new to teensy question: octows2811 video mirrored
e.oelberg
New member
huch: octows2811 video always mirrored ?
Hello hello
I'm new to the forum, teensy LED matrixes and all the stuff. Nevertheless I already built successful a matrix 60 x 24 LED big with an octows2811 and a teensy 3.2 it works, test patches run and I was able to screen video ! The only problem I have is all video is mirrored. I thought I just change the direction from left to right to right to left by changing 0 to 1, but no difference. What did I do wrong or how can I flip (mirror) the image to display correct ?
I went around doing the usual searches on the forum but didn't find a answer yet, maybe I was looking for the wrong terms
thank you, nicholas
What did I do wrong
How could anyone possibly say from only this message, which doesn't show any photos of how you actually wired up your LEDs, nor the specific settings you used in the code.
Well, if your layout doesn't match any of the ways the code already implements, you might have to modify the code. This may involve more than just changing a setting or 1 number. It all depends on the fine details, which aren't in your message...
Hi Paul !
of course, they are not, pardon.. I hoped for a common beginner's error. Here is a photo of my wiring. These are the first 1-4, 5-8 look the same.
The code is unchanged apart of Led_height and LED_Layout:
/*  OctoWS2811 VideoDisplay.ino - Video on LEDs, from a PC, Mac, Raspberry Pi
    http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
    Copyright (c) 2013 Paul Stoffregen, PJRC.COM, LLC
    Permission is hereby granted, free of charge, to any person obtaining a copy
    of this software and associated documentation files (the "Software"), to deal
    in the Software without restriction, including without limitation the rights
    to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
    copies of the Software, and to permit persons to whom the Software is
    furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in
    all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
    LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
    THE SOFTWARE.
Update: The movie2serial program which transmit data has moved to "extras"
https://github.com/PaulStoffregen/OctoWS2811/tree/master/extras
  Required Connections
    pin 2:  LED Strip #1    OctoWS2811 drives 8 LED Strips.
    pin 14: LED strip #2    All 8 are the same length.
    pin 7:  LED strip #3
    pin 8:  LED strip #4    A 100 to 220 ohm resistor should used
    pin 6:  LED strip #5    between each Teensy pin and the
    pin 20: LED strip #6    wire to the LED strip, to minimize
    pin 21: LED strip #7    high frequency ringining & noise.
    pin 5:  LED strip #8
    pin 15 & 16 - Connect together, but do not use
    pin 4:  Do not use
    pin 3:  Do not use as PWM.  Normal use is ok.
    pin 12: Frame Sync
    When using more than 1 Teensy to display a video image, connect
    the Frame Sync signal between every board.  All boards will
    synchronize their WS2811 update using this signal.
    Beware of image distortion from long LED strip lengths.  During
    the WS2811 update, the LEDs update in sequence, not all at the
    same instant!  The first pixel updates after 30 microseconds,
    the second pixel after 60 us, and so on.  A strip of 120 LEDs
    updates in 3.6 ms, which is 10.8% of a 30 Hz video frame time.
    Doubling the strip length to 240 LEDs increases the lag to 21.6%
    of a video frame.  For best results, use shorter length strips.
    Multiple boards linked by the frame sync signal provides superior
    video timing accuracy.
    A Multi-TT USB hub should be used if 2 or more Teensy boards
    are connected.  The Multi-TT feature allows proper USB bandwidth
    allocation.  Single-TT hubs, or direct connection to multiple
    ports on the same motherboard, may give poor performance.
#include <OctoWS2811.h>
// The actual arrangement of the LEDs connected to this Teensy 3.0 board.
// LED_HEIGHT *must* be a multiple of 8.  When 16, 24, 32 are used, each
// strip spans 2, 3, 4 rows.  LED_LAYOUT indicates the direction the strips
// are arranged.  If 0, each strip begins on the left for its first row,
// then goes right to left for its second row, then left to right,
// zig-zagging for each successive row.
#define LED_WIDTH      60   // number of LEDs horizontally
#define LED_HEIGHT     24   // number of LEDs vertically (must be multiple of 8)
#define LED_LAYOUT     0    // 0 = even rows left->right, 1 = even rows right->left
// The portion of the video image to show on this set of LEDs.  All 4 numbers
// are percentages, from 0 to 100.  For a large LED installation with many
// Teensy 3.0 boards driving groups of LEDs, these parameters allow you to
// program each Teensy to tell the video application which portion of the
// video it displays.  By reading these numbers, the video application can
// automatically configure itself, regardless of which serial port COM number
// or device names are assigned to each Teensy 3.0 by your operating system.
#define VIDEO_XOFFSET
#define VIDEO_YOFFSET  0       // display entire image
#define VIDEO_WIDTH    100
#define VIDEO_HEIGHT   100
//#define VIDEO_XOFFSET  0
//#define VIDEO_YOFFSET  0     // display upper half
//#define VIDEO_WIDTH    100
//#define VIDEO_HEIGHT   50
//#define VIDEO_XOFFSET  24
//#define VIDEO_YOFFSET  85    // display lower half
//#define VIDEO_WIDTH    50
//#define VIDEO_HEIGHT   7
const int ledsPerStrip = LED_WIDTH * LED_HEIGHT / 8;
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
elapsedMicros elapsedUsecSinceLastFrameSync = 0;
const int config = WS2811_800kHz; // color config is on the PC side
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
  pinMode(12, INPUT_PULLUP); // Frame Sync
  Serial.setTimeout(50);
  leds.begin();
  leds.show();
// wait for a Start-Of-Message character:
//   '*' = Frame of image data, with frame sync pulse to be sent
//         a specified number of microseconds after reception of
//         the first byte (typically at 75% of the frame time, to
//         allow other boards to fully receive their data).
//         Normally '*' is used when the sender controls the pace
//         of playback by transmitting each frame as it should
//         appear.
//   '$' = Frame of image data, with frame sync pulse to be sent
//         a specified number of microseconds after the previous
//         frame sync.  Normally this is used when the sender
//         transmits each frame as quickly as possible, and we
//         control the pacing of video playback by updating the
//         LEDs based on time elapsed from the previous frame.
//   '%' = Frame of image data, to be displayed with a frame sync
//         pulse is received from another board.  In a multi-board
//         system, the sender would normally transmit one '*' or '$'
//         message and '%' messages to all other boards, so every
//         Teensy 3.0 updates at the exact same moment.
//   '@' = Reset the elapsed time, used for '$' messages.  This
//         should be sent before the first '$' message, so many
//         frames are not played quickly if time as elapsed since
//         startup or prior video playing.
//   '?' = Query LED and Video parameters.  Teensy 3.0 responds
//         with a comma delimited list of information.
  int startChar = Serial.read();
  if (startChar == '*') {
    // receive a "master" frame - we send the frame sync to other boards
    // the sender is controlling the video pace.  The 16 bit number is
    // how far into this frame to send the sync to other boards.
    unsigned int startAt = micros();
    unsigned int usecUntilFrameSync = 0;
    int count = Serial.readBytes((char *)&usecUntilFrameSync, 2);
    if (count != 2) return;
    count = Serial.readBytes((char *)drawingMemory, sizeof(drawingMemory));
    if (count == sizeof(drawingMemory)) {
      unsigned int endAt = micros();
      unsigned int usToWaitBeforeSyncOutput = 100;
      if (endAt - startAt < usecUntilFrameSync) {
        usToWaitBeforeSyncOutput = usecUntilFrameSync - (endAt - startAt);
      digitalWrite(12, HIGH);
      pinMode(12, OUTPUT);
      delayMicroseconds(usToWaitBeforeSyncOutput);
      digitalWrite(12, LOW);
      // WS2811 update begins immediately after falling edge of frame sync
      digitalWrite(13, HIGH);
      leds.show();
      digitalWrite(13, LOW);
  } else if (startChar == '$') {
    // we are controlling the video pace.  The 16 bit number is how long
    // after the prior frame sync to wait until showing this frame
      while (elapsedUsecSinceLastFrameSync < usecUntilFrameSync) /* wait */ ;
      elapsedUsecSinceLastFrameSync -= usecUntilFrameSync;
      leds.show();
  } else if (startChar == '%') {
    // receive a "slave" frame - wait to show it until the frame sync arrives
    unsigned int unusedField = 0;
    int count = Serial.readBytes((char *)&unusedField, 2);
      elapsedMillis wait = 0;
      while (digitalRead(12) != HIGH && wait < 30) ; // wait for sync high
      while (digitalRead(12) != LOW && wait < 30) ;  // wait for sync high->low
      if (wait < 30) {
        leds.show();
  } else if (startChar == '@') {
    // reset the elapsed frame time, for startup of '$' message playing
  } else if (startChar == '?') {
    // when the video application asks, give it all our info
    // for easy and automatic configuration
    Serial.print(LED_WIDTH);
    Serial.write(',');
    Serial.print(LED_HEIGHT);
    Serial.write(',');
    Serial.print(LED_LAYOUT);
    Serial.write(',');
    Serial.print(0);
    Serial.write(',');
    Serial.print(0);
    Serial.write(',');
    Serial.print(VIDEO_XOFFSET);
    Serial.write(',');
    Serial.print(VIDEO_YOFFSET);
    Serial.write(',');
    Serial.print(VIDEO_WIDTH);
    Serial.write(',');
    Serial.print(VIDEO_HEIGHT);
    Serial.write(',');
    Serial.print(0);
    Serial.write(',');
    Serial.print(0);
    Serial.write(',');
    Serial.print(0);
  } else if (startChar >= 0) {
    // discard unknown characters
if you change LED_LAYOUT 1 it makes no difference.
movie2serial is also unchanged but the movie file
I'm more of a musician than a coder please excuse if I not yet get the terminology right
thank you, Nicholas
if ((y & 1) == (layout ? 1 : 0)) { //changed from originally: (layout ? 0 : 1)
ok that's my rough and dirty solution for now:
/*  OctoWS2811 movie2serial.pde - Transmit video data to 1 or more
      Teensy 3.0 boards running OctoWS2811 VideoDisplay.ino
    THE SOFTWARE.
// To configure this program, edit the following sections:
//  1: change myMovie to open a video file of your choice    ;-)
//  2: edit the serialConfigure() lines in setup() for your
//     serial device names (Mac, Linux) or COM ports (Windows)
//  3: if your LED strips have unusual color configuration,
//     edit colorWiring().  Nearly all strips have GRB wiring,
//     so normally you can leave this as-is.
//  4: if playing 50 or 60 Hz progressive video (or faster),
//     edit framerate in movieEvent().
import processing.video.*;
import processing.serial.*;
import java.awt.Rectangle;
Movie myMovie = new Movie(this, "/Users/nicholas/Documents/test.mov");
float gamma = 1.7;
int numPorts=0;  // the number of serial ports in use
int maxPorts=24; // maximum number of serial ports
Serial[] ledSerial = new Serial[maxPorts];     // each port's actual Serial port
Rectangle[] ledArea = new Rectangle[maxPorts]; // the area of the movie each port gets, in % (0-100)
boolean[] ledLayout = new boolean[maxPorts];   // layout of rows, true = even is left->right
PImage[] ledImage = new PImage[maxPorts];      // image sent to each port
int[] gammatable = new int[256];
int errorCount=0;
float framerate=0;
  String[] list = Serial.list();
  delay(20);
  println("Serial Ports List:");
  println(list);
  serialConfigure("/dev/tty.usbmodem3292521");  // change these to your port names
  //serialConfigure("/dev/ttyACM1");
  if (errorCount > 0) exit();
  for (int i=0; i < 256; i++) {
    gammatable[i] = (int)(pow((float)i / 255.0, gamma) * 255.0 + 0.5);
  size(480, 192);  // create the window
  myMovie.loop();  // start the movie :-)
// movieEvent runs for each new frame of movie data
void movieEvent(Movie m) {
  // read the movie's next frame
  m.read();
  //if (framerate == 0) framerate = m.getSourceFrameRate();
  framerate = 30.0; // TODO, how to read the frame rate???
  for (int i=0; i < numPorts; i++) {
    // copy a portion of the movie's image to the LED image
    int xoffset = percentage(m.width, ledArea[i].x);
    int yoffset = percentage(m.height, ledArea[i].y);
    int xwidth =  percentage(m.width, ledArea[i].width);
    int yheight = percentage(m.height, ledArea[i].height);
    ledImage[i].copy(m, xoffset, yoffset, xwidth, yheight,
                     0, 0, ledImage[i].width, ledImage[i].height);
    // convert the LED image to raw data
    byte[] ledData =  new byte[(ledImage[i].width * ledImage[i].height * 3) + 3];
    image2data(ledImage[i], ledData, ledLayout[i]);
    if (i == 0) {
      ledData[0] = '*';  // first Teensy is the frame sync master
      int usec = (int)((1000000.0 / framerate) * 0.75);
      ledData[1] = (byte)(usec);   // request the frame sync pulse
      ledData[2] = (byte)(usec >> 8); // at 75% of the frame time
      ledData[0] = '%';  // others sync to the master board
      ledData[1] = 0;
      ledData[2] = 0;
    // send the raw data to the LEDs  :-)
    ledSerial[i].write(ledData);
// image2data converts an image to OctoWS2811's raw data format.
// The number of vertical pixels in the image must be a multiple
// of 8.  The data array must be the proper size for the image.
void image2data(PImage image, byte[] data, boolean layout) {
  int offset = 3;
  int x, y, xbegin, xend, xinc, mask;
  int linesPerPin = image.height / 8;
  int pixel[] = new int[8];
  for (y = 0; y < linesPerPin; y++) {
      // even numbered rows are left to right
      xbegin = 0;
      xend = image.width;
      xinc = 1;
      // odd numbered rows are right to left
      xbegin = image.width - 1;
      xend = -1;
      xinc = -1;
    for (x = xbegin; x != xend; x += xinc) {
      for (int i=0; i < 8; i++) {
        // fetch 8 pixels from the image, 1 for each pin
        pixel[i] = image.pixels[x + (y + linesPerPin * i) * image.width];
        pixel[i] = colorWiring(pixel[i]);
      // convert 8 pixels to 24 bytes
      for (mask = 0x800000; mask != 0; mask >>= 1) {
        byte b = 0;
          if ((pixel[i] & mask) != 0) b |= (1 << i);
        data[offset++] = b;
// translate the 24 bit color from RGB to the actual
// order used by the LED wiring.  GRB is the most common.
int colorWiring(int c) {
  int red = (c & 0xFF0000) >> 16;
  int green = (c & 0x00FF00) >> 8;
  int blue = (c & 0x0000FF);
  red = gammatable[red];
  green = gammatable[green];
  blue = gammatable[blue];
  return (green << 16) | (red << 8) | (blue); // GRB - most common wiring
// ask a Teensy board for its LED configuration, and set up the info for it.
void serialConfigure(String portName) {
  if (numPorts >= maxPorts) {
    println("too many serial ports, please increase maxPorts");
    errorCount++;
    return;
  try {
    ledSerial[numPorts] = new Serial(this, portName);
    if (ledSerial[numPorts] == null) throw new NullPointerException();
    ledSerial[numPorts].write('?');
  } catch (Throwable e) {
    println("Serial port " + portName + " does not exist or is non-functional");
    errorCount++;
    return;
  delay(50);
  String line = ledSerial[numPorts].readStringUntil(10);
  if (line == null) {
    println("Serial port " + portName + " is not responding.");
    println("Is it really a Teensy 3.0 running VideoDisplay?");
    errorCount++;
    return;
  String param[] = line.split(",");
  if (param.length != 12) {
    println("Error: port " + portName + " did not respond to LED config query");
    errorCount++;
    return;
  // only store the info and increase numPorts if Teensy responds properly
  ledImage[numPorts] = new PImage(Integer.parseInt(param[0]), Integer.parseInt(param[1]), RGB);
  ledArea[numPorts] = new Rectangle(Integer.parseInt(param[5]), Integer.parseInt(param[6]),
                     Integer.parseInt(param[7]), Integer.parseInt(param[8]));
  ledLayout[numPorts] = (Integer.parseInt(param[5]) == 0);
  numPorts++;
// draw runs every time the screen is redrawn - show the movie...
void draw() {
  // show the original video
  image(myMovie, 0, 80);
  // then try to show what was most recently sent to the LEDs
  // by displaying all the images for each port.
    // compute the intended size of the entire LED array
    int xsize = percentageInverse(ledImage[i].width, ledArea[i].width);
    int ysize = percentageInverse(ledImage[i].height, ledArea[i].height);
    // computer this image's position within it
    int xloc =  percentage(xsize, ledArea[i].x);
    int yloc =  percentage(ysize, ledArea[i].y);
    // show what should appear on the LEDs
    image(ledImage[i], 240 - xsize / 2 + xloc, 10 + yloc);
// respond to mouse clicks as pause/play
boolean isPlaying = true;
void mousePressed() {
  if (isPlaying) {
    myMovie.pause();
    isPlaying = false;
    myMovie.play();
    isPlaying = true;
// scale a number by a percentage, from 0 to 100
int percentage(int num, int percent) {
  double mult = percentageFloat(percent);
  double output = num * mult;
  return (int)output;
// scale a number by the inverse of a percentage, from 0 to 100
int percentageInverse(int num, int percent) {
  double div = percentageFloat(percent);
  double output = num / div;
  return (int)output;
// convert an integer from 0 to 100 to a float percentage
// from 0.0 to 1.0.  Special cases for 1/3, 1/6, 1/7, etc
// are handled automatically to fix integer rounding.
double percentageFloat(int percent) {
  if (percent == 33) return 1.0 / 3.0;
  if (percent == 17) return 1.0 / 6.0;
  if (percent == 14) return 1.0 / 7.0;
  if (percent == 13) return 1.0 / 8.0;
  if (percent == 11) return 1.0 / 9.0;
  if (percent ==  9) return 1.0 / 11.0;
  if (percent ==  8) return 1.0 / 12.0;
  return (double)percent / 100.0;
