How can I include the SdFat that came with Audio.h (not the default one)
qcarver
I have an audio 'logger', and I want to use an SD2Card object in my sketch.
Audio.h does (in a round about way) provide the SD2Card code but only the library seems to see it. This is probably because it is in the "utility" folder of the library; I assume this is not "public" with the library.
Compile output shows that he only library w/o "teensy" in the path is SDFat. It is being included from .....Arduino/libraries/SDFat which causes trouble when building for the teensy (compile outputs below):
Using library Audio at version 1.3 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.1.1 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.5 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SerialFlash
[COLOR="#A52A2A"]Using library SdFat at version 1.0.3 in folder: C:\Program Files\Arduino\libraries\SdFat [/COLOR]
Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\Wire
Using library TinyGPS in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\TinyGPS (legacy)
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SoftwareSerial
Error compiling for board Teensy 3.2 / 3.1.
I'm hoping someone will say something like: "There is a cool library.properties tag that will let you include everything in the folder not just the root .h and .cpp of the library".
I suppose I could brute force it and just bust up Paul's teensy/avr/SD library into more libraries, but those utilities have includes of their own in the same utility folder... so.. more libraries. Not so elegant. Ideas?
