Results 1 to 14 of 14
Thread: "Error compiling for board Teensy LC"
    Nov 2017
    12
    I'm not sure what happened - i had this program working fine previously but all of a sudden it started acting up and wont compile on the teensy LC anymore. any ideas on how to resolve this issue? heres the full error message:
    Arduino: 1.8.5 (Mac OS X), TD: 1.40, Board: "Teensy LC, MIDI, 48 MHz, Debug, US English"
    /Users/user/Desktop/project/tap_tempo.ino: At global scope:
    /Users/user/Desktop/project/tap_tempo.ino:32:1: internal compiler error: in output_constructor_regular_field, at varasm.c:4986
    libbacktrace could not find executable to open
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <http://gcc.gnu.org/bugs.html> for instructions.
    Multiple libraries were found for "LiquidCrystal.h"
     Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/LiquidCrystal
     Not used: /Applications/Arduino.app/Contents/Java/libraries/LiquidCrystal
    Error compiling for board Teensy LC.
    I had this project working fine yesterday and now that its stopped working i am beyond frustrated. any help would be greatly appreciated
    17,483
    Oh, that looks bad. Real compiler bugs are rare, but they do exists.
    Since it's on line 4986, I'm going to guess you have a *lot* of code in this project or a library? Even if you posted such a huge program, I'm not sure anyone could really dig through so much code.
    As will all these sorts of things, the first step is trying to whittle it down to a smaller program which still produces the error. Sorry, there's just not much I can do on this, other than this overly obvious and probably not too helpful suggestion.
    Nov 2017
    12
    i cut down my code to a fraction of the length and its still saying that its on 4896, there arent that many lines in the current code. Where should I go from here?
    17,483
    Can you share the code? I'll give it a try here and see if I can reproduce the error.
    Nov 2017
    12
    AARP_v2.zip
    there it is, thanks for taking a look at it
    926
    The problem is the incorrect way in which you initialized the pitch and step1 arrays (the compiler spits out a lot of warning messages).
    E.g.
    char*pitch[] = {
    pitch[0] = "-12",
    pitch[1] = "-11",
    pitch[2] = "-10",
    and
    float step1[] = {
    step1[0] = 1, //12
    step1[1] = 10, //11
    step1[2] = 18,  //10
    Change the declarations of these arrays to:
    const char*pitch[] = {
      "-12",
      "-11",
      "-10",
      "-9 ",
      "-8 ",
      "-7 ",
      "-6 ",
      "-5 ",
      "-4 ",
      "-3 ",
      "-2 ",
      "-1 ",
      " 0 ",
      "+1 ",
      "+2 ",
      "+3 ",
      "+4 ",
      "+5 ",
      "+6 ",
      "+7 ",
      "+8 ",
      "+9 ",
      "+10",
      "+11",
      "+12"
    float step1[] = {
       1, //12
      10, //11
      18,  //10
      28,  //9
      38, //8
      47, //7
      54, //6
      60, //5
      69, //4
      77, //3
      85, //2
      90,//1
      99, //0
      107, //1
      117,//2
      124,//3
      130,//4
      140,//5
      150,//6
      157,//7
      165,//8
      171,//9
      179,//10
      189,//11
      200//12
    This gets rid of the problem.
    Adding const to the declaration of the pitch array removes a lot more compiler warning messages which then makes it easier to see warnings like this:
    lcd_update: In function 'void lcdUpdate()':
    lcd_update:15: warning: array subscript is above array bounds
         lcd.write(dash[8]);
    AARP_v2: In function 'void loop()':
    AARP_v2:485: warning: array subscript is above array bounds
         lcd.write(dash[8]);
    AARP_v2:491: warning: array subscript is above array bounds
         lcd.write(dash[8]);
    These suggest that there's an error here.
    EDIT: They should probably be
         lcd.write(dash);
    Pete
    Nov 2017
    12
    Thanks Pete- Iíll give that a shot. wonder why it has compiled hundreds of times in the past, yet all of a sudden wonít compile?
    926
    Have you updated to a new version of the Arduino IDE and/or Teensyduino?
    Pete
    17,483
    Indeed, the error is wrong syntax for initializing the pitch[] and step1[] arrays.
    Quote Originally Posted by tjm56 View Post
    wonder why it has compiled hundreds of times in the past, yet all of a sudden won’t compile?
    I believe a better question is why did that ever compile before? Are you sure it was really like that in a prior version? Any chance you have any backups or prior versions archived anywhere?
    17,483
    Looks like older 4.8 versions of the toolchain do allow this syntax. But 5.4 we're using doesn't like it at all.
    2,686
    Cool
    It is what is called a designated initializer. The C99 standard describes a syntax to initialize fields within a structure, and GCC had a slightly different syntax as a previous GCC extension. GCC accepts both formats when translating the C language. However the C++ language committee decided they did not want it, and it is not in the ISC C++. I don't recall if older GNU C++'s accepted designated initializers or not. Perhaps if the code was in a library, it was installed as a C file and not C++, and the C compiler allowed it.
    Nov 2017
    12
    yeah I have a few that are works in progress, using the same incorrect syntax, and it doesnt compile. Also, I changed the syntax to "const char*pitch[]" and it still wont compile.
    I did update my teensyduino software recently, should I revert to an older version?
    Nov 2017
    12
    yup, solved the problem. reverted back to teensyduino 1.35 and arduino 1.8.1 and its uploading. Thank you all for your help and suggestions!
    17,483
    You could also just edit the initialization of those 2 arrays. Assigning to the array within its own initialization can't be good...
