400 baud should work, since that will limit the speed to only 1 character every 4.17 ms. That will allow FastLED to interfere with interrupts for 3.42 ms and you still have plenty of time between bytes.
2: You can connect another signal to tell the ESP when it's ok to send data. Pulse the pin when you are not updating the LEDs, also allow enough time before you do another LED update for the entire message to arrive.
3: The very new WS2812Serial library is meant to solve this problem. But it uses extra memory, and on Teensy LC is uses Serial1 which means you would need to use Serial2 or Serial3 to receive the timestamp data. You'll also need the very latest FastLED from github, since Daniel merged the WS2812Serial support only 2 days ago. After you have installed both of these libraries, look at the FastLED_Cylon example. You just change "WS2812" to "WS2812SERIAL" in LEDS.addLeds<>(), and you add "#define USE_WS2812SERIAL" between the two #include lines for these libs.
The LED update will probably also interfere with IRremote's ability to receive incoming data. WS2812Serial is probably your only viable path since you can't really control the timing of incoming infrared remote control data.
WS2812 / NeoPixel updates interfering with incoming communication is very a common problem. That's why I wrote the WS2812Serial library!
EDIT: I forgot solution #4, which is the answer you will get from Adafruit and pretty much everyone else (for non-Teensy boards): you can buy different LEDs like APA102 or WS2801 which have both clock and data signals. Those LEDs can tolerate timing differences. If the extra 1.7k of memory for WS2812Serial or use of Serial1 is a problem, that might be your only other way to get this working together with IRremote.
Thanks for your answer and help! I will try your suggestions asap!
Would it help to move the serial communication part into the setup? I only need to check the time at startup...
Greetings, Kai
I tried to change the baud rate - this didn't work at all. I got no messages from the esp at all.
So I will give the #3 a try next.
Greetings, Kai
