Results 1 to 4 of 4
Thread: Simultaneously start multiple timers
    Sep 2015
    19
    For a project which requires precise timings, I'm trying to align three PWM signals from three different timers; one 12 MHz, one 1.5 MHz and one 0.75 MHz signal.
    As far as I understand this would require all three timers to start counting at the same time from 0.
    The only problem is that I can't seem to find a way to start the timers simultaneously; when I run FTM2_SC = FTM1_SC = FTM3_SC = FTM_SC_CLKS(1) | FTM_SC_PS(0); every register is set after each other, which already creates a time offset between the timers.
    What I tried in the code below is to give the timers an specific offset before they start, which would make them align when they get started sequentially.
    For Teensy 3.6:
    // For Teensy 3.6
    // 12 MHz on pin 3
    // 0.75 MHz on pin 29
    // 1.5 MHz on pin 35
      FTM1_SC = 0;
      FTM1_CNT = 0;
      FTM1_MOD = 4;
      FTM1_C0SC = 0x28;
      FTM1_C0V = 2;
      CORE_PIN3_CONFIG = PORT_PCR_IRQC(1) | PORT_PCR_MUX(3);
      FTM2_SC = 0;
      FTM2_CNT = 0;
      FTM2_MOD = 79;
      FTM2_C0SC = 0x28;
      FTM2_C0V = 40;
      CORE_PIN29_CONFIG = PORT_PCR_IRQC(1) | PORT_PCR_MUX(3);
      FTM3_SC = 0;
      FTM3_CNT = 0;
      FTM3_MOD = 39;
      FTM3_C4SC = 0x28;
      FTM3_C4V = 5;
      CORE_PIN35_CONFIG = PORT_PCR_IRQC(1) | PORT_PCR_MUX(3);
      syncStart();
      delayMicroseconds(100);
      stop();
      delay(10);
    void stop() {
      FTM1_SC = 0;
      FTM2_SC = 0;
      FTM3_SC = 0;
    void syncStart() {
      noInterrupts();
      FTM2_SC = 0;
      FTM2_CNT = 0;
      FTM1_SC = 0;
      FTM3_SC = 0;
      FTM1_CNTIN = 3;
      FTM1_CNT = 0;
      FTM1_CNTIN = 0;
      FTM3_CNTIN = 36;
      FTM3_CNT = 0;
      FTM3_CNTIN = 0;
      FTM2_SC = FTM1_SC = FTM3_SC =  FTM_SC_CLKS(1) | FTM_SC_PS(0);  // start the timers
      interrupts();
    This seems to work ok, but it produces a small error at the beginning; when starting the timers the output of the channel will always go to HIGH; the following two screenshots explain more than a thousand words:
    0.75 MHz & 12 MHz: SDS00002.BMP
    0.75 MHz & 1.5 MHz: SDS00003.BMP
    I assume there is a better way of doing this, one that also doesn't depend on the delay between the execution of timer start commands.
    I would love to hear any suggestions!
    Thanks!
    25,217
    You could try configuring the FTM timers to use an external clock, instead of F_BUS. I believe pins 0 and 1 (PTB16 & PTB17) can be used if their config mux is set to ALT4. Look at the SIM_SOPT4 register for configuring how the timers get their clocks.
    There's also a hardware mechanism for sync'd trigger documented on section 45.1.6 on pages 1128-1129.
    I have not personally tried either of these. If you do, I hope you'll share anything you learn?
    Sep 2015
    19
    Thanks! I'll look into both options and report back
    Feb 2014
    Colmar, France
    2,600
    I'd use the Teensy just to generate the 12MHz clock and use an external 74HC binary counter as a divider by 8 and by 16 to get 1.5 and 0.75 Mhz.
