Results 1 to 12 of 12
Thread: Eclipse Arduino Download Manager for Teensy
    Okay, so my last Teensy project used 12 classes, and I really don't want to use the Arduino IDE anymore. I've tried various approaches, Sloeber, Jante, but there seems to be some issue or another that is annoying enough to cause me to drop back to the Arduino toolchain.
    I'm starting a new project, and it looks like the Eclipse CDT has come a long way to support the IOT platforms, with Arduino included. However, there is no Teensy support. I'm just looking for an eclipse solution that works.
    What is the best Eclipse environment Teensy toolchain solution?
    Feb 2014
    Colmar, France
    1,454
    Still Sloeber. Using it, too. To make it work with the Teensy boards, you have to have a parallel installation of the Arduino IDE, just as a container for the Teensyduino installation because the Teensy hardware info can't be just downloaded as for many other boards. That's not a Sloeber problem, but a decision from PJRC. Then, you have just to add the local hardware and lib path in the Sloeber settings. Takes 1 minute.Click image for larger version.
Name:	Capture d’écran 2017-11-06 à 18.38.08.png
    Thanks. I'll give it another try. It's been about a year since I tried the Sloeber solution.
    Feb 2017
    134
    So, is there somewhere a nice step-by-step tutorial for installing and setting up this Eclipse / Sloeber? I’m really interested in moving from Arduino to a more sophisticated IDE. But, I’m definitely not interested in spending a lot of time dorking around hunting down and maintaining tool chains, etc. I just want to use the IDE, not dedicate my life to it.
    Feb 2014
    Colmar, France
    1,454
    All you need is downloading and installing Sloeber, and then add the paths as I showed in my previous posts. More is not needed, especially if you are used to working with workspace oriented IDEs.
    San Francisco Bay Area
    640
    This really seems like it's much easier now. With the new teensyduino, I'll have to give this a go. Especially since I switched to the new version of sublime and it's really sluggish on linux.
    Feb 2017
    134
    @Theremingenieur:
    If you wouldn't mind giving a little guidance, I'd really appreciate it as this is very confusing.
    So, I wanted to start my Sloeber Adventure with a clean install of the latest IDE and Teensyduino (1.8.5 / 1.40). But, I wanted to keep my old IDE installation for all my legacy projects. So I did a "portable installation" of the IDE per:
    www.arduino.cc/en/Guide/PortableIDE
    It's located right in the root folder of my D: drive:
    I then installed Teensyduino and the ESP8266 package into the IDE.
    Then, I installed Sloeber V4 -- at least I think I did, kind of a weird installation process. It's also in the root folder of my D: drive:
    Now I have this:
    Doesn't look like your picture. What are the magic incantations I need to put into these boxes so I can write sketches for Teensy and Adafruit ESP8266 Huzzah? What if I later want to add the Adafruit SAMD board?
    Thanks for your time.
    Feb 2014
    Colmar, France
    1,454
    You are on Windows, I am on Mac... your last pic looks basically ok, for the hardware path you’d have to click on New and then browsing towards the folder (inside your Arduino installation) and adding the one containing the Teensy3 boards.txt file. Then, for the private library path the same, click New and add the Teensy3 lib path. Then, you should be done.
    Can’t help for other boards since I’m working exclusively with Teensy, but basically, the procedure would be similar.
    Nov 2017
    2
    It working on linux or not?
    Feb 2014
    Colmar, France
    1,454
    Naturally! As all professional developers know, Eclipse is open source and programmed in Java and rund thus on Win, Mac, and Linux. Sloeber is just a ready to install bundle comprising Eclipse v4 and Jantje’s famous Arduino plug-in for it.
    Feb 2017
    134
    Thanks for the help @Theremingenieur, I've managed to get Sloeber installed and configured -- including support for Teensy and ESP8266.
    Now, if you don't mind, just one more question. You mentioned:
    Well, I'm definitely not. So, I'd like a little advice on keeping things organized. When using the Arduino IDE I often make subfolders in my main sketch folder. These enable me to group together related sketches or different versions of the same sketch in a hierarchical manner.
    So, what's the equivalent of this hierarchy in the Eclipse world? Say I want to group together multiple versions of the same sketch so that I can always revert back to a previous one if I screw things up too badly along the way. Can I have multiple versions of the source code in the same project? Or, do I make a "sub workspace" under my main one and put an individual project for each version in there? What I'm trying to avoid is having a large, flat workspace structure that contains every sketch I've ever written all on the same "level". I prefer hierarchical organization.
    Thanks.
    PS - I've posted a similar question on the Arduino Other Software Development forum but have received no replies.
    Feb 2018
    1
    Sorry for the thread necro...
    Long time listener, first time poster.
    Just wanted to report that setting the paths per theremingenieur worked for me on Windows 10, Java 8, 64 bit, sloeber release 4.2
    Thanks for the info.
