Results 1 to 3 of 3
Thread: No Audio Library
    Oct 2017
    17
    No Audio Library (solved)
    I installed Teensyduino in Arduino IDE on Ubuntu. I can see the Teensy version in the IDE about splash, but even after the installation, the librariesí Examples menu looks as it was before.
    When I made this same installation on my Mac, many more Libraries was added, but not on Ubuntu.
    One of these Libraries is ďAudioĒ. Iím starting my first Audio project with Teensy + the Audio module, but thereís no Audio example in the Examples menu. In fact, I'm not really sure if all the Libraries was installed (Iím sure all was selected in the installation though).
    On the Libraries webpage, I canít see the Audio Livrary. Is there a way, I can get it somewhere ?
    Thanks.
    Apr 2013
    1,759
    Audio should be on the check list you get shown during the install process, so it is possible to de-select it. Does your devices list show Teensy as an option, and have you got it selected? Examples only show for devices that match so if this vanilla install is still set for Uno only base libraries will be shown.
    Oct 2017
    17
    Thank you so much GremlinWrangler!
    That was exactly the solution.
Tags for this Thread
